34 ICT Dual Carb throttle return spring bracket
6sixTinBox
6sixTinBox is offline
PostPosted: Fri Jun 13, 2025 11:06 am    Post subject: 34 ICT Dual Carb throttle return spring bracket Reply with quote
Anyone know where I can purchase the throttle return spring bracket for 34 ICT dual carbs in the U.S.? Mine fell off, I lost it and now I have poor throttle. I have searched all over the internet and here on the samba with no success. Thanks for the help. Cool It's number 43 here on this parts break down.
https://safe.menlosecurity.com/doc/docview/viewer/...6733a2ea79
1966 13 Window Deluxe
Comparison is the thief of joy - Theodore Roosevelt
John 14:6
Alstrup
Alstrup is offline
PostPosted: Fri Jun 13, 2025 11:50 am    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
https://www.carbparts.eu/exploded_view/WEBER_34_ICT
Buy them on Ebay to make it more simple.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Multi69s
Multi69s is offline
PostPosted: Fri Jun 13, 2025 1:57 pm    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
I get the vast majority of my Weber stuff from Pierce Manifolds
https://www.piercemanifolds.com/?utm_medium=paid&a...meEALw_wcB
Not only do they have a good parts selections, but they are extremely helpful if you need jetting help
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
6sixTinBox
PostPosted: Fri Jun 13, 2025 3:35 pm    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
Thank you Cool
John 14:6
Rome
Rome is offline
PostPosted: Fri Jun 13, 2025 4:14 pm    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
Piece #43 looks like a simple bracket with a right angle and a few holes. You could probably make something effective using a small metal right-angle mending plate from a HW store:
ggress gallery:
earthquake
earthquake is offline
PostPosted: Fri Jun 13, 2025 8:14 pm    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
I don't like putting the throttle return spring on ITC's because the do not have bushings on the butterfly shaft and the springs on the carb wear out the main body of the carb faster. I put them on the linkage so it takes the stress off the BF shaft, I have a set of ITC's Mark Harney bushed for me and they run great, I wish he was still doing them.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
H2OSB
H2OSB is offline
PostPosted: Sat Jun 14, 2025 12:52 pm    Post subject: Re: 34 ICT Dual Carb throttle return spring bracket Reply with quote
eQ
Woot, had mine bushed, as well. I've always heard they're decent carbs, with that as the main detractor. I had an opportunity to swap some disc brake parts I didn't need for to work on my carbs from one of the carb rebuilders on here. He also rejected them for my engine size, including emulsion tubes. Win-win.
But, to bring this back on topic...I purchased the correct brackets from Carbs Unlimited, IIRC. I bought my carb set used at the Sacramento Bug-O-Rama swap meet, and it had the crappy cross bar linkage. The cone shaped filters had gotten woefully crushed, so I got the linkage kit CB Performance sells, which has IDF style filters, but also retains the return spring brackets that come with the carbs (and I did not get with my used carbs).
H2OSB
(o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you.
