jsstevenson Samba Member
Posted: Thu Jul 11, 2019 4:30 pm Post subject: Aftermarket Rim Tire Size? |
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130 lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated |
Joined: December 28, 2016 Posts: 311 Location: atlanta ga
Posted: Fri Jul 12, 2019 8:06 am Post subject: Re: Aftermarket Rim Tire Size? |
you can count on 165x15 fitting but maybe 195/65x15 would fit. You would have to try them before buying. This larger size would easily fit on stock 914 wheels with the 23mm offset. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1992 Location: FL Panhandle
Posted: Fri Jul 12, 2019 12:53 pm Post subject: Re: Aftermarket Rim Tire Size? |
I had 185/70x15 Michelin XAS on my 914 - that size is hard to find now. 185/65 x 15 is nearly an inch less in diameter so probably too small. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23002 Location: Oklahoma City
Posted: Sat Jul 13, 2019 7:03 am Post subject: Re: Aftermarket Rim Tire Size? |
195/65 and 195/60....that second one being a little rare....both fit the rim perfectly. I do not know whether they fit under the fenders correctly. 205/60 and 205/55 also both fit the rim with no issues.
I will have to check my cheat sheet.....but 195/65 and 205/55 are the closest in circumference to stock.
IMHO.....there is no value in going to a wider tread AND keeping high profile sidewalls......so keeping a 70 series just means it gets even taller. Ray |
