One Van Repair Shop in Seattle - any insights?
jimf909
jimf909 is offline
PostPosted: Wed Mar 13, 2024 5:13 pm    Post subject: One Van Repair Shop in Seattle - any insights? Reply with quote
I just came across One Van in the SoDo area of Seattle. Does anyone know anything about them? They're new to me but I don't get out much.
One Van is a small customer dedicated shop specializing in VW repair, restoration, and conversion.
A new shop concept based on two decades of experience.
25+ years specializing in Vanagon, Eurovan and Air-Cooled vans
https://www.onevanrepair.com
- Jim
Butcher wrote:
Guilty as charged.
do.dah
do.dah is offline
PostPosted: Thu Mar 14, 2024 1:55 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I think Casey might weigh in?
djkeev
djkeev is offline
PostPosted: Thu Mar 14, 2024 4:55 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
While it isn't a problem, my take away from his stated working model of keeping your Van at Your house until He has all of the parts and the time to fix it .......
Tells me he is a small operation, small shop, small lot, no place for vehicle storage.
Though I do think that he is either optimistic that he can order all of the parts that will be needed in one swoop ..... or he is ordering a lot of "maybe I'll need this" items. "It will be good to put in a new one anyway"
Do new rear axle bearings come with new bearing carriers too? You don't know the carrier is shot until it is in your hand.
Does he have a good parts department in house for these type of situations?
Ghia
Vanagon
Beetle
RicMcK Premium Member
RicMcK is offline
PostPosted: Thu Mar 14, 2024 8:09 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I would hightly reccomend Yori @ Shoreline Auto Clinic 206.922.3651.
Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window (first car)
58 split window bug - long gone.
jimf909
jimf909 is offline
PostPosted: Thu Mar 14, 2024 9:00 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
Vehicle storage is a challenge for these shops in a city. PeaceVans, about a mile away from this shop, has accumulated sizable shop and storage space but it's remarkable how close they pack the vans in their available space. Tight as sardines. Another Seattle shop ran into problems with the city when using public parking for storage of customer vans.
Regardless, it's good to see another shop available to work on Vanagons. It was a few years ago that PeaceVans said they were getting out of the vanagon maintenance business. They've since e-mailed (10/17/23) that they're servicing Vanagons again. Adding another service option may be good for Vanagon owners. Their advertised labor rate of $155/hr appears to be on the low side. I believe the last time I paid for service, 2020? 2021?, it was $185/hr.
- Jim
Butcher wrote:
Guilty as charged.
E1
E1 is offline
PostPosted: Thu Mar 14, 2024 9:06 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I know none of the players but think it’s cool to spread the word like this, Jim.
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
MikeB71
MikeB71 is offline
PostPosted: Wed Mar 05, 2025 1:15 pm    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I didn't have a good experience there with a Subaru conversion. They might know their way around a Vanagon really well. They did a fine job on my brakes.
But for Subaru conversions I think there are way too many factors involved to get it right. I had to go to another shop to try and fix a lot of things they did wrong.
DeLvxe
DeLvxe is offline
PostPosted: Thu Mar 06, 2025 10:58 am    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I've had a lot of experience there - they have been my main "have to take it to a shop for this" kind of work for probably 5 years. I am not sure where the comment about storage came from, but he has had my van for decent periods of time while parts came in. He has some storage, but I am sure it is a hassle to move vans around.
He has worked on my Subaru swapped van - had thinks like valve cover gasket, replaced exhaust manifold, replaced my wiring harness (from PO swap) with one from Auto Ventures, some brake work, replaced steering rack, replaced clutch, and probably a few other things. He's done a good job, I felt was honest, and at a fair price.
It has overall been a pretty good experience with only a few bumps. He let me bring in some of my own parts to avoid the markup and has provided some guidance on how to do some things myself that I was a little nervous about.
While a small shop, I have found it is much quicker to schedule work. I had something done at Eions (who is great) but had to schedule is 5 months out. Except at the busies times, Case has usually had me in within a week and has always been responsive to emergencies.
I have asked him to do a couple things that he is unwilling to do but he is upfront and clear about this work.
My worst experience there was related to the wiring harness swap. The PO had a rat's nest of a wiring harness and other mechanics had flagged it as a problem. I had some gremlins and Casey said the harness was part of the problem. He sourced a harness from a salvage yard and sent it along with the ECU to Auto Ventures. Turns out the harness and the ECU weren't a perfect match which caused some delays and problems. The van was offline for about 5 months. When I got it back, there was a very high idle problem which OneVan kinda shrugged their shoulders.
Hope this helps
1991 manual camper with EJ25
jimf909
jimf909 is offline
PostPosted: Thu Mar 06, 2025 12:00 pm    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
I think Dave was referring to this statement on their website:
"One van solves this problem by keeping your van in your driveway until you have an accurate estimate in hand. Efficient turn-around times with drop-offs scheduled once all parts and materials arrive."
I stopped by last year but no one was home. There appeared to be plenty of room for parking customer vans in addition to what appeared to be a few project/parts vans. Regardless, it doesn't make sense to store customer vans that are weeks away from being touched (liability, work space, etc.) so it's a good expectation to set.
- Jim
Butcher wrote:
Guilty as charged.
Red Ryder
Red Ryder is offline
PostPosted: Thu Mar 06, 2025 6:24 pm    Post subject: Re: One Van Repair Shop in Seattle - any insights? Reply with quote
If I know the shop needs to order parts, I ask about availability and the lead time to get them. Customer-provided parts can be a liability for the shop unless agreed to in advance. Overall, I prefer to keep the van in OUR garage if there is a significant wait involved rather than being stored by the shop.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
