calvinater Samba Member
Joined: September 06, 2014 Posts: 3600 Location: 802 The Pointless Forrest
Posted: Sun Mar 16, 2025 3:33 pm Post subject: Query |
Can anyone tell me why. This tool would be useful?
1/2 inch female on both ends
Appears to be homemade.
_________________ "Albatross"! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sun Mar 16, 2025 3:46 pm Post subject: Re: Query |
Farm or industrial machinery with square head fill/drain plugs maybe? _________________ 1960 Ragtop w/Semaphores "Inga" |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79957 Location: Sneaking up behind you
Posted: Sun Mar 16, 2025 3:55 pm Post subject: Re: Query |
Might not be a tool, but a universal joint for square steering/drive shaft. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53039 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 16, 2025 4:39 pm Post subject: Re: Query |
If it's drilled or has set screws Glenn wins, if it isn't then I agree with Mukluk. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Sun Mar 16, 2025 11:22 pm Post subject: Re: Query |
l would talk to a plumber, cast iron plugs, often have a square head on them. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2579 Location: high ridge, mo
Posted: Mon Mar 17, 2025 3:43 am Post subject: Re: Query |
Run across a lot of old garage doors with square headed lag bolts holding the tracks to the wall. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36116 Location: Conejo Valley, CA
Posted: Mon Mar 17, 2025 9:02 am Post subject: Re: Query |
Anyone up for some twisted female on female action? _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Joined: January 01, 2007 Posts: 17885 Location: sticksville, ct.
Posted: Mon Mar 17, 2025 9:40 am Post subject: Re: Query |
more than likely a universal joint for a very low speed 1/2 square shaft _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Mar 18, 2025 4:13 am Post subject: Re: Query |
Welp it. Is going in the. Socket drawer, may find a use for. It someday..
No set screws, just what appears to be a hand peened rivet.. _________________ "Albatross"! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33286 Location: Hot Arizona
Glenn  Mr. 010
Posted: Tue Mar 18, 2025 7:06 am Post subject: Re: Query |
Cusser wrote: |
I'd put it with my 9mm combination wrench that I've used exactly once in 55 years..... |
16mm for me _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue Mar 18, 2025 8:02 am Post subject: Re: Query |
Glenn wrote: |
Cusser wrote: |
16mm for me |
Apparently you've never owned an 80's/90's GM product, they seem to use every odd wrench in both metric and imperial.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23296 Location: Oklahoma City
Posted: Tue Mar 18, 2025 9:17 am Post subject: Re: Query |
busdaddy wrote: |
Glenn wrote: |
Cusser wrote: |
16mm for me |
Apparently you've never owned an 80's/90's GM product, they seem to use every odd wrench in both metric and imperial.  |
Modern water cooled VW too. 16mm and 18mm are very common on suspension parts. 9mm fits clutch PP bolts and a few other parts.
Ray |
zerotofifty Samba Member
Posted: Tue Mar 18, 2025 11:45 am Post subject: Re: Query |
busdaddy wrote: |
Glenn wrote: |
Cusser wrote: |
16mm for me |
My Jeep has SAE and metric fasteners, a mix circa 1990. Body is most all metric, drivetrain, suspension is most all SAE.
Double your pleasure, double your fun!
It also has AMC and Chrysler bits, a transition of maker thing back then. Then again it has also been modified with a Ford 9 inch rear end. I have to search at many suppliers for parts. |
mukluk Samba Member
Posted: Tue Mar 18, 2025 4:17 pm Post subject: Re: Query |
Cusser wrote: |
Buy a Ford. You'll need that wrench, a T15 driver, a #1 phillips, and a special trim tool just to get one door panel off.  _________________ 1960 Ragtop w/Semaphores "Inga" |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24189 Location: NYC/Upstate/ROW
Posted: Tue Mar 18, 2025 11:13 pm Post subject: Re: Query |
Glenn wrote: |
Cusser wrote: |
16mm for me |
You know you are old when you can look at your wrenches and tell which one you haven’t used.
Love from Long Island _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Cusser Samba Member
Posted: Wed Mar 19, 2025 7:30 am Post subject: Re: Query |
Abscate wrote: |
You know you are old when you can look at your wrenches and tell which one you haven’t used. |
And you don't care about March Madness because you're mad year -round !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
