Fuel Tank Sending Unit
Ian
Ian is offline
PostPosted: Mon Oct 28, 2019 6:14 am    Post subject: Fuel Tank Sending Unit Reply with quote
Has one used one of the newer replacement fuel tank sending units for late model Bay? Does it read right on your Bus?
I put almost a full tank in a Bus with a new sender and the gauge only reads 1/3 full.
I think the knock-off sender might be the culprit.
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Mon Oct 28, 2019 6:44 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
I've installed an newer replacement fuel tank sending unit. I just filled up for the first time since installing it, too. Tank reads a little over 1/2 full with approximately 11 gallons.
I read recently that the gauge on the dash has a little fuse thing inside of it. I don't remember the thread off the top of my head, but good luck!
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
WildIdea
WildIdea is offline
PostPosted: Mon Oct 28, 2019 6:55 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
I put a newer sending unit in my 77 two years ago. It reads 3/4 when full and when the needle hits the red reserve area I can add around 7 gallons, so still plenty of fuel in the tank. It’s some indicator though and I have even living with it the way it is.
1977 Sage Green Westy
https://www.thesamba.com/vw/forum/viewtopic.php?t=691987
1965 SWR Walk-Through Standard
1960 211 Panel American Camper Conversion
Zed999
Zed999 is offline
PostPosted: Mon Oct 28, 2019 8:38 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
I fitted one last year and it reads correctly.
Poor connections add resistance and make them under read. There's one you might not be aware of in the tank compartment to the right, before the wire exits to the main loom. Not easy to get at.
SamboSamba22
SamboSamba22 is offline
PostPosted: Mon Oct 28, 2019 8:50 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Clean up your grounds. The resistor in the gauge cluster needs clean connections to compute correctly with the sender. There isn't a lot of resistance in the system, so a little dirt can change more than one would believe.
Good luck.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Daverham
Daverham is offline
PostPosted: Mon Oct 28, 2019 9:08 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Yes, they (can) work.
Check the ohms.
And watch how you install it... the float has to be able to float all the way up to the top. I positioned mine so that the arm & float are pointing 90-degrees to the left (driver's side). Watch out for that last 1/8 turn as you dog it into place. You'll want it positioned a little aft of that before you lock it in so that it's at 90-degrees when it's locked down. If you don't do that, the float can get stuck on the side of the tank, it won't go all way up and you'll get that 2/3 reading. I've done it myself, and then fixed it easily by repositioning the arm/float.
Make sense? Then it should work.
And of course, by all means, check your connections.
secretsubmariner
Champagne Wrangler
PostPosted: Tue Oct 29, 2019 9:19 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Excellent input Daverham. To this day I am still in awe of your $1 fuel sender repair.
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
SGKent Premium Member
SGKent is offline
PostPosted: Tue Oct 29, 2019 9:49 am    Post subject: Re: Fuel Tank Sending Unit Reply with quote
There is no year mentioned for you bus so the question can't be answered without knowing that. The late senders typically need to be adjusted to read properly. This is done with an empty tank, preferably with CO2 in it to avoid an explosion from a static spark.
George Carlin:
Skills@EuroCarsPlus:
Mispeld
Mispeld is offline
PostPosted: Tue Oct 29, 2019 6:45 pm    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Check the ohms.
What Daverham said.
I installed a new sender about 3 weeks ago and read just under 3/4 tank when full. It was reading 70 ohms when I bench tested it before I installed it. My old unit would only read 1/4 and full, so I figured my electrical was fine. The weekend before last we made a 130 mile trip and it was smelling like gas bad. Tonight I removed the firewall and checked everything. I thought maybe I disturbed the filler neck hoses when I had my tank out. I used my electronic leak detector for hvac refrigerant and found the sender leaking fumes. I was able to pull the sender through the pie hole and gently tapped the flanges with a hammer and punch to make it fit more snuggly in the tank. I also noted that the wire connections were not 90° with the float arm. I used a paint pen and marked the top of the sender so I knew the position when I reinstalled it. From the looks of it, I do beleive the float was being stopped on the side of the tank. Hopefully it works now and the fuel smell goes away. Nobody likes a wife that complains about the smell of fuel on a rainy day for 130 loooong miles. Sad
I know this is more info than you asked for - just sharing my experience with a new sender if you happen to smell gas too.
Tom
1977 Westy. 2.0 Fuel Injected.
Ian
Ian is offline
PostPosted: Wed Oct 30, 2019 12:07 pm    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Vehicle in question is a "late model Bay" as stated in first post. 1979 year model to be exact, but I think the sender is from 73 to 79.
I dinked with everything til I was blue in the face. Put a VDO sender in and problem solved.
I would recommend everyone to avoid all no-name replacement senders in the future.
SGKent is offline
PostPosted: Wed Oct 30, 2019 12:48 pm    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Usually the "new" VDO senders with a white float read about 1/4 lower than full when the tank is full. If you found a new VDO sender with a black flat-topped float you need to buy a lottery ticket or what ever they have for lotteries down under.
George Carlin:
Wildthings
Wildthings is offline
PostPosted: Wed Oct 30, 2019 1:27 pm    Post subject: Re: Fuel Tank Sending Unit Reply with quote
Agreed, my VDO sender didn't read remotely correcty when new and took a lot of custom bending of the limit taps and arm to make it marginally acceptable.
