VW cylinder jug beer stein
Cowboyroy45
Cowboyroy45 is offline
PostPosted: Thu Mar 11, 2021 9:31 am    Post subject: VW cylinder jug beer stein Reply with quote
So, I’m not sure if this has ever come up before, but has anyone ever made a beer mug/stein out of a cylinder jug? I’ve got a rusty one that came from a buddy of mine and I was thinking about bead-blasting it, carefully welding a bottom onto it, and possibly a top and handle as well. I suppose my question is, has anyone ever done it before, and what can be done to ensure it would be safe to drink from?
mark tucker
mark tucker is offline
PostPosted: Thu Mar 11, 2021 9:54 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
shit thats eazy...make it out of ceramic. I have the old holly bug spray coffie mugs, cylinder mug should be eazy to do. and make it is a rust color Wink .
jeffrey8164
jeffrey8164 is offline
PostPosted: Thu Mar 11, 2021 5:09 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
If you can pull it off, I’m gonna send you a 94mm barrel.
I like big beers and I can not lie.
You other brothers can’t deny...
Make up your own lyrics from there I suppose.
How much beer does an 85.5 hold?
I bet if you put it in the freezer or a cooler it would help keep your beer cold longer.
Maybe I missed it but what to do to prevent rust on the inside? POR 15?
Mark, Are you talking about a ceramic coating of some sort?
Am I an idiot? Is POR 15 a ceramic coating or more of an epoxy?
Volkswagen!
(Compression 8.7:1)
my59
my59 is offline
PostPosted: Thu Mar 11, 2021 8:48 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
Weld on a bottom and a handle, get it triple plated chrome!
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
YDBD
YDBD is offline
PostPosted: Thu Mar 11, 2021 10:22 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
I would think a glass insert would be the way to go.
Just head to Walmart with your jug and find the glass that fits inside. You will look crazy but it's Walmart...
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
Mispeld
Mispeld is offline
PostPosted: Fri Mar 12, 2021 4:48 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
I almost spit my coffee out.
Might need to use this as a sig line. Cool
Tom
1977 Westy. 2.0 Fuel Injected.
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Fri Mar 12, 2021 6:20 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
Probably would be a good idea to insulate the beverage from the cylinder walls. Direct contact with a deeply finned cylinder will most likely result in a room temperature beverage very quickly. Wink
Does sound like a fun mug though, there are coffee mugs available that look like zoom lenses for the photographer crowd, so why not cylinder mugs for the gear heads.
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Fri Mar 12, 2021 6:36 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
This is my favoritest thread LOL
KTPhil Premium Member
KTPhil is online now
PostPosted: Fri Mar 12, 2021 12:11 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
Um, yeah, that's the whole idea, isn't it? LOL <dope slap to forehead>
mark tucker
PostPosted: Sat Mar 13, 2021 8:33 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
no, ceramic as in clay molded then fired with a glaze on it..no not a donut...and no not that glaze either. Shocked and no not moldy clay with moldy glaze~ whatever on it. Rolling Eyes
Ive never pored 15, 2 cups is about my limit.
Cusser
Cusser is offline
PostPosted: Sat Mar 13, 2021 9:07 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
Right, more displacement !!!
Cowboyroy45
PostPosted: Mon Mar 15, 2021 8:16 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
Sorry for the wait gents. Work has been quite hectic. My plan is to either weld a metal plate onto the bottom, or glue (JB Weld) it. I’m not sure how well a hardened cylinder jug would take to welding on mild steel. Any advice is appreciated. Afterwards, in order to ensure it’s safe to drink from, my plan is to have it Cerakoted. I will likely think up a lid and handle later down the road, but for now I just want a functional beer mug!
Bulli Klinik
Bulli Klinik is offline
PostPosted: Mon Mar 15, 2021 8:24 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
It's cast iron.
Mike K
Bulli Klinik
Colorado Springs
[email protected]
rohweder@hbci.com is offline
PostPosted: Mon Mar 15, 2021 12:42 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
You would have forearms like Popeye!
AirHead1966
AirHead1966 is offline
PostPosted: Tue Mar 16, 2021 11:27 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
If you have a 3D printer, you can print yourself a cylinder with a hole sized to accommodate a beer can. It would be like a beer cozy. You won't have to worry about lining it, etc. When empty, replace with a new can.
mark tucker
PostPosted: Tue Mar 16, 2021 1:12 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
now thats using your thinker!!!!
johnnyvw164
johnnyvw164 is offline
PostPosted: Wed Mar 17, 2021 1:03 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
Actually, there is someone who makes cupholders like that already, should be easy to use them as a coozy...
jeffrey8164
PostPosted: Fri Mar 19, 2021 3:18 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
I got some too. Painted black for better heat dissipation 😉
They’re actually 85.5mm and hold a Yeti coozie perfectly.
Somehow I don’t think any self respecting German would drink from a plastic stein.
Volkswagen!
(Compression 8.7:1)
mark tucker
PostPosted: Sat Mar 20, 2021 8:48 am    Post subject: Re: VW cylinder jug beer stein Reply with quote
I like those.
jeffrey8164
PostPosted: Wed Mar 24, 2021 3:52 pm    Post subject: Re: VW cylinder jug beer stein Reply with quote
So how are those gears turning?
Any ideas?
Volkswagen!
(Compression 8.7:1)
