Snoopy1971 Samba Member
Joined: May 15, 2020 Posts: 329 Location: Parkville, Maryland
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79647 Location: Sneaking up behind you
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 828 Location: Downriver, MI
Posted: Mon Aug 31, 2020 6:13 pm Post subject: Re: Which Fuel Filter? |
If you're lucky enough to have a Mom & Pop autoparts store, this HASTINGS is a staple item. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
joaniebo Samba Member
Joined: July 26, 2010 Posts: 23 Location: Crystal Lake, IL
Posted: Mon Aug 31, 2020 6:22 pm Post subject: Re: Which Fuel Filter? |
In 1969 or 1970, I installed one of the Mann WK31/2 Filter in my 1968 MGB and since getting my 68 Beetle in 1986, there's also been a Mann WK31/2 Filter in it.
Never have had a problem with that filter in either car, |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11793 Location: Redding, CA
Posted: Mon Aug 31, 2020 6:53 pm Post subject: Re: Which Fuel Filter? |
Get the one from Jbugs—if it has the flat can inside the the filter screen. Those are probably the ones made in Israel, and I’ve used them for years without any issues.
Perhaps these aren’t as good as the tin-can suggestions, but I, too, like to see inside for rust, etc.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Glenn  Mr. 010
Posted: Mon Aug 31, 2020 6:56 pm Post subject: Re: Which Fuel Filter? |
Tim Donahoe wrote: |
Tim |
My filer is under the car so kinda hard to see.
And if you have a rust issue.... remove, clean and seal the tank. No more rust issue. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33147 Location: Hot Arizona
Posted: Mon Aug 31, 2020 7:30 pm Post subject: Re: Which Fuel Filter? |
Snoopy1971 wrote: |
Ok so what fuel filter does everyone use? |
My 1835cc engine has a single Weber 40DCNF with small jets, so I use an all-metal filter similar to what Glenn showed in his post above.
My 1970 with 1600cc DP engine has only its screen in its fuel pump and a filter sock inside the fuel tank - like VW designed it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Aug 31, 2020 8:46 pm Post subject: Re: Which Fuel Filter? |
Glenn, my filters are also under the car: one under the fuel tank, and another by the transmission.
And I don’t have any rust in my fuel tank, but if and when it occurs, a clear filter is easier for me to observe any contaminants—even if they’re under the car.
I could pull my gas tank just to check for rust, say once every two years, but that seems like a hassle that I can avoid simply by looking at my fuel filter which is under the tank.
Richard O'Brien |
Ovally Samba Member
Posted: Tue Sep 01, 2020 12:08 am Post subject: Re: Which Fuel Filter? |
Recently I bought a number of fuel filters from Mahle, type is KL13 / Made in Austria.
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Maddel Samba Member
Posted: Tue Sep 01, 2020 12:39 am Post subject: Re: Which Fuel Filter? |
Ovally wrote: |
Recently I bought a number of fuel filters from Mahle, type is KL13 / Made in Austria. |
I use these too. |
Posted: Tue Sep 01, 2020 3:49 am Post subject: Re: Which Fuel Filter? |
So in the 4 links I posted above, are they all the same filter, just sold 4 diff places, or are any of them not the junky chinese ones ppl say to stay away from? |
Posted: Tue Sep 01, 2020 3:53 am Post subject: Re: Which Fuel Filter? |
Ovally wrote: |
Regards. |
Where does one get one of these?
I had one that looked similar in my bug when I got it, but since removed it because I like the clear one to be able to see any particulates. I still have the one I removed, not sure if its the same one, it looks exactly the same except without the printed markings in it... I'll have to take a look at it. |
Ovally Samba Member
Posted: Tue Sep 01, 2020 6:04 am Post subject: Re: Which Fuel Filter? |
Don't know where in the USA, in Europe we have several Mahle suppliers.
Try to find a company in the USA that supplies Mahle products.
The fuel filter KL13 is listed in de USA catalog.
https://catalog.mahle-aftermarket.com/na/product.xhtml?eid=184>=KL+13+OF
VW Bug 1200 D motor
Glenn  Mr. 010
beetlenut Samba Member
Posted: Tue Sep 01, 2020 6:22 am Post subject: Re: Which Fuel Filter? |
I've been using the NAPA Gold filters which are made by WIX. They have a plastic see-through one that filters down to 7 microns. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
frenchroast Samba Member
Posted: Tue Sep 01, 2020 7:26 am Post subject: Re: Which Fuel Filter? |
The only filter I use is the stock cone screen in the fuel pump and the tank sock. Works just fine. When I restore the tank, I may consider a steel filter alongside the transaxle but that's just another point to leak, fail, maintain, etc. |
Zundfolge1432  Samba Member
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Wed Sep 02, 2020 4:04 pm Post subject: Re: Which Fuel Filter? |
I have been running these for years with success...
Napa Gold 3001. Should be the one in the photos with the super small inlet and outlet for a car, but yea nice size filter you can see.
I was told by a builder, after new tank, rubber lines, cleaning of metal line, to go no more than 6,000 on one... This is to be routine and for preventative maintenance... RB
https://www.napaonline.com/en/p/FIL3001
p.s. I had no issues with a 2110 and two of these filters before the Single IDF Carb. And with my Dell filter's in the carb, no issues as of yet.... On a 2180. _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Wed Sep 02, 2020 5:45 pm Post subject: Re: Which Fuel Filter? |
This builder says it could go longer than 6k |
