oprn Samba Member
Joined: November 13, 2016 Posts: 14877 Location: Western Canada
Posted: Wed Sep 25, 2024 5:47 am Post subject: New challenge |
Have you ever regretted supporting someone's dream? A fellow I got to know in a town an hour north of us saw the wife and I driving our street Buggy.
"I always wanted one of those!" So he spent the next summer on line sending me pictures of Buggies for sale, picked one that looked really good, paid top dollar and met the guy 1/2 way across the country to pick it up.
A year goes by in which we keep trying to get together for a ride and some ice cream but life is too busy for both of us and it doesn't happen. I keep hearing about "little" annoying things he is dealing with, shaky steering, flat spots on acceleration, that sort of thing. Nothing much, just hints. I know he doesn't want to be a whiner or impose on me. Nice guy all around!
Now this fellow is a retired school teacher, excellent people skills, very musical but almost zero mechanical skills.
Finally we break through the busy wall, "I gotta at least see this thing!" I tell him. So he confesses to wanting to change the oil and is confused about the significance of the oil strainer, what to do with it etc. And "I would really like to have you drive it to see if it's "normal".
Yesterday was the day! Took our Buggy. Oil change went fine. No surprises, has a filter pump, good deal! I'm looking at the engine and alarm bells are going off... 1/2 a cooling system, dual cannons, Chinese no name distributor and carb, tiny aftermarket air cleaner, regulation plastic fuel filter beside the coil and distributor cap ready for an insurance fire claim (parks it in the garage attached to his house), in short, all the appropriate mistakes that have been made on these engines in Buggies for the last 50 years.
Test drive time! He is in mine and I am in his. First off, this thing has a 2000 RPM idle! Huh! On the road the shake kicks in at 55 MPH and out at 65 MPH... perfect, just where you always wanted one! Not bad, bad, just annoying as heck! Car feels twitchy but the steering is tight, no play at all... anywhere. I know he has spent quite a bit at the alignment shop on this thing.
Conclusion: Needs castor shims and get rid of the offset caused by adaptors and wide tires/rims. Start with the shims... $15 + shipping.
Engine, seems to run ok... sort of. A 1641 DP should be a lot more lively really, you ain't going to pull out and pass anything. High idle is really annoying. Bit of a flat spot, not too bad. Does have a vacuum pot and it's hooked up. Hmmm...
Back home to do some adjusting. This is where the whole thing starts to unravel! Every carb adjustment I try makes it run worse! Throttle cable resembles a guy wire for a telecommunications tower. Big and stiff. The carb return spring cannot overcome it enough to close the throttle fully. Engine does NOT want to idle down. It's acting like it has a wild cam, lumpy hit and miss idle even at 1000 RPM.
Now let's check the timing. Oh Boy! 21* at idle vacuum line plugged, 43* at full mechanical advance. turn it down to 9* and 31*... won't idle at all! Back to the carb and open the air bleed back up to finally get a ragged 1000 RPM idle... test drive time.
Now we have better power but a hole in transition you could drive a Greyhound Bus through! Back on the carb, accelerator pump is already maxed out, get some relief from leaning out the idle and putting the idle speed back up to 1800 RPM but this thing is just NOT RIGHT!
So, out of time for the day, starting to realize there is no simple fix here, I have just embarked on my next career to get this thing running properly, need to start with a valve lash adjustment, compression test, dial indicator to determine cam choice (Buddy was told it has a performance cam), look for intake leaks, see if the heat riser is plugged, change the exhaust to get some heat riser flow, add ALL the bottom tins including flaps and thermostat, do something with the stiff throttle cable, get an extension on the air cleaner to contain the fuel fog.
Only then can I attempt to tune it...
Here is the kicker. Buddy gave me a gift certificate when I went to leave for helping with the oil change and making his Buggy run worse! Now I feel really bad as he has already spent way too much on this thing!
The upside is that I am so, so grateful/blessed if you will for having grown up with, driven and maintained our own air cooled VWs in the past and know how they are supposed to run. There must be a hundred thousand Buggy owners out there with engines that run like crap and they have no idea... just like my Buddy here!
P.S. Last summer I met in person the 80 year old man that built my Buddy's Buggy. Really nice guy! Does a really nice job of building them, clean and sweet, show quality really or very close. "I build them all the same." he told me. But... he never drives them more than a few blocks to get a coffee or a doughnut! Never on the highway... so this is but one of 68 Buggies he has built and sold! "Ya, I always set them at 15* BTDC and the valve lash at .010"."
Just think, there are 67 more Buggies around here that just need a proper tune!
_________________ Our cars get old, we get old but driving an old VW never gets old! |
EVfun  Samba Member
Posted: Wed Sep 25, 2024 8:41 am Post subject: Re: New challenge |
Some thoughts...
Caster shims for sure, when the tires stick out they are very needed. If it has front disc brakes there may be a rotor option available with the GM pattern to eliminate the adapters and push the tires in some.
The throttle cable sounds like the original early style. They are a solid steel wire, pretty stiff, but it should return without binding. That is what is in my buggy. There were originally used with the pusher return spring with the 28 PCI or 28 PICT carb. You mention the need for an intake extension, for looks I would see if you could find one of these air filter bases.
[photo by Scott Novak]
Good catch on the WAY off timing. This thing sounds like it might benefit from getting a rebuilt OEM carb and distributor. I don't trust the new replacement parts that much. Unless...
If the engine has much of a cam in it I think it will always be a bear on the low end so long as the stock intake and carb are in place. However, with dune buggy duals the stock single carb is likely the best choice for intake. His buggy doesn't look like it has room for a pair of Webers.
With that exhaust the heat riser is never going to work that well. Perhaps an air filter with a snorkel can be found and then you could run a hose off the snorkel back to the oil cooler outlet (I'm guessing this has a doghouse cooling system). This may be more of a warm weather car.
The full stock cooling system is a good idea on a buggy, but few have it and most run a lot better than what you described. You will have to pull the engine to correct the cooling system to stock unless that chrome shroud happens to have the flaps installed. Would you have to loosen and lift the body a little to pull the engine? (the shroud looks close, and the body slopes down behind it)
Remember that a lot of what is done with buggies is about the look. Some of the mods are not the most practical, but for the most part these are fair weather cars. He has a beautiful looking buggy. I would try to keep the modifications for driveability in style. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
oprn Samba Member
Posted: Wed Sep 25, 2024 9:58 am Post subject: Re: New challenge |
| EVfun wrote: |
Some thoughts...
Caster shims for sure, when the tires stick out they are very needed. If it has front disc brakes there may be a rotor option available with the GM pattern to eliminate the adapters and push the tires in some. |
Drums but I am hoping (I think I am right) they are aftermarket drums without the ribs so they have enough meat to re-drill them to Chevy bolt pattern. That would eliminate the front adaptors that feel like they are about an inch and a half thick.
| EVfun wrote: |
| The throttle cable sounds like the original early style. They are a solid steel wire, pretty stiff, but it should return without binding. That is what is in my buggy. There were originally used with the pusher return spring with the 28 PCI or 28 PICT carb. |
Yes I remember those cables but this is a wound one about 50% thicker than stock and very, very stiff! Much like a bundle of music wire.
| EVfun wrote: |
Yes that is what we need!
| EVfun wrote: |
| Good catch on the WAY off timing. This thing sounds like it might benefit from getting a rebuilt OEM carb and distributor. I don't trust the new replacement parts that much. Unless... |
He was told by the seller (not the builder) that he HAS to run premium in it. He tried regular but he said it ran badly and seemed to miss on the highway when you stepped on it. I think he was getting detonation with 41* mechanical advance! Who knows, maybe more too if the vacuum was kicking in.
| EVfun wrote: |
| If the engine has much of a cam in it I think it will always be a bear on the low end so long as the stock intake and carb are in place. |
That is what I am afraid of that there will be no fix apart from a different cam. The seller says it has a performance cam, the builder can't remember for sure but thinks it's stock.
| EVfun wrote: |
| However, with dune buggy duals the stock single carb is likely the best choice for intake. His buggy doesn't look like it has room for a pair of Webers. |
He is looking at my Webers with envy ( I should have never let him drive it!) but he cannot imagine tuning his single on his own... is puts the fear of God right into him big time!
| EVfun wrote: |
| With that exhaust the heat riser is never going to work that well. Perhaps an air filter with a snorkel can be found and then you could run a hose off the snorkel back to the oil cooler outlet (I'm guessing this has a doghouse cooling system). |
I think I can fix the heat riser without too much trouble.
| EVfun wrote: |
| This may be more of a warm weather car. |
Yes it is. I am the only one that is silly enough to ice race a Buggy at -25*! As long as we can get it to run decent mid spring to mid fall he will be very happy.
| EVfun wrote: |
| The full stock cooling system is a good idea on a buggy, but few have it and most run a lot better than what you described. You will have to pull the engine to correct the cooling system to stock unless that chrome shroud happens to have the flaps installed. Would you have to loosen and lift the body a little to pull the engine? (the shroud looks close, and the body slopes down behind it) |
I am not looking forward to this but you are correct. No flaps at present but the bonus is that the holes are there.
| EVfun wrote: |
| Remember that a lot of what is done with buggies is about the look. Some of the mods are not the most practical, but for the most part these are fair weather cars. He has a beautiful looking buggy. I would try to keep the modifications for driveability in style. |
Yes!
On that vain I have an idea or two for the cannons. How about an equalizer tube either above or below the transaxle between #1 and #3? Remember the dual V8 exhausts of yesteryear? They often added a balance tube between the two sides. My thoughts are to give those two cylinders a bit more volume before the muffler and to smooth out the exhaust note at the same time. _________________ Our cars get old, we get old but driving an old VW never gets old! |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2927 Location: HdG, MD & NJ
Posted: Wed Sep 25, 2024 2:03 pm Post subject: Re: New challenge |
Some people just aren’t meant to own a classic custom vehicle. You need some brains and mechanical ability.
Check for a quick steer kit. And front and back alignment. Not sure it’s in need of caster shims.
I spun a buggy out at the track with zero caster. It feels like the rear is on ice and is trying to pass you. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
oprn Samba Member
Posted: Wed Sep 25, 2024 3:38 pm Post subject: Re: New challenge |
| NJ John wrote: |
| Some people just aren’t meant to own a classic custom vehicle. You need some brains and mechanical ability. |
And that is exactly where I made my first mistake!
| NJ John wrote: |
| Check for a quick steer kit. |
None.
| NJ John wrote: |
| And front and back alignment. Not sure it’s in need of caster shims. |
Just done professionally but I could get out a tape measure and check the toe settings.
| NJ John wrote: |
| It feels like the rear is on ice and is trying to pass you. |
Yes that is exactly how it feels but in a mild way. Drives fine really except that you have to be on it constantly, no time to look around at the scenery. Gives you the feeling that it is just waiting for your attention to lapse and it will give you a good clip upside the ear! That was how mine felt too both before and after a wheel alignment. The castor shims made all the difference and that was the only thing I changed after the alignment.
You really have to experience the difference to appreciate it. _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Fri Sep 27, 2024 5:13 am Post subject: Re: New challenge |
[quote="oprn"]
| NJ John wrote: |
I have been thinking about this statement some more.
My first reaction was to lay the blame on the original builder but in spite of all the conventional "right for Buggies" things he did and Chinese parts on it, I find it hard to believe that he would sell one that ran this badly. I have seen the Buggy he uses to go for coffee and parts/groceries, heard it run. It does not run like this one at all. Here it is.
He says he doesn't remember much about that Buggy but I wonder... my memory just might go bad too if I sold a used car (that is what these Buggies are, really!) to someone that qualified for NJ John's description and came back looking for warranty. As for his state of mind he sent me a picture of the paint can he used to paint that Buggy... seems to remember that detail...
The history here as nearly as I have determined is that the first owner bought the Buggy, took it home and the flywheel came loose. The builder told me he does not rebuild any engines he gets if they seem tight and run well. So the buyer complained to the builder and the builder sent him a 1641 that he had rebuilt sitting under his bench. Pretty decent of him I think.
So now the owner and/or his buddy dress this engine up and put it back in. The first thing he does now is put the car up for sale.
Scene 1
Enter left stage: my friend, looking for a Buggy. Likes the looks of it but price is a bit steep.
Owner: "It has a fresh 1641 engine."
Buyer: "How is it for power on the highway, can it keep up with the traffic?"
Owner: "Well it does struggle a bit with that."
Buyer contacts your's truly on the phone.
Your's truly: "It shouldn't. An engine that size should do 60 to 70mph."
Buyer exits stage left.
Scene 2
Enter left stage: the buyer... Summer is nearly gone and he has looked at a number of other Buggies and not found what fits his expectations and budget, notices that yellow one is still on the market.
Buyer: "I see the Buggy is still for sale."
Owner: "Yes it is and since our last conversation the engine is broken in and has good power now."
Buyer negotiates a better price and meets seller 1/2 way to complete the transaction.
Scene 3
Go to back to the start of this thread! _________________ Our cars get old, we get old but driving an old VW never gets old!
Posted: Fri Sep 27, 2024 5:17 am Post subject: Re: New challenge |
I always said, if you can keep your lawnmower running well, you could probably handle an aircooled vw, but some people can’t keep their lawnmower running. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
oprn Samba Member
Posted: Fri Sep 27, 2024 5:47 am Post subject: Re: New challenge |
I don't really have time to deal with this engine right now, fall garden work, winterizing the acreage and a grandchild on the way in the next 2 or 3 weeks 11 hours away. So for now I am taking my sand rail over to him today (it has a single port 1641) to drive around and get a feel as to how they should run. Then this winter I will put his Buggy in my garage, pull the engine and get at it.
I am hoping he will come over (1 hour drive) and get involved. I think he has the interest to and will. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1142 Location: North East Pennsylvania
EVfun  Samba Member
Posted: Sun Sep 29, 2024 2:40 pm Post subject: Re: New challenge |
The crossover pipe is interesting to me as well. I never thought about that until Oprn mentioned it. I did consider crossing over the cylinders, running #1 exhaust over to merge with the #4 and the #3 over to merge with #2. I’ve wondered if reversing the exhaust pulses compared to the intake would make dual Kadrons behave. Instead I ditched the Kads.
Oprn, if he intends that to be a summer fun vehicle you could likely get it to behave without pulling the engine. I’d start with a compression test and general check-up. Then I’d make sure the heat riser flowed and perhaps use a welder to create slight positive and negative scoops in the 2 and 4 pipes. It might benefit from a power pulley, even with one my first buggy oil temperature was only about 100F over outside temp. A rebuilt stock carb and distributor to correct that end (may need minor rejetting). All that, and a taller air filter as you mentioned, may just net a driveable buggy. (Since they are still running cold I tend to toss in a couple degrees extra advance at idle too.) _________________
| Wildthings wrote: |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4946 Location: Stuck in Ohio
oprn Samba Member
Posted: Mon Sep 30, 2024 2:26 am Post subject: Re: New challenge |
| EVfun wrote: |
| The crossover pipe is interesting to me as well. I never thought about that until Oprn mentioned it. I did consider crossing over the cylinders, running #1 exhaust over to merge with the #4 and the #3 over to merge with #2. I’ve wondered if reversing the exhaust pulses compared to the intake would make dual Kadrons behave. Instead I ditched the Kads. |
Ah! The old "Two wrongs to make a right." Interesting...
Yes I gave my Kadrons away. The present system on mine is dual cannons but with #1 paired to #3 and #2 paired to #4. Doesn't have any of the low RPM issues the conventional duals have. I don't know how stuck he is on the cannons that he has now or how much more money he is willing to throw at this Buggy but for my sake (being selfish here with my time) a 4 into 1 would be the quick fix. It would be interesting though to see what a balance tube would do between #1 and #3.
| EVfun wrote: |
| Oprn, if he intends that to be a summer fun vehicle you could likely get it to behave without pulling the engine. I’d start with a compression test and general check-up. Then I’d make sure the heat riser flowed and perhaps use a welder to create slight positive and negative scoops in the 2 and 4 pipes. It might benefit from a power pulley, even with one my first buggy oil temperature was only about 100F over outside temp. A rebuilt stock carb and distributor to correct that end (may need minor rejetting). All that, and a taller air filter as you mentioned, may just net a driveable buggy. (Since they are still running cold I tend to toss in a couple degrees extra advance at idle too.) |
I agree with all of the above but I would like to see the engine at the very least have a set of flaps in the fan housing. Then a thermostat could be added later without much trouble. Bare in mind that we had a hot summer here, it reached 85*F several times and 90* twice! Mostly it was 65 to 75*F.
My impressions from driving this engine was that it has ok power between 2500 and 3000 RPM but felt like it has a cork up it's butt any higher than that and of course the super high idle... good thing it's not an automatic transmission! _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Mon Sep 30, 2024 2:39 am Post subject: Re: New challenge |
| Buggeee wrote: |
| It's a good looking buggy. Well worth sorting it out. |
It is. The body itself feels much more ridged than mine. Not nearly as much twisting and flexing over the rough roads. _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Thu Jul 17, 2025 6:15 am Post subject: Re: New challenge |
Well, here I am finally back a couple weeks ago with enough parts to have a go at this Buggy.
Engine out, fan housing off, flaps, thermostat and all the tins in place. Cheap exhaust gaskets had already failed, hade a set of temporary ones to get him through the summer while we got some proper ones in. Exhaust nuts were various sizes and quality, ordered some copper nuts. Welded little cups in the #2 and #4 exhaust ports to see if we can get flow in the heat riser. New boots and new intake gaskets on the intake manifold.
Put it all back together and tried to get a tune on the carb. No joy, big flat spot and still lacking power in the upper revs. Accelerator pump maxed out but not delivering enough. Cheap distributor set at 10* initial and 31* total at about 3200 RPM. Seems surprisingly stable too. At least it idles now below 2K!
Ran out of time.
Back at it yesterday with a stock Solex and carb kit. Put a 4" extension on the air cleaner, proper boots on the spark plug wires, 2.5* castor shims on the front beam.
Runs and drives like a completely different car now! The only fly in the ointment is a 2 cylinder idle. #3 and #4 won't stay lit at idle and very low speeds. Creates a hole just barely off idle that disappears the instant it gets the accelerator pump shot. Idle mixture adjustment screw is open far too much, I took it right out and covered the hole with my finger with no change in how it runs. Far too lean, must still be some corrosion in the idle circuit we missed. Tried different idle cut off solenoids too but no change. Idle jet confirmed as a 55 and clean.
Out of time again, maybe tomorrow... _________________ Our cars get old, we get old but driving an old VW never gets old! |
kpf Samba Member
Joined: March 01, 2017 Posts: 1061 Location: California, US
Posted: Thu Jul 17, 2025 8:16 am Post subject: Re: New challenge |
Congratulations on the improvements!
| oprn wrote: |
| ...2 cylinder idle. #3 and #4 won't stay lit at idle and very low speeds. Creates a hole just barely off idle that disappears the instant it gets the accelerator pump shot. Idle mixture adjustment screw is open far too much, I took it right out and covered the hole with my finger with no change in how it runs. Far too lean,... |
I'll place my bet on "vacuum leak." _________________ 1971 Super Beetle |
oprn Samba Member
Posted: Thu Jul 17, 2025 10:48 am Post subject: Re: New challenge |
And that is why we replaced the intake boots and gaskets. It idled as good as can be expected for and engine with dual cannons with the Chinese carb. The idle problem started with this Solex so pretty sure it's the carb. I sprayed ether starting fluid around that side just to be sure and there was no change.
Bringing a 50 year old carb back to life just might take a couple tries. _________________ Our cars get old, we get old but driving an old VW never gets old! |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1033 Location: South Florida
Posted: Thu Jul 17, 2025 12:04 pm Post subject: Re: New challenge |
| oprn wrote: |
| ... sprayed ether starting fluid around that side ... |
Including both sides of butterfly throttle shaft? |
EVfun  Samba Member
Posted: Thu Jul 17, 2025 2:05 pm Post subject: Re: New challenge |
I have never seen a throttle shaft leak give a 2 cylinder idle on one side. We ran some pretty loose ones back before aftermarket “stock” carbs were available. I’ve also never seen dune buggy duals cause a 2 cylinder idle on one side. They can cause 1 and 3 to drop out. So… the simplest answer is you have a slight intake leak on the left side. _________________
| Wildthings wrote: |
oprn Samba Member
Posted: Thu Jul 17, 2025 6:48 pm Post subject: Re: New challenge |
Yes the throttle shaft does have some wear.
I totally get the intake leak thing but explain to me why it leaks with the Solex carb but not the Chinese clone? _________________ Our cars get old, we get old but driving an old VW never gets old! |
EVfun  Samba Member
Posted: Thu Jul 17, 2025 8:59 pm Post subject: Re: New challenge |
| oprn wrote: |
I totally get the intake leak thing but explain to me why it leaks with the Solex carb but not the Chinese clone? |
A warped carb base, perhaps? That doesn't seem like a one side drop-out though. _________________
| Wildthings wrote: |
