Part ID Help
bigwhit
bigwhit is offline
PostPosted: Fri May 23, 2025 2:26 pm    Post subject: Part ID Help Reply with quote
So after being in storage for over a decade, I am finally getting around to my Notch. I pulled out all the boxes and started to catalog and sort the parts. But since I didn't pull the car apart, there are parts I have no idea what they are. Any help on identifying these bits and pieces is appreciated.
Deleting photos as parts are ID'd
"All Glory Comes From Daring To Begin" William Shakespeare
bigwhit
bigwhit is offline
PostPosted: Fri May 23, 2025 2:27 pm    Post subject: Re: Part ID Help Reply with quote
Dfasty
Dfasty is offline
PostPosted: Fri May 23, 2025 6:29 pm    Post subject: Re: Part ID Help Reply with quote
In the first three pictures that’s a piece off the og muffler
70 fastback automatic 06 invader
bigwhit
bigwhit is offline
PostPosted: Fri May 23, 2025 6:49 pm    Post subject: Re: Part ID Help Reply with quote
Yessir. It certainly is. Thanks.
Dfasty
Dfasty is offline
PostPosted: Fri May 23, 2025 7:17 pm    Post subject: Re: Part ID Help Reply with quote
In the fourth picture the four clips on the right are clips to hold the lower trim to the lower edge of the dash top.
The lower tabs are to hold the gas tank in place.
ALLWAGONS
ALLWAGONS is offline
PostPosted: Fri May 23, 2025 8:37 pm    Post subject: Re: Part ID Help Reply with quote
[quote="bigwhit"]So after being in storage for over a decade, I am finally getting around to my Notch. I pulled out all the boxes and started to catalog and sort the parts. But since I didn't pull the car apart, there are parts I have no idea what they are. Any help on identifying these bits and pieces is appreciated.
Spring are for headliner bows
Left clios are for door sills
Right clios are for dash trim
Bottom plates are gas tank hold downs
if I am not mistaken.
Martin
Allwagond
PostPosted: Fri May 23, 2025 9:17 pm    Post subject: Re: Part ID Help Reply with quote
bigwhit wrote:
I agree with all of the ids posted above (if you need 2nd verification)
The clip above looks like a hubcap clip for a wide 5 Bug/Bus wheel so not Type 3.
Bobnotch
Bobnotch is offline
PostPosted: Sat May 24, 2025 12:01 pm    Post subject: Re: Part ID Help Reply with quote
[quote="ALLWAGONS"]
Martin
Allwagond
Yup, that's what they look like to me too.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
bigwhit
bigwhit is offline
PostPosted: Sat May 24, 2025 5:38 pm    Post subject: Re: Part ID Help Reply with quote
Mystery parts kit.
ALLWAGONS
PostPosted: Sat May 24, 2025 6:47 pm    Post subject: Re: Part ID Help Reply with quote
bigwhit wrote:
Mystery parts kit.
Nuts, bolts , locking washers, washers and some trapezoid looking thingys!
Bobnotch
Bobnotch is offline
PostPosted: Sun May 25, 2025 11:56 am    Post subject: Re: Part ID Help Reply with quote
ALLWAGONS wrote:
bigwhit wrote:
Mystery parts kit.
Not sure, but they look like the bolts, rubber washers, and metal washers for a late model trunk (ties the support brackets to the inner walls?).
Not sure about the "brass colored pieces", as I don't recall seeing them before.
Tram wrote:
Tram wrote:
bigwhit
bigwhit is offline
PostPosted: Sun May 25, 2025 12:25 pm    Post subject: Re: Part ID Help Reply with quote
It was a mystery parts bag that was tossed into the box that had a ton of interior electrical components.
I asked cause I have never seen anything like this.
No worry on identifying this.
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sun May 25, 2025 12:31 pm    Post subject: Re: Part ID Help Reply with quote
The first 2 pics, (that little bracket with the small bolt in it) look like the mounting bracket from an oval-window wiper switch?
- Zeuxius, 400 BC
