DanHoug Samba Member
Joined: December 05, 2016 Posts: 5754 Location: Bemidji, MN
Posted: Sun Apr 28, 2019 4:42 pm Post subject: spline repair: JB Weld + carborundum |
this might be useful to some... needed to fix the splines on a Polaris Ranger driveshaft that had stripped out completely due to rust, you could turn the driveshaft without resistance when it was mated to the output shaft of the differential. so really stripped.
the driveshaft and differential shaft were both spendy and difficult to locate so i tried a no-cost fix that is no harm done if it doesn't last, if the fix strips out again, i'll pull it apart and replace both the output shaft and driveshaft.
onto the fix... i wanted to create interference between what little was left of the splines on each part to 'lock up' the two. carborundum is 9 hardness on the MOHS scale, diamond being 10 so i thought that would make a good filler. mixed up enough carborundum i had on hand with JB Weld to make a slurry that resembled concrete. wetted both output shaft and driveshaft and then mated them together. the grit filled the stripped splines enough to lock the shaft and the JB Weld might hold it all in place for a while. it should be noted that these splines are for a NON sliding solid axle driveshaft.
after curing, took it for a test drive and it is holding so far. next time, i'd use 3M DP-460 epoxy and carborundum as it is about 4x stronger than JB Weld but i didn't want to wait for a delivery of it. also, Loctite 660 is getting very good reviews for spline repair
https://www.henkel-adhesives.com/us/en/product/retaining-compounds/loctite_660.html _________________ -dan
www.thefixitworkshop.com |
jimf909 Samba Member
Posted: Sun Apr 28, 2019 6:28 pm Post subject: Re: spline repair: JB Weld + carborundum |
Brilliant! Do you think this will fix a worn rear drive spline on an ‘77 R100?  _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8427 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Apr 28, 2019 8:00 pm Post subject: Re: spline repair: JB Weld + carborundum |
jimf909 wrote: |
Brilliant! Do you think this will fix a worn rear drive spline on an ‘77 R100?  |
since you need to be able to get the rear tire off the drive splines, i'd try it with the 3M DP460 but use Saran Wrap or aluminum foil on one side so it doesn't bond the wheel to the hub. but having the hub rebuilt is way better! _________________ -dan
Posted: Sun Apr 28, 2019 8:12 pm Post subject: Re: spline repair: JB Weld + carborundum |
djkeev wrote: |
Interesting fix but I doubt it will deliver long term service.
There is simply too much torque on a drive shaft for a glue product to last very long.
It is fascinating what people have lying around, a jar of sandpaper 80 grit?!?
Dave |
this is a total experiment. i'm going to start looking for deals on the replacement parts while the clock ticks. but with the grit in there, even WHEN the JB Weld cracks, it still contributes to the interference fit. had a long argument with a friend over beers about doing this... he wanted me to try it as all that would be lost was time and a porketta we cooked in the garage, i wanted to spend the $400 for parts and fix it for good. the beer won. he promised he'd come back to help put the right parts in provided there was more beer and porketta.
yeah, that jar of carborundum looks like it is from the 1950s. could never throw it out. _________________ -dan
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Mon Apr 29, 2019 7:38 am Post subject: Re: spline repair: JB Weld + carborundum |
I like it!
So many people will tell you that it will not work, but will not try. I look forward for the results of this butchery. Is there a pool on how long it will last? |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1520 Location: Wisconsin
Posted: Mon Apr 29, 2019 1:21 pm Post subject: Re: spline repair: JB Weld + carborundum |
DanHoug wrote: |
this is a total experiment. had a long argument with a friend over beers about doing this... he wanted me to try it as all that would be lost was time and a porketta we cooked in the garage ... |
We shall never know how many great historical discoveries of science and technology were born thusly ... _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Sat Aug 10, 2019 5:05 am Post subject: Re: spline repair: JB Weld + carborundum |
well... splines are still holding! the experiment continues. We now return you to your regular programming. _________________ -dan
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sat Aug 10, 2019 8:39 am Post subject: Re: spline repair: JB Weld + carborundum |
Hey, that's a great experiment. I've done a few less outlandish things with JB Weld and it's kinda fun to play with modern epoxies and physics to see what's possible. I carry it on remote trips and would not hesitate to use it in a component failure to get home, etc.
Well done. Once you have the new part(s), you should subject it to normal operating torque and see what it takes to fail it, providing you don't put other components at risk. Bravo! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Fri Aug 30, 2019 12:25 pm Post subject: Re: spline repair: JB Weld + carborundum |
well, the experiment is over! axle splines finally spun out as i was bringing a load of campfire wood up some steep steps with the Ranger. yes, it goes up steps just fine and yes, it is a good torque load on all parts as the tire climbs the vertical face of the step.
so. i'd say the JB Weld plus carborundum is a good temporary repair but for the long haul, you need new steel. onward! _________________ -dan
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24009 Location: NYC/Upstate/ROW
Posted: Fri Aug 30, 2019 6:05 pm Post subject: Re: spline repair: JB Weld + carborundum |
April to August isn’t a temporary repair , you just need more JB weld. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Fri Aug 30, 2019 6:47 pm Post subject: Re: spline repair: JB Weld + carborundum |
I know, I was the skeptic.
I thought it wouldn't hold and it turns out I was right..... admittedly it lasted far longer than I thought it would.
I dislike glue, adhesives, epoxies........ why?
My Grandfather.
He was born in the 1800's and watched technology explode and blossom as a young man.
He drove an electric car in 1919, worked for Thomas Edison who sent him to England to introduce the talking movie to the King, wired the Holland Tunnel in NYC, etc
In the 1950's and 60's he was enamoured with plastic ........ and glue.
He had the glue pot with the brush, he purchased any new tube of magic goo that hit the market and he glued EVERYTHING!!!!
Most of it failed if it ever held at all. Brown gobs oozing out of "repaired" products.
I determined as a child that I absolutely hated glue.
And I still do today. Most of it fails to work or fails to bond shortly after application, nothing has changed.
Any chemical goo just doesn't excite me. Yes, I have a drawer full of various goos, I try them and am almost always disappointed. (Except for wood glues)
Any concoction will fail, it's been proven to me.
Anyway....
Great experiment you did but sadly with the expected results!
Ghia
Vanagon
Beetle
Posted: Fri Aug 30, 2019 6:54 pm Post subject: Re: spline repair: JB Weld + carborundum |
Next time we hit the woods We can glue together, too. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
4Gears4Tires Samba Member
Posted: Fri Aug 30, 2019 6:59 pm Post subject: Re: spline repair: JB Weld + carborundum |
Don't forget leather. You can bond that stuff so well it'll never come apart. Good porosity on both materials. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1735 Location: Budapest Hungary, Europe
Posted: Fri Aug 30, 2019 11:17 pm Post subject: Re: spline repair: JB Weld + carborundum |
It sounds a good bush repair. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 601 Location: Scappoose, OR / Oakland, CA
Posted: Fri Aug 30, 2019 11:20 pm Post subject: Re: spline repair: JB Weld + carborundum |
Abscate wrote: |
April to August isn’t a temporary repair , you just need more JB weld. |
Hell, April to August is longer that an EMPI axle assembly will last. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Posted: Sat Aug 31, 2019 12:18 am Post subject: Re: spline repair: JB Weld + carborundum |
ledogboy wrote: |
Abscate wrote: |
Hell, April to August is longer that an EMPI axle assembly will last. |
Twice as long as any URO rubber part that’s sees oil _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Sun Sep 01, 2019 6:27 pm Post subject: Re: spline repair: JB Weld + carborundum |
new steel ordered for $412. differential output shaft and a drive shaft. labor cost is beer + porketta for the garage oven. _________________ -dan
drip Samba Member
Posted: Mon Sep 02, 2019 1:23 am Post subject: Re: spline repair: JB Weld + carborundum |
This time drill and tap for a grease fitting...no more rust 😏 |
