jakekoebrich Samba Member
Joined: June 02, 2024 Posts: 15 Location: Kingston Ontario
Posted: Wed Oct 29, 2025 10:52 am Post subject: Did I just discover one of Vanagon's unknown secrets? |
| Hi guys, I'm installing some sound deadening in my 85 Vanagon and I just realized there's an air vent on the door however there doesn't seem to be any port coming from the front dashboard to feed air into the door? Is that sliding vent useless? There seems to be a hole in the door that's supposed to pass the air into the bulkhead behind the cabinetry but again where does that airflow come from? Is this an unknown secret? (cue the spooky music) |
kamzcab86 Samba Moderator
Posted: Wed Oct 29, 2025 11:07 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| jakekoebrich wrote: |
| there's an air vent on the door however there doesn't seem to be any port coming from the front dashboard to feed air into the door? Is that sliding vent useless? There seems to be a hole in the door that's supposed to pass the air into the bulkhead behind the cabinetry but again where does that airflow come from? Is this an unknown secret? |
Nope; not a secret. It's your van's flow-through ventilation:
https://gowesty.com/blogs/article-library/ventilation-heat-and-a-c-in-the-vanagon-explained
 _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
jimf909 Samba Member
Posted: Wed Oct 29, 2025 11:11 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
The secret is that you can stow a full size umbrella in the door in that duct. Stash it in the passenger door so it can be accessed safely while on the side of the road. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
E1 Samba Member
Joined: January 21, 2013 Posts: 8762 Location: Westfalia, Earth
Posted: Wed Oct 29, 2025 11:14 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
The sliding vent indeed works, a dusty drive on a dirt road will prove it.
The front of the door has an oval opening sealed with a rubber perimeter to keep dust out, and it’s mated to the painted framework forward of it.
The rear of the door has another oval opening that mates to the chassis just aft of the door, where it’s surrounded by a “brush” trim on the chassis to keep dust out.
From there, the air feeding all this goes straight up the pillar forward of the sliding door, and continues to the upper vents above the slider.
On Westys anyway, I think the airflow stops at the pillar on the driver’s side… I can’t speak to non-Westys, but imagine they have upper wall vents like the passenger side of Westys have. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4698 Location: United States, Iowa
Posted: Wed Oct 29, 2025 12:51 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| jimf909 wrote: |
| The secret is that you can stow a full size umbrella in the door in that duct. Stash it in the passenger door so it can be accessed safely while on the side of the road. |
Careful on that tho, a big bump can jog that umbrella back into the B pillar and you can't open the door...
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
mrinnovation1 Samba Member
Posted: Wed Oct 29, 2025 3:13 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Who needs an umbrella? Its just water. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10135 Location: Where?
Posted: Wed Oct 29, 2025 4:55 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| mrinnovation1 wrote: |
This seems obvious to the point of absurdity, but you asked. I can't say I've ever 'needed' an umbrella, but I prefer having one when walking in the rain simply because I prefer to be less wet especially if it is cold out. It is just a matter of my own personal comfort. Remarkably similar are the reason I wear clothes, have a house, have a car, etc... The umbrella I usually carry in inclement weather also has a nice wooden knob for a handle and could serve double duty as a nice bludgeon if necessary.
I'm curious, what was the motivation for your post? _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80390 Location: Sneaking up behind you
Posted: Wed Oct 29, 2025 4:59 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| ?Waldo? wrote: |
| This is remarkably similar to the reason I wear clothes |
And we all thank you. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24396 Location: NYC/Upstate/ROW
Posted: Wed Oct 29, 2025 11:37 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
Anyone walking in UV index >5 _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10305 Location: Mt Lemmon, AZ
Posted: Thu Oct 30, 2025 9:58 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| jimf909 wrote: |
| The secret is that you can stow a full size umbrella in the door in that duct. ... |
It's where I keep my spare wipers blades. It rains so seldom that I don't replace them until they're really needed. |
do.dah Samba Member
Joined: August 27, 2015 Posts: 862 Location: Washington
Posted: Thu Oct 30, 2025 10:56 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
OR,, the umbrella slides forward into the 'A' pillar, especially if the umbrella has a long(ish) point.
| bobbyblack wrote: |
| jimf909 wrote: |
-bobby |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4592 Location: ABQ NM USA.... Except when not
Posted: Thu Oct 30, 2025 11:28 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| do.dah wrote: |
| bobbyblack wrote: |
| jimf909 wrote: |
-bobby |
on mine, there is a plate that covers the A pillar. the speaker wires go through the plate.
the B pillar I have made a plate to cover it to avoid the umbrella sliding back.
.. I wonder what good storage could be in the B pillar through that hole! _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Thu Oct 30, 2025 11:29 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Ahwahnee wrote: |
| jimf909 wrote: |
That is a GREAT idea on the blades!!!! Being from rarely-rainy NM my needs are similar to yours. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Thu Oct 30, 2025 11:39 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| kamzcab86 wrote: |
Ok, that's the answer I was hoping for. I knew about the passthru on the passenger side but I didn't know about the low pressure zones in the door jams and this drivers vent allows internal air out of the van. Good to know. Thanks! |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8523 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Oct 30, 2025 11:50 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| ?Waldo? wrote: |
I'm curious, what was the motivation for your post? |
Remember, everybody’s at a different point on the sarcasm scale…no harm, no foul.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Oct 30, 2025 1:08 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| BTW, where's the umbrella on an umbrella stroller? |
Posted: Thu Oct 30, 2025 2:02 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| vanis13 wrote: |
| Ahwahnee wrote: |
| jimf909 wrote: |
That is a GREAT idea on the blades!!!! Being from rarely-rainy NM my needs are similar to yours. |
Best idea of the month. _________________ - Jim
| Butcher wrote: |
Guilty as charged.
E1 Samba Member
Posted: Thu Oct 30, 2025 2:36 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
I’ve personally seen Julie Andrews’ Westy, so Jim’s is not a new idea. _________________ If ever twice as rich, we’re gettin’ a double-wide
MartinJS Samba Member
Joined: December 30, 2019 Posts: 117 Location: Western Canada
Posted: Thu Oct 30, 2025 5:54 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Perfect place for a pair of hiking poles... |
Andymon Samba Member
Joined: February 24, 2015 Posts: 416 Location: Medford, OR
Posted: Fri Oct 31, 2025 9:27 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
I keep a zombie machete in there.....just in case!! _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
