Type 34 type 1 engine ??
twistedbug
twistedbug is offline
PostPosted: Sun Dec 29, 2019 12:57 pm    Post subject: Type 34 type 1 engine ?? Reply with quote
I see type 3 engines and type 1 engines in ghia's, Will a stock type 1 engine fit
in a type 34 ghia engine compartment, just not sure if the engine cover will close.
W1K1
W1K1 is offline
PostPosted: Mon Dec 30, 2019 8:40 am    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
you need the type 3 engine tin and fan assembly for it to fit. Putting a T1 cooling system in a type 3 will shorten the life because it won't cool properly, and it's a hack that will affect the value of your car.
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
twistedbug
PostPosted: Mon Dec 30, 2019 11:04 am    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
i just need it temporarily just to move around the property, I just didn't know if the engine compartment lid would close, I don't have the car yet. it will be here next week
Bobnotch
Bobnotch is offline
PostPosted: Mon Dec 30, 2019 2:28 pm    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
The engine hatch lid can't be used with a normal stand up fan T-1 engine in ANY type 3 or T-34. I'm not sure IF the rear trunk lid will close with a T-1 engine in a T-34 either, as the rear trunk isn't very tall.
You'd be better off converting the t-1 engine to t-3 cooling configuration, then it'll fit.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Dec 30, 2019 2:52 pm    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
I guess if you are just moving it around your property and don't mind the hatch removed and the decklid propped up securely (so it doesn't tweak the hinges) then it will work for short drives before it gets hot.
Erik G
Erik G is offline
PostPosted: Mon Dec 30, 2019 2:56 pm    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
for that matter, you could leave the fan shroud off all together if it's a quick start, drive for 30 seconds or so, and shut down. Drag racers do it all the time, I've broke in motors with no head tins...
twistedbug
PostPosted: Mon Dec 30, 2019 3:16 pm    Post subject: Re: Type 34 type 1 engine ?? Reply with quote
I have a type 3 engine coming, just need to go through it, I already have 3 dubs I gotta push.
