bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Fri Jan 07, 2022 6:15 pm Post subject: Elliptical resistance |
I have had this Schwinn elliptical for about 5 years so it's out of warranty. The problem I'm having is with the resistance. When you turn it on, it resets to the lowest setting like it's supposed to. Then you start start in the manual mode and everything works as it should. But when you start to add resistance, the motor works and it keeps cycling to all the way on then all the way off, continuously. You can turn it off and it goes back to the lowest setting. I've tried googling and about the only thing I know to do is replace the motor - or I may just take it to the dump.
I've tried turning it on and off multiple times.
I've tried unplugging it multiple times.
The motor works and varies the resistance but won't stop cycling.
I am using the manual mode, as I have always done so it's not a program problem.
The motor does not have an on/off switch.
Does anybody have any other thoughts?
_________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!!
Posted: Fri Jan 07, 2022 6:45 pm Post subject: Re: Eliptical resistance |
I should probably clarify further, I'm thinking if I have to replace something, it would be the motor control board. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
finster Samba Member
Joined: May 26, 2012 Posts: 10451 Location: not far from the madding crowd
Posted: Sat Jan 08, 2022 3:43 am Post subject: Re: Elliptical resistance |
is it possible to bypass the motor control board and rig up an on/off switch to the motor instead? _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sat Jan 08, 2022 5:59 am Post subject: Re: Elliptical resistance |
I don’t want to lose the variability of the resistance. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
Posted: Sat Jan 08, 2022 7:13 am Post subject: Re: Elliptical resistance |
I assumed you could do that by blipping the motor. _________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Sat Jan 08, 2022 12:12 pm Post subject: Re: Elliptical resistance |
Further research. They don’t make that motor control board anymore, of course. To the dump it goes. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53160 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jan 08, 2022 4:57 pm Post subject: Re: Elliptical resistance |
Maybe I'm missing something here, why does an exercise device need a motor?, isn't it all about soaking up energy produced by you?, why does it need a boost?
I'm not razzing anyone, just curious since IMO a power assist is a bit like cheating. Can't you just unplug it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3232 Location: Downingtown, PA
Posted: Sat Jan 08, 2022 6:10 pm Post subject: Re: Elliptical resistance |
| It's not power assist - it's inductive resistance to make it harder to turn the wheel. Of course, in the OP's case, I'd be tempted to simply hook the magnetic band to a rheostat to see if the resistance can be adjusted that way. |
Posted: Sun Jan 09, 2022 6:00 pm Post subject: Re: Elliptical resistance |
The motor moved the bank of magnets closer (to make it harder to pedal) or further away (to make it easier to pedal).
The elliptical is gone. I have been running a lot lately- I bought a Forerunner 55 and have been following a training plan which is incorporated into the watch. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71841 Location: Phoenix 602
Posted: Mon Jan 10, 2022 5:48 am Post subject: Re: Elliptical resistance |
Not really couch as I do Crossfit. But decided to start putting longer distance in - more than I get in Crossfit. My first one is a 10k end of February here in my hometown. Got another 10k in March and one in April. Trying to decide if I want to do a half in November. I've done several marathons and halfs in my past. It's just training during the summer months down south here is brutal with the heat and humidity.
Are you a runner? _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Abscate Samba Member
Joined: October 05, 2014 Posts: 24341 Location: NYC/Upstate/ROW
Posted: Mon Jan 10, 2022 6:09 am Post subject: Re: Elliptical resistance |
| bigdog1962 wrote: |
| Further research. They don’t make that motor control board anymore, of course. To the dump it goes. |
Sorry I missed this. If you sent me the board they can often be repaired by oldschiolers like me who had to read Horowitz and Hill in the 1970s (maybe 1980 early) _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Mon Jan 10, 2022 7:10 am Post subject: Re: Elliptical resistance |
any fuses? In the mean time, there are plenty of free weight exercises. _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
Posted: Mon Jan 10, 2022 9:25 am Post subject: Re: Elliptical resistance |
No fuses - the motor worked but just kept cycling.
I no longer have the elliptical.
I run and do crossfit so I'm good. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
