Cold temperature transmission fluid
Honuak
Honuak is offline
PostPosted: Sat May 16, 2020 10:48 am    Post subject: Cold temperature transmission fluid Reply with quote
Things have warmed up now and shifting is great but this past winter was extra cold, even for here (Anchorage Alaska). All shifting components have been replaced with new/rebuilt and I have all the RS fab parts too, summer shifting is great. Cold temp shifting is very bad/stiff, it gets better after driving a bit but still very stiff. After confirming that all components are in good working order and lubricated I'm now thinking that I could change out my trans fluid for the winter or perhaps find the right fluid that would work year round. I'm not sure what fluid is in there now, but whatever it is it could be the wrong stuff for cold temps. Any advice including constructive criticism welcome.
SAMBA!
MarkWard
MarkWard is offline
PostPosted: Sat May 16, 2020 10:57 am    Post subject: Re: Cold temperature transmission fluid Reply with quote
Without turning this into a lube thread argument, you could swap fluids fall and spring. You can actually reuse the fluid after it settled out over the winter. Plus you can keep an eye on your magnet.
I'm using Swepco 210 in my 2wd vanagon. I am experimenting with another lube in my Syncro transaxle. We don't get extreme cold down here. The problem is any lube that might help lubricate gear faces and bearings is competing with the syncronizer rings which like a thinner fluid to assist in grabbing the gear during shifts.
The thinner the oil, the smoother shifts in cold.
DanHoug
DanHoug is offline
PostPosted: Sat May 16, 2020 5:42 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
living in northern MN where we hit -40F each winter, not that i drive the van at that temp, i really like the Swepco 202 i'm using for cold weather performance.
-dan
www.thefixitworkshop.com
dobryan
dobryan is offline
PostPosted: Sat May 16, 2020 6:37 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
I also like the 202 but we do not get the extreme cold here.
Dave O
The Western Syncro build
rmcd
rmcd is offline
PostPosted: Sat May 16, 2020 7:23 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
I’m using 210 in the pacific nw and it sucks trying to shift into second gear in the morning when it is 55’. I will be dumping it soon.
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
dobryan
dobryan is offline
PostPosted: Sat May 16, 2020 8:27 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
I had 210 before the 202 and had the same issue.
Dave O
Honuak
Honuak is offline
PostPosted: Tue Oct 20, 2020 1:24 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
Its that time of year.
Van has the full RS FAB - from shifter all the way back to the trans.
Shift VERY well in summer. Shift not at all when cold. I don't know what fluid is in there. It had a flush a few years back, local shop probably put in the manufacture recommended dino oil.
Tempted to try the thinnest SWEPCO (201?)...but interested in alternatives.
Read someplace that straight 30W is an option if changed out again in spring.
Thoughts?
Wildthings
Wildthings is offline
PostPosted: Tue Oct 20, 2020 1:59 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
Just fill it with synthetic ATF during the winter, which is what VW called for, at least at times. ATF+4 even carries a GL-4 rating, IIRC.
Pcforno
Pcforno is offline
PostPosted: Tue Oct 20, 2020 7:41 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
I can attest 202 works great down to -10 F
201 was not good even at 20 F
syncroserge
syncroserge is offline
PostPosted: Tue Oct 20, 2020 8:11 pm    Post subject: Re: Cold temperature transmission fluid Reply with quote
Swepco is not bad in the cold. But the problem I find further north is the number of days of lower than 0 F.
Even a small inconvenience becomes a big one if you drive it daily or regularly for months in that kind of weather.
I like the Mobil Delvac 75W90 a lot.
I spend most summers crisscrossing the continent, ending up in New Mexico for weeks in 100 F temps.
Then drive home to months of below 0 F where I drive it regularly.
All that with a modified TDI doing the pushing. Change it every year..almost nothing on the magnet..very satisfied.
