jphurwitz Samba Member
Joined: January 08, 2019 Posts: 8 Location: San Diego, CA
Posted: Fri Jan 11, 2019 7:00 pm Post subject: Igntion Problem - 1980 vanagon westfalia |
Hi All,
I'm broken down on the road in Guatemala during a test drive (van has been sitting for 2 years) I'm having an issue with the ignition. It was working intermittently and has stopped working completely. What I mean is that when I turn the key in the ignition, the dash lights come on, etc, and when I turn the key to start nothing happens. There is no noise.
I have had this happen before and replacing the ignition switch fixed the issue. I have two spare ignition switches on hand and I used both of them but neither worked. I also rocked the van back and forth in 3rd gear, jumped the starter (which works) and checked all the connections for the coil, distributor, and sparkplugs (which all looked good).
I'm next to a hill, so next is to try a push start down the hill.
I would really like to get to the bottom of this problem so that my van starts again after I turn it off.
Any help would be great.
Thanks. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8511 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jan 11, 2019 7:55 pm Post subject: Re: Igntion Problem - 1980 vanagon westfalia |
Sticky solenoid would cause your issue...not uncommon.
Also check all your battery, starter & main ground connections...
(bottom of battery box, tranny mount & DS engine block to frame)
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jan 11, 2019 9:30 pm Post subject: Re: Igntion Problem - 1980 vanagon westfalia |
| I'll check it out. The solenoid. Pushing her downhill worked great. Now I just have to figure out what the issue is. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5175 Location: California's Hot and Smoggy Central Valley
Posted: Fri Jan 11, 2019 11:01 pm Post subject: Re: Igntion Problem - 1980 vanagon westfalia |
Try to get one of these and use it to connect directly to the starter solenoid. It will help your troubleshooting:
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Sat Jan 12, 2019 6:00 am Post subject: Re: Igntion Problem - 1980 vanagon westfalia |
If you have an idiots guide its very applicable to the aircooled vans. John gives great direction on testing the primary circuit.
Tap the starter with a hammer and try the key again. Worked last week on my f150. has worked on my VWs too.
Thats a good looking remote starter. Mines down to two wires and some alligators. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Sat Jan 12, 2019 7:54 am Post subject: Re: Igntion Problem - 1980 vanagon westfalia |
With the blade of a screwdriver, you can jump from the big B+ lug on the starter solenoid (the one with all the wires on it) to the male spade with the red/white wire on it (remove the wire from the spade first) and the starter should slam the drive into the action and scare the crap out of you. Make sure the P-brake is on, the tranny is in neutral, and the wheels chocked so that you don't get yourself run over. The key needs to be in the ON position for the engine to start.
Making up an 8 inch long 10 gauge jumper with a female spade on one end can make this job easier and safer. Install the female spade on to the male and then touch the other end of the jumper to the big lug.
I just pulled the starter out of my 83 1/2 on Thursday and lubed the solenoid plunger with Super Lube, we will see over the years how well Super Lube does here. |
