iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9935 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Apr 16, 2017 7:31 pm Post subject: Re: Beetles with Multi-Colored body parts |
This is a very interesting thread.
Thanks, Bruce, for starting it. |
arizonabuckeye Samba Member
Posted: Tue Apr 18, 2017 2:18 pm Post subject: |
hitest wrote: |
Derluft- indeed, the upper car (likely a '64 due to wheels rims and decklid) may have Gulf blue as a base, because...
61sunrf- VW was extremely picky. It probably would not have taken much back then for a fender to blow inspection- and get resent through paint. I would not expect to find major repairs so much as finish flaws. If the texture or hue were far off from fender to car- I'd bet VW would pull it. In the previous examples, however, it's strange that even VW could blow a paintjob on a taillight housing!
I do know that the airscoops and license light on my orginal paint thing look they came from different continents... Perhaps the bodywork and paint finish were a perfect match- but the color was simply off?
EDIT: I just know there are 3 bilingual retired VW factory workers from the sixties getting a kick out our theories. What's German for(?): "those silly Americans- they just don't get our Friday afternoon paint antics." |
This is instantly where my thought went. It's not hard for me to picture a scenario where color of a fender/door/decklid/taillight housing was slightly off hue or had a slight bubble in the top coat and was rejected because it wouldn't match on a completed car. VW would have grabbed a replacement from it's stock of pre-paints and sent the rejected one back through the process meaning it would be repainted and according to factory needs it would get a different color. There is also scenarios where parts that got rejected would get multiple coats of different colors. For example if instead of being recycled back into the production line it was repainted and put in the mass stock of pre-painted parts. Then VW would routinely go through their stock and assess if they have too many of a specific color - grab colors where the stock is too high and recycle it again. So you would have a pool of parts that already have two different colors that are getting selected to get another color. *Total speculation - but based on evidence others have presented.* |
PopPop Jambon Samba Member
Joined: November 23, 2016 Posts: 125 Location: Florida
Posted: Wed Apr 19, 2017 5:08 am Post subject: |
61SNRF wrote: |
Can anyone explain why I had a '67 decklid that had been painted not twice but three times then?
I don't believe for a minute that every example out there happened in a dealer body shop. My information authority states that he has never found any evidence that the parts were body worked or repaired in anyway except for the repaint. Maybe it was done in a special facility on the assembly line, but done at the factory none the less.
Any good conspiracy is an unproven one!!! _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
(PO removed the deck lid, cut out the rear skirt and added rear fiberglass fenders, that's about it) |
tasb  The Distributor Distributor
Joined: April 27, 2002 Posts: 6665 Location: Pentwater, Michigan
Posted: Thu Aug 31, 2017 10:16 am Post subject: Re: Beetles with Multi-Colored body parts |
I've read through most of this topic but not every word, interesting none the less. I didn't see any examples from early cars, maybe because it's a post 1958 thread, but I do have one to contribute.
This is an original paint December of 1955- 1956 model year pastel green USA delivered Beetle. The original paint is weathering off nicely and reveals this, on the exterior of the front hood:
That's jungle green under the pastel green. The car was manufactured a few days before Christmas, 1955 and delivered to Washington state. It didn't get titled until just before Valentines Day, 1956, and the title is from a Lakewood, CA dealership, a suburb of Los Angeles. I would think that an LA ordered VW would have been delivered through Long Beach, not Washington state? Leads me to suspect that something happened to the car in transit, the hood was replaced and repainted and then shipped to LA, no?
_________________ Roads Scholar
Member# 2059 |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Thu Aug 31, 2017 10:58 am Post subject: Re: Beetles with Multi-Colored body parts |
@tasb
Certainly possible it could have been happening in 55/56, the paint/body specialist elrick67 mentioned his '58 back on page 3.
You're in the best position to judge. Have a close look under the hood, it might have thinner coats of paint, but it should have the same Jungle green under Pastel, and the paint on hood hinge bolts should be undisturbed. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
67ctbug Samba Member
Posted: Mon Jul 22, 2019 9:47 pm Post subject: Re: Beetles with Multi-Colored body parts |
Here's the hood on my 67. Underneath it is nice factory black with no sign of damage, on the top side during paint prep, however, we have primers then red, then sealer, then VW Blue, then sealer, then black. I can only see the red in a few places where I burned through the blue, however, there is filler under the black. This is factory paint so VW did do actual dent repair on stuff.
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
mukluk wrote: |
61SNRF Samba Member
Posted: Tue Sep 17, 2019 7:23 pm Post subject: Re: Beetles with Multi-Colored body parts |
@67ctbug,
I don't believe VW ever used any plastic fillers under factory paint, it should be all metal work. Your second pic does look typical of cars in this topic but hard to say from this side.
Here's a perfect example I recently found on FB, Ruby Red under Sea Blue...
hopkin  Samba Member
Joined: June 25, 2012 Posts: 2542 Location: Ottawa, Ontario
Posted: Tue Sep 17, 2019 8:11 pm Post subject: Re: Beetles with Multi-Colored body parts |
Just saw this thread, here's a pic of my old '71 Super I had in the early '80s. The road salt wasn't kind to my (then) 10 year old car:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (past)
2017 Dune Edition (daughter's car) |
socal1904 Samba Member
Posted: Wed Sep 18, 2019 11:04 am Post subject: Re: Beetles with Multi-Colored body parts |
Here is a shot of mine
finster Samba Member
Joined: May 26, 2012 Posts: 9781 Location: not far from the madding crowd
Posted: Wed Sep 18, 2019 12:05 pm Post subject: Re: Beetles with Multi-Colored body parts |
here's a pic from wolfsburg in 54/55. filling imperfections after primer
_________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Wed Sep 18, 2019 3:57 pm Post subject: Re: Beetles with Multi-Colored body parts |
finster wrote: |
here's a pic from wolfsburg in '55. filling imperfections after primer
Look at that, plastic filler! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
61SNRF Samba Member
Posted: Fri Sep 27, 2019 12:20 pm Post subject: Re: Beetles with Multi-Colored body parts |
@hopken and socal 1904, if you have read from page 1 you should know that this topic was created to showcase unmolested cars with cars with ORIGINAL paint.
Since both of your cars obviously feature NEITHER of these atributes I would greatly appreciate it if you would please delete each of your posts.
Thank you for your understanding. _________________ -Bruce
61SNRF Samba Member
Posted: Fri Sep 27, 2019 12:27 pm Post subject: Re: Beetles with Multi-Colored body parts |
67ctbug wrote: |
finster wrote: |
Look at that, plastic filler! |
First off, can finster please provide the source and legitimacy of this photo?
Secondly, the filler being applied in the photo is no doubt a lacquer based "spot" filler and not a polyester based surface repair filler. _________________ -Bruce
AlteWagen Troll
Posted: Mon Sep 30, 2019 1:41 pm Post subject: Re: Beetles with Multi-Colored body parts |
[quote="61SNRF"]
sure - page 136 of 'als der kafer laufen lernte' by bernd wiersch a book of photos taken at the factory in 1954
ps -perhaps you should change the title of the thread by adding 'factory fitted' or similar... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Mon Sep 30, 2019 2:06 pm Post subject: Re: Beetles with Multi-Colored body parts |
here's another pic from the same book showing quality control inspectors in the bodyshop - played by val kilmer and geoffrey rush look-a-likies
61SNRF Samba Member
Posted: Mon May 11, 2020 7:36 am Post subject: Re: Beetles with Multi-Colored body parts |
Found this example while browsing the Classifieds...
https://www.thesamba.com/vw/classifieds/detail.php?id=2376802
Note paint on left front fender worn through revealing Java Green under OG Black...
Seems like these oddity's are more commonly seen '65-> as paint quality from this era seemed to drop off. _________________ -Bruce
61SNRF Samba Member
Posted: Sun Jul 26, 2020 3:40 pm Post subject: Re: Beetles with Multi-Colored body parts |
..and yet another perfect example from jchaidez, Sea Blue door under Ruby Red topcoat...
Wonder what retort bill may would have now? May he RIP. _________________ -Bruce
jchaidez Samba Member
Posted: Mon Jul 27, 2020 1:05 pm Post subject: Re: Beetles with Multi-Colored body parts |
61SNRF wrote: |
Wonder what retort bill may would have now? May he RIP. |
Some extra images per 61snrf :
I do not know if the door is unadultered but these may help. |
61SNRF Samba Member
Posted: Mon Jul 27, 2020 3:28 pm Post subject: Re: Beetles with Multi-Colored body parts |
jchaidez wrote: |
Thanks jchaidez
Although it can be said from this pic it looks like the hinge screws have been loosened at one time I don't think there is any doubt (at least in my mind) that the car left the factory with this door.
Again it's an excellent example but why the oddity is so much more prevalent on 65 /66's with Ruby Red or Sea Blue is still a mystery. _________________ -Bruce
