gaspo13 Samba Member
Posted: Thu Dec 19, 2019 4:17 pm Post subject: Weber Progressive Carb |
Would I be accurate in identifying this as a Weber “progressive” carb? Removed it from a non running T4 1.8.
I’m looking to switch back to a dual carb set up bc of the info I’ve read about this carb on a T4. Is it worth selling this carb to someone else and what vehicle(s) would benefit from this carb?
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52918 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 19, 2019 4:30 pm Post subject: Re: Weber Progressive Carb |
Yes, Weber progressive 32/36 DFAV, at least it's not a Chinese knockoff.
gaspo13 wrote: |
what vehicle(s) would benefit from this carb? |
Something watercooled, it's a real challenge to make one of those work well on an air cooled flat 4, it's not impossible though, read this: https://www.thesamba.com/vw/forum/viewtopic.php?t=217070
Duals are a big improvement, but if you are only using it for Sunday cruises you may be better off making that one work. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7872 Location: Videbaek Denmark
Posted: Thu Dec 19, 2019 4:53 pm Post subject: Re: Weber Progressive Carb |
Yes. That carb set up has no bearing on a type 4, maybe unless youre living in southern CA, Texas or similar.
The carb can be used on a type 1 with the correct manifold, or maybe someone with a GM Monza in need of a replacement carb. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1642 Location: Buford GA
Posted: Thu Dec 19, 2019 6:37 pm Post subject: Re: Weber Progressive Carb |
I have a progressive carb set up for my Beetle and I WILL make it run good. I spent about 10 years heavily involved in the SCCA and have used these carbs on everything from 1300CC to 2600CC. They all performed great. Yes these were inline 4s.
The first thing I will fab up for mine is an enclosed air filter that I can duct very hot air to. I think it will do wonders. The type 1 progressive intakes already have ex heat for the center section. |
Posted: Thu Dec 19, 2019 7:09 pm Post subject: Re: Weber Progressive Carb |
Sounds good, you can make a prog work on a ACVW quite well, but it's not just a "bolt on" deal like the outfits that sell them claim, if you don't mind some tinkering and experimentation you can make it work in most cases.
If you like the challenge go for it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4168 Location: Georgia
Posted: Thu Dec 19, 2019 7:19 pm Post subject: Re: Weber Progressive Carb |
gaspo13 wrote: |
I’m looking to switch back to a dual carb set up bc of the info I’ve read about this carb on a T4. Is it worth selling this carb to someone else and what vehicle(s) would benefit from this carb? |
Yes, it is a Weber Progressive.
Yes, I would offer it up to a type 1 and go with duals.
I almost want it just for nostalgia.
I ran one for several years on a 1915 and loved it!
Got 32 mpg from Tampa to Atlanta. Never really kept up with it for daily life though.
I still have a rebuild kit for that with a needle and seat in my pile-o-parts. _________________ Volkswagen!
(Compression 8.7:1) |
