Stop leak for a leaking power steering pump?
GWTWTLW
GWTWTLW is offline
PostPosted: Sun Aug 01, 2021 12:12 am    Post subject: Stop leak for a leaking power steering pump? Reply with quote
Has anyone had any success using stop leak for a leaky power steering pump? I know I need to replace it but I’m hoping to buy a little time…
Thanks!
Pete
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
Wildthings
Wildthings is offline
PostPosted: Sun Aug 01, 2021 2:20 am    Post subject: Re: Stop leak for a leaking power steering pump? Reply with quote
It's worth a try. The steering gear on my '91 was leaking a dozen years ago, and after adding fluid with a stop leak added it is dry today.
Abscate Premium Member
Abscate is offline
PostPosted: Sun Aug 01, 2021 5:17 am    Post subject: Re: Stop leak for a leaking power steering pump? Reply with quote
It will stop a seep, it won’t stop a drip or flow.
DanHoug
DanHoug is offline
PostPosted: Sun Aug 01, 2021 5:53 am    Post subject: Re: Stop leak for a leaking power steering pump? Reply with quote
i've had ONE success with stop leak in my life... one. old Mercedes PS pump, flinging oil from the shaft seal. tried ATP AT-205 and i'll be durned if it didn't slow, then stop. been fine for over a year now.
that same stuff, AT-205, did zilch on a crankshaft seal on a neighbor's car.
worth a try.
-dan
www.thefixitworkshop.com
kamzcab86
kamzcab86 is offline
PostPosted: Sun Aug 01, 2021 11:35 am    Post subject: Re: Stop leak for a leaking power steering pump? Reply with quote
GWTWTLW wrote:
I know I need to replace it ...
Dad & I resealed my Westy's leaky pump with this: https://www.autohausaz.com/catalog/c/vw/1990/12865...amp;page=1 . Leak-free ever since.
~Kamz Anxious
2016 Golf GTI S
GWTWTLW
GWTWTLW is offline
PostPosted: Sun Aug 01, 2021 1:01 pm    Post subject: Re: Stop leak for a leaking power steering pump? Reply with quote
It turns out it is actually the switch that’s leaking (although the pump has been weeping for a long time now). I threw some Lucas in to see if it’ll slow it down enough until I can find a replacement…
@gwtwtlw
