Deck lid latch release
paul_round
paul_round is offline
PostPosted: Thu May 15, 2025 3:52 am    Post subject: Deck lid latch release Reply with quote
I've been having huge problems with my decklid release, as other people have said, sometimes it takes both hands to open it, yet sometimes it just will pop open whilst driving. I was wondering if anyone has used a solenoid / actuator to open the latch?
sputnick60
sputnick60 is offline
PostPosted: Fri May 16, 2025 2:02 am    Post subject: Re: Deck lid latch release Reply with quote
Have you lubricated it? Hard to pull and not closing properly suggests there's too much friction around the plate.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
paul_round
PostPosted: Fri May 16, 2025 3:28 am    Post subject: Re: Deck lid latch release Reply with quote
Hi Nicholas, yes, all greased up. Upon further investigation, I've found that the nylon tube, just behind where the knob is, has become distorted, possibly from heat? I think it's a repo tube, I'm thinking of replacing with some 8 or 10mm copper microbore tubing. Still doesn't explain it popping during a drive though.
runamoc Premium Member
runamoc is offline
PostPosted: Fri May 16, 2025 8:01 am    Post subject: Re: Deck lid latch release Reply with quote
I replaced mine with a tractor choke cable. Has a spring coil wrap. No 'slop'. The popping open is from a feature of the latch. If/when the cable breaks the rear hood unlatches. Yours must be too loose. Cool
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
paul_round
PostPosted: Fri May 16, 2025 9:23 am    Post subject: Re: Deck lid latch release Reply with quote
I've tried tightening / loosening it, goes between being impossible to open, to popping open.
The tractor cable sounds interesting, I guess the spring coil wrap is similar to that on a bicycle.
runamoc is offline
PostPosted: Fri May 16, 2025 11:56 am    Post subject: Re: Deck lid latch release Reply with quote
you can see what I used....painted black of course. Cool
Steelz21
Steelz21 is offline
PostPosted: Sat May 17, 2025 4:59 pm    Post subject: Re: Deck lid latch release Reply with quote
Great idea with the tractor cable. When I lube mine, I get a build up of lube at the end then force it further in with a shot of compressed air. Works really well for me.
I use fluid film for lube.
runamoc is offline
PostPosted: Sat May 17, 2025 5:04 pm    Post subject: Re: Deck lid latch release Reply with quote
use fluid film
I got some of that but I was going to use it as undercoating.
ghiaueberalles67
ghiaueberalles67 is offline
PostPosted: Thu May 22, 2025 12:25 pm    Post subject: Re: Deck lid latch release Reply with quote
Can you elaborate on the tractor tube you used? Mine has been inoperable since 2003, but the deck lid is heavy enough that it never pops open, nor does it close and lock.
My cable is broken and I am looking for the best idea to fix it, to include doing nothing if that seems legit.
runamoc is offline
PostPosted: Thu May 22, 2025 1:48 pm    Post subject: Re: Deck lid latch release Reply with quote
Go to a Tractor Supple place and get a choke cable for a tractor. 6 to 7 foot will be enough. The stuffs easy to trim to fit.
