My 95 Winnebago is running again. Tire Suggestions??
bcolins
bcolins is offline
PostPosted: Tue Jun 06, 2023 4:28 pm    Post subject: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
I got the call from the shop today that my 95 EVC is finally running on all 5 cylinders ($4,000 later)
The 195/70 15 Continental Vanco tires have some light side wall cracking,....the tread depth looks to be at 75% or better.
Thinking I would like to do something like the Falken Wildpeak A/T tires I put on my 2003 MV, but thought to check with you guys before moving forward.
I put one size taller and one size narrower on my 2003: 215/65-16" and they have worked out well. But with the 95 EVC having a 195 width, I don't know that I would want to go narrower.
So,....in addition to asking about tire recommendations, I am interested in hearing if anyone has gone with a taller tire.
Thoughts?
Brian in Austin
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Wed Jun 07, 2023 8:07 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
bcolins wrote:
So,....in addition to asking about tire recommendations, I am interested in hearing if anyone has gone with a taller and narrower tire.
Thoughts?
Brian in Austin
Congratulations on the van running again! That's great.
I have no commentary on different sizes, but will say that I've got Continental Vanco tires in the stock size on mine and they're great so far. Quiet, wearing evenly, basically doing what a tire should.
Joshwa
Joshwa is offline
PostPosted: Wed Jun 07, 2023 10:54 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
I’ve been running Nokian II, 215/65/16. Long tread life.
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
OB Bus
OB Bus is offline
PostPosted: Wed Jun 07, 2023 12:36 pm    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
You need load rating 102 minimum.
We have been very satisfied with Kumho Crugen, load rating 104.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
jjvincent
jjvincent is offline
PostPosted: Wed Jun 07, 2023 12:42 pm    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Go with a 215/65/16 tire size. It's extremely popular in Europe and there are many here in the US that have the 102 load rating. From my experience, the Nokian Rotiiva AT have been the best I have ever used on my EV. Good wear, do not get noisy over time, work in the mud and they are winter tires too. I liked them so much, my Jeep has them.
https://www.nokiantires.com/all-season-tires/nokian-tyres-rotiiva-at/
bcolins
bcolins is offline
PostPosted: Thu Jun 08, 2023 6:50 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Hey guys, if memory serves,.....thinking my 95 EVC has a 15" wheel.
jjvincent
PostPosted: Thu Jun 08, 2023 7:35 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Yes it does, but you can buy 16" wheels and then have a better selection to tires that meet the size and load rating. Upgrade now with a product that will futureproof itself as opposed to struggling with going with an old configuration.
mpilihp
mpilihp is offline
PostPosted: Wed Aug 23, 2023 9:05 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Hello so I didn't see a reply to the OPs comment about his 95 having 15 in rims.
I also have a 95, Winni Rialta camper and I am interested in going to 16s so can possibly install larger brakes.
Can someone explain the process to allow using 16 in rims at least in the front as the rear is different than a Eurovan.
Thank you. Phil
bcolins
bcolins is offline
PostPosted: Wed Aug 23, 2023 10:39 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Thank you. Phil
recommend you start a new thread rather than introduce a totally different topic into an existing thread about tires.
volkybus
volkybus is offline
PostPosted: Sun Sep 03, 2023 9:38 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Just remember if you go to 16 in Wheels or change to a larger than the stock 15-in wheels underneath where the tire spare tire goes, It will rub against the exhaust so caution ....mine caught fire with 205 's....it's very exciting and scary...so I have my spare tire in the back inside the van. it's a pain in the neck,but safety first... Some people put a rear swing away spare tire holder but it interferes with my everpresent bike racks...Id really like to put it in front like my Bay but I'm not sure with all the weight and airflow It will work...Good luck...Bill VT and PR
mpilihp
mpilihp is offline
PostPosted: Mon Sep 04, 2023 5:59 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
So rereading this thread as I also have a Winni Rialta as the OP does and I noticed people recommending tires with a lower load rating than what is required for the Rialta.
The Rialta requires a 104 in front and 109 load rated tire in the rear.
http://www.rialtainfo.com/winnebago/tires_&_wheels.htm
Hope the OP re reads this so he is aware.
Phil
bcolins
bcolins is offline
PostPosted: Mon Sep 04, 2023 7:46 pm    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Phil
Actually have an EVC not a Rialta
mpilihp
mpilihp is offline
PostPosted: Tue Sep 05, 2023 5:36 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Phil
OK just the title says Winnebago...
Phil
bcolins
bcolins is offline
PostPosted: Tue Sep 05, 2023 8:44 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Phil
Phil
Eurovan campers (EVC) were built by Winnebago
bcolins
bcolins is offline
PostPosted: Tue Sep 05, 2023 8:45 am    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Phil
Phil
mpilihp
mpilihp is offline
PostPosted: Mon Sep 11, 2023 5:02 pm    Post subject: Re: My 95 Winnebago is running again. Tire Suggestions?? Reply with quote
Phil
Phil
Didnt know that thanks!
