Drive gear pinion spacer question
pablovent
pablovent is offline
PostPosted: Sun Dec 04, 2022 1:50 pm    Post subject: Drive gear pinion spacer question Reply with quote
Hi;
In the photo you can see two crank timing gear spacers, 4mm and 3mm thick......they both do the same job?
My best regards
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Dec 04, 2022 2:36 pm    Post subject: Re: Drive gear pinion spacer question Reply with quote
Use the thicker one if you plan on turning more RPM then stock.
VW used the thinner one on later engines, cheaper? Less weight?
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
pablovent
PostPosted: Mon Dec 05, 2022 4:06 am    Post subject: Re: Drive gear pinion spacer question Reply with quote
Thank you!!
slalombuggy
slalombuggy is offline
PostPosted: Mon Dec 05, 2022 4:59 am    Post subject: Re: Drive gear pinion spacer question Reply with quote
If you plan on spinning your engine you should be leaving both those spacers in the spares bin and using a solid "racer spacer"
