JIME82 Samba Member
Joined: May 09, 2023 Posts: 8 Location: Rotterdam, The Netherlands
Posted: Sat Apr 20, 2024 5:54 am Post subject: Re: What did YOU do to your van today? |
Left hand side coming along nicely. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32761 Location: Reading Pennsylvania
WillRB Samba Member
Posted: Sun Apr 21, 2024 6:49 pm Post subject: Re: What did YOU do to your van today? |
Added some led strip light for footwell lighting utilizing the Uniwerks retro gauge pod. Also added some lights for under the bench seat. ran some lights so I can see in glove box too and lights up my secondary auxiliary electrical behind glove box.
_________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
JIME82 Samba Member
Posted: Thu Apr 25, 2024 6:29 am Post subject: Re: What did YOU do to your van today? |
Finished it. Bleeded the brakes, taking her down for a long random and bumpy drive this weekend to settle in the new suspension and will get her aligned next week. Up next: fixing some rust and installing self made liftkit for the roofrack-poptop combo.
mtnhome Samba Member
Joined: July 17, 2010 Posts: 526 Location: Summit County, CO
Posted: Fri Apr 26, 2024 2:03 pm Post subject: Re: What did YOU do to your van today? |
Sometimes it's the little stuff.
My sliding door handle was sagging and loose. Took it apart and found it was cracking. I actually remembered that I had bought a NOS many years ago. After much searching, I found and installed it after switching the lock cylinder over. Replaced the inner foam seal and plastic escutcheon. Like new, nice and tight.
But then this.
Fortunately, I had some used spare handles and dropped them off with a powder coater I know.
This is a great guide to disassembly.https://www.thesamba.com/vw/forum/viewtopic.php?p=4667417&highlight=#4667417
I switched the lock cylinders over and installed the re finished handles. I also degreased and lubed the locks prior to installation. There was not a trace of foam in my OE handles, was that added later? Also, there is a thin plastic ring or seal on the lock cylinder. One of mine was cracked and I couldn't find an o-ring thin enough. Couldn't find one being offered anywhere so I assume its NLA.
Much better.
_________________ '84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight= |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3279 Location: ABQ NM USA.... Except when not
Posted: Fri Apr 26, 2024 6:36 pm Post subject: Re: What did YOU do to your van today? |
The cracked handle can often be prevented with the awesome derlin bushing available on eBay. Since you 3d print, I have made them that way and they seem to work well. Likely not as long lasting as the awesome derlin ones but there's are available at the push of a button. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 594 Location: Murray, Utah
Posted: Sat Apr 27, 2024 3:10 pm Post subject: Re: What did YOU do to your van today? |
Ordered a set of 16” Mercedes steelies today! I guess this is the motivation I need to get it titled finally _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
JIME82 Samba Member
Posted: Sun Apr 28, 2024 10:46 pm Post subject: Re: What did YOU do to your van today? |
Lift assist kit on a budget. Bought 2 cheap 600Nm 40cm gas struts, made two simple brackets out of stainless steel of stuff that I had lying around. Added two rod end bearings to connect to the bolts holding the roofrack.
Works like a charm after bending the brackets inwards a little. |
jlrftype7 Samba Member
Posted: Mon Apr 29, 2024 5:39 am Post subject: Re: What did YOU do to your van today? |
JIME82 wrote: |
Very Nice- can you add a close-up picture of the brackets and your work. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
kamzcab86 Samba Moderator
Posted: Mon Apr 29, 2024 12:31 pm Post subject: Re: What did YOU do to your van today? |
Finally made Aluminet front door window screens:
Warm/hot-weather camping should be more pleasant now! Test-run will be this weekend. _________________ ~Kamz
2016 Golf GTI S
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4387 Location: United States, Iowa
Posted: Mon Apr 29, 2024 1:55 pm Post subject: Re: What did YOU do to your van today? |
Kamz,
I think I see your usual magnets sewn into the hem. Looks good! Do you have radiation deflecting tint on your wing vents? Do you open those often while camped, as to why not covering them too?
Cool look. Now studying "Aluminet".
Thanks _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Apr 29, 2024 3:47 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Do you have radiation deflecting tint on your wing vents? Do you open those often while camped, as to why not covering them too? |
Yes, all glass is tinted (with clear ceramic on windshield). The vent windows only open 90° (virtually useless), so I rarely open them (need to do some modifying). Plus, it's far easier, quicker to sew a rectangle than a triangle.
I got the idea of making these when I stopped at Lake Havasu a few years ago. It was hot (although not summertime hot) and the wind was blowing. I put the fiberglass screens on, but the sun was baking the front of the van. Perfect situation for Aluminet versions. _________________ ~Kamz
2016 Golf GTI S
jimf909 Samba Member
Posted: Mon Apr 29, 2024 8:25 pm Post subject: Re: What did YOU do to your van today? |
How is Aluminet at keeping insects out? Is there a chance you'd want both Aluminet and fiberglass screen material in the screen?
Regardless, the Aluminet looks like neat stuff for blocking heat. _________________ - Jim
Abscate wrote: |
JIME82 Samba Member
Posted: Tue Apr 30, 2024 3:56 am Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
JIME82 wrote: |
Very Nice- can you add a close-up picture of the brackets and your work. |
Will do so next week when we are out camping. |
4Gears4Tires Samba Member
Posted: Tue Apr 30, 2024 8:05 am Post subject: Re: What did YOU do to your van today? |
jimf909 wrote: |
Regardless, the Aluminet looks like neat stuff for blocking heat. |
Apparently it's used in greenhouses and it's effective at blocking pests. _________________ '87 Syncro
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7780 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Apr 30, 2024 8:23 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
…Now studying "Aluminet"... |
Have not relied on for bug screening, but VERY effective for moderating temperature in hot, sunny conditions.
Aluminet, ARB-knockoff awning & portable fans made this trip tolerable for a coupl’a Minnesota folks!
(Goblin Valley near Moab, July 2018; 106°F ambient):
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Apr 30, 2024 8:24 pm Post subject: Re: What did YOU do to your van today? |
jimf909 wrote: |
Should be fine for insects, except perhaps for tiny, no-see-um types. If need be, I'll just pop the fiberglass versions on the inside.
Aluminet is fantastic for blocking the heat of the sun while allowing airflow. I've got a 6x8 panel for the awning and such.
Credit to dhaavers for posting about it in 2020. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat May 04, 2024 1:44 pm Post subject: Re: What did YOU do to your van today? |
Removed the Passat black rims with the snow tires, and installed the All Season Michelins which are mounted on the Mefro Silver rims. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
fxfxfx Samba Member
Joined: September 03, 2020 Posts: 7 Location: Ottawa/Gatineau
Posted: Sat May 04, 2024 4:28 pm Post subject: Re: What did YOU do to your van today? |
It started with paint on a rack extension to secure a Burger on the pop-top - and went downhill to a stuck intake valve...
1- low power, unburnt gas smell, rough idle, bogging under load
- changed o2-sensor: mostly the same
2- oily plug on #4, (light grey on all others), oil stays with the cylinder (spark plug cleans-up / fouls according to location in 10min driving)
3- spark ok (spark plug off, visual)
4- no change on idle when spark wire removed on #4
- at this point it is clear that #4 does not combust
5- no change on injector electrical wire swap with #3
6- injector off: same pattern both injectors on #3 and #4
- changed both orings - slight cracks
- injection is fine
7- compression: all sparkplugs off, at least 3 full turns
- order is 1-2-3-4
- dry test: 150-120-120-0 (yup: zero on #4...)
- with oil in #4: bumped-up to maybe 10-15psi on dynamic cranking (10 seconds cranking, my tester is equipped with a schrader check-valve directly at the head connection)
8- valve cover off: rocker is loose when valve is not activated on intake #4. All adjusters are fine and seem to be in the same adjustment position as when the motor was rebuilt.
- at this point: stuck-open intake valve on #4
Time to take a few steps aside and think
At least, the paint on the rack extension is almost dry now... |
WillRB Samba Member
Posted: Sat May 04, 2024 10:15 pm Post subject: Re: What did YOU do to your van today? |
Wrapped up a couple projects. First installing a CR-V fold down center console using rivnuts and a piece of wood painted brown as a stand off to maintain passenger swivel. The other is replacing the cone filter intake that came in the RMW conversion kit with a stock Subaru air box. Ran some intake line up into the driver side vent pillar from air box. Heading out to Utah towards the end of May and have never trusted the cone filter let alone in an area like Moab. Major plus is that airbox definitely quieted down the intake. Still need to drop my fuel tank again to deal with a leak at the fuel sender on fill ups, but things are coming along.
