Breaking Rusted wheel Lugs Nuts Free?
Page: Previous  1, 2
type2much
type2much is offline
PostPosted: Sun Nov 11, 2007 5:14 pm    Post subject: Reply with quote
what kind of lubricant can be put on lug nuts to keep them from seizing? mine are always real hard to get loose, they creak and then finally pop loose.
LittleThunder
LittleThunder is offline
PostPosted: Sun Nov 11, 2007 5:31 pm    Post subject: Reply with quote
Invest it a tap and die to fit the stud and nut. Clean those threads up. Wire brush the corrosion off. I don't use any lube. If the faces of the threads are reasonably smooth, they should come on and off easy and stay tight when torqued properly.
PostPosted: Sun Nov 11, 2007 7:02 pm    Post subject: Reply with quote
You can use anti-seize. I would use it on the threads only, don't get any where it contacts the wheel.
I agree on wire wheel your lug nut threads. You should be able to take a lug wrench and spin the lug nuts into the drum with no resistance.
arthurnugen
Location: The PNW, where "going green" means rolling with moss.
arthurnugen is offline
PostPosted: Tue Nov 13, 2007 1:34 pm    Post subject: Reply with quote
You could always try a 12 gauge. Shocked
http://seattletimes.nwsource.com/html/localnews/2004010439_lugnut13m.html
cdennisg wrote:
Lawyers don't deserve buses.
zozo wrote:
Don't worry too much. You can always trust a lawyer.
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke!
codeMechanic
codeMechanic is offline
PostPosted: Tue Nov 13, 2007 2:17 pm    Post subject: Reply with quote
beautiful
Stocknazi
Stocknazi is offline
PostPosted: Tue Nov 13, 2007 5:01 pm    Post subject: Reply with quote
interesting advice on not using antiseeze on the bolts where they contact the wheel. i have always dabbed a little there as well as the threads and never had a problem. however, the bolt becoming loose is quite a possibility. has anyone ever had a wheel bolt become loose due to antiseeze being used in this way?
WANTED:
Thomas Jefferson
PostPosted: Tue Nov 13, 2007 6:49 pm    Post subject: Reply with quote
I don't think it would really matter but I like the thought of metal on metal contact there.
Lohe
Lohe is offline
PostPosted: Tue Nov 13, 2007 11:09 pm    Post subject: Reply with quote
He wasn't even drunk.. wow
vintagevolks
vintagevolks is offline
PostPosted: Wed Nov 14, 2007 1:43 pm    Post subject: Reply with quote
PB Blaster will losen anything..
59 Ragtop
65 Restored Kombi... Went to the UK
66uno
66uno is offline
PostPosted: Tue Jul 14, 2009 9:43 am    Post subject: GD lugnuts Reply with quote
Two weeks now of PB blaster, torch, inpact wrench, hammer and swearing. Those suckers haven't budged yet. I think I might try dry ice next. Maybe it will make the metal contract? I just don't know: I am about out of ideas and am real, real frustrated.
I have other GD things to do besides this.
SkooobaSteve
SkooobaSteve is offline
PostPosted: Tue Jul 14, 2009 10:22 am    Post subject: Re: GD lugnuts Reply with quote
Impact? or if it runs just put breaker bar on there and drive it fowards use the engine to take it off. Ok that last one wasn't a good idea lol. Could just see it slipping off and flying into someone somthing. Laughing
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
SingleWheel
SingleWheel is offline
PostPosted: Tue Jul 14, 2009 11:12 am    Post subject: Reply with quote
I've used an old mechanics trick before that has never let me down. A toilet wax seal and a torch. Heat up the offending lugnut and apply the wax seal. it will melt and get into all the nooks and crannys and then try the breaker bars and impacts.
Not sure where I heard it, but tried it and it worked great. Good luck and let us know what eventually works.
Visit http://www.singlewheel.com
rusbus
rusbus is offline
PostPosted: Tue Jul 14, 2009 11:14 am    Post subject: Re: GD lugnuts Reply with quote
Don't forget breaker bar. I have a 6 foot pipe from a chain link fence that has busted loose nuts that no impact gun could budge. 6 feet x 200 lbs = 1200 foot pounds of torque. Jumping probably increases it even more. If the wheel is spinning, lock it in place with another bar against the ground. Just make sure you have a REALLY sturdy wrench on the bolt.
GeorgeL
GeorgeL is offline
PostPosted: Tue Jul 14, 2009 12:26 pm    Post subject: Reply with quote
Lug nuts/bolts are the one place where I don't use any goo, but then again I've never had one that I couldn't get off.
Considering the pressure between the parts it's unlikely that the anti-seize would prevent metal-to-metal contact. It just fills in the minute gaps to exclude oxygen and prevent corrosion.
AZ Landshaper
AZ Landshaper is offline
PostPosted: Tue Jul 14, 2009 7:25 pm    Post subject: Reply with quote
multiple applications of liquid wrench, each followed by a few taps with the hammer. on day two get that 5' bar back out and hang on it.
I actually hung a heavy bag on my 5ft bar and came out in the morning to have the job done for me. Gooood morning.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Jul 14, 2009 9:03 pm    Post subject: Reply with quote
nice square blow like you want to kill it from a 10lb hammer and a breaker bar with 7' of pipe and its off. with that kind of leverage you can shear the lug bolt. if for whatever reason it doesn't the drum most likely is junk drill it apart if you gotta have the rim, but toss the junk and move forward otherwise.
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
Stocknazi
PostPosted: Wed Jul 15, 2009 7:30 am    Post subject: Reply with quote
when i remove my lug bolts that i applied anti-sieze to it still makes that creaking sound like a dry bolt makes; almost all the anti-sieze looks like it's been wiped off where the contact point is
WANTED:
Thomas Jefferson
Page: Previous  1, 2
Page 2 of 2
