Huskerbob Samba Member
Posted: Mon Mar 15, 2021 2:39 pm Post subject: Tire Size for a 63 with narrowed beam |
I'm new to Samba and not quite learned how to search very well so please excuse this question.
My wife has a 63 bug with a narrowed front beam (4" I believe) and it needs tires. At times when we are both in it I will hear it rub on the front right and I was wondering if I ran something smaller than the 165/80r15, let's say a 155, if that might help? I also wanted to ask which brand is a good brand. It has Nexen on it now and they seem fine they are just cracking on the sidewalls from age. |
shano63  Samba Member
Joined: October 06, 2006 Posts: 3617 Location: Stormville NY
Posted: Mon Mar 15, 2021 3:42 pm Post subject: Re: Tire Size for a 63 with narrowed beam |
I run 155/80s on my 63. I'm running a lowered beam, but stock width. I'm sorry I can't really help you with your first question, but I only run BF Goodrich tires on everything I drive. Mine rub the fender if I hit a good sized bump at "speed". I just put up with it.
_________________ 63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
VACP  Samba Member
Joined: July 16, 2020 Posts: 12 Location: Central Florida
Posted: Mon Mar 15, 2021 8:42 pm Post subject: Re: Tire Size for a 63 with narrowed beam |
What wheels do you have? Do you also have dropped spindles or just the adjustable beam? It also helps to know if the beam is 2” or 4” narrowed. A couple of pics might help.
Old school is going with a 135 or 145. Personally, I prefer a wider tire. You might try the 155 as mentioned or could try a lower profile 165 such as a 165/55.
Where type of wheel comes into play is the stock wheels are only 4” wide. Aftermarket are often 5.5 and many times the extra width is added to the outside of the rim. So backspacing is important to determine what will fit. |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
