kangaboy Samba Member
Joined: August 28, 2010 Posts: 1064 Location: St. Louis, Mo
Posted: Sun Sep 27, 2020 8:03 am Post subject: Flanged Main Bearings from CB |
How are these superior to standard bearings and what is their application (street/strip/daily)? Are they worth the almost 4x price of standard mains?
https://www.cbperformance.com/product-p/1845.htm _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out  |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Sun Sep 27, 2020 8:13 am Post subject: Re: Flanged Main Bearings from CB |
They aren’t simply a replacement stock size bearing set. They have a very specific use for a flanged crank with Type 4 main journals in an unmachined standard linebore case. The other more common way was to take two sets of standard Type 4 bearing sets to create the two piece flanged bearing, then have the case line bored to accept the larger Type 4 bearing. Comparing prices to their counter parts are about the same, but there isn’t the additional machine work to the case needed. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3509 Location: Charleston, SC
Are you running a flanged crank? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Sun Sep 27, 2020 8:21 am Post subject: Re: Flanged Main Bearings from CB |
[email protected] wrote: |
They have a very specific use for a flanged crank with Type 4 main journals in an unmachined standard linebore case. |
Awesome, thanks for the response. I never heard of them before, so was just asking about their general application.
Stripped66 wrote: |
Are you running a flanged crank? |
Nope, so now I don't need to worry about using these. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3668 Location: Sarasota, in my adopted state of Florida
Posted: Sun Sep 27, 2020 10:49 am Post subject: Re: Flanged Main Bearings from CB |
Makes me think 🤔 CB is going to start selling flanged cranks SOON. Dan |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1872 Location: Grass Pants, Orygun
Posted: Sun Sep 27, 2020 11:32 am Post subject: Re: Flanged Main Bearings from CB |
Dan Ruddock wrote: |
CB had flanged cranks in their booth at Sacramento Bugorama 4 or 5 years ago and had wondered why they haven't been selling them. I would assume bearing supply was the main issue. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/ |
Posted: Sun Sep 27, 2020 11:38 am Post subject: Re: Flanged Main Bearings from CB |
stealth67vw wrote: |
CB had flanged cranks in their booth at Sacramento Bugorama 4 or 5 years ago and had wondered why they haven't been selling them. I would assume bearing supply was the main issue. |
The current Empi/bugpack should be available to CB also. Wish a Porsche journal version was produced. Dan |
Posted: Sun Sep 27, 2020 6:36 pm Post subject: Re: Flanged Main Bearings from CB |
The main issue with a flanged crank is the cost. That’s why Empi contacted Revmaster to start making the ones they used to do for Bugpack again. Empi has them listed for a little over $1500 for a crank/flywheel. That’s a bargain compared to the $2200+ the Scat ones are up to. And you don’t want to know what the Pro-Stock/Pro-Mod cranks are going for.
CB definitely is an innovator in creating something to fill a market void, or make performance stuff more available to the common hobbiest. With everyone complaining about aluminum rod bearings, they should of had King make some tri-metal VW/Chevy journal bearings. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
SLAKKER Samba Member
Joined: August 11, 2010 Posts: 56 Location: SOUTH AFRICA
Posted: Mon Sep 28, 2020 1:34 pm Post subject: Re: Flanged Main Bearings from CB |
On the flanged crank how do the seal work is there a pic
of the crank in a block somwhere , haven't seen one in a block
yet |
Posted: Mon Sep 28, 2020 2:53 pm Post subject: Re: Flanged Main Bearings from CB |
SLAKKER wrote: |
yet |
The seal rides on the outer diameter of the rear flange section of the crank, as opposed to riding on the flywheel. The flanged seals are larger in diameter than a stock VW one, so the case needs machined for the seal.
Dauz Samba Member
Posted: Mon Oct 12, 2020 9:34 am Post subject: Re: Flanged Main Bearings from CB |
I wound up buying these bearings. They're basically 411 adapters for standard type 1 mains. I opted out of doing the thrust conversion this time around since it is built into the bearing.
vw donvieira Samba Member
Joined: May 11, 2004 Posts: 629 Location: stockton, California
Posted: Mon Dec 26, 2022 10:16 pm Post subject: Re: Flanged Main Bearings from CB |
How is the crankshaft end play managed? I have a flanged crank and was going to have GEERS do the bronze bushing, but this seems reasonable alternative. _________________ "No Give Up" |
