Mitch Case Samba Member
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Thu Feb 12, 2009 8:01 pm Post subject: |
DownRiver wrote: |
crukab wrote: |
grim reaper wrote: |
so does anybody know the difference between a 68 bay double back seat and a 65? or maybe some pictures? |
The split seat frame drops down about 8" from the ends, as does the seat frame, the Bay seat base goes straight across, no dip down.
crukab, that's a 64?-67 pedestal.
According to http://www.dropgates.com
Major Props to Dropgates for the following text. You can find pedestal photos on that site, along with a ton of truck specific info.
58 only
Curved pedestal, mounting tabs point inward.
59-60
61-64(?)
Curved pedestal, mounting tabs point outward.
64?-67
Flat pedestal, mounting tabs point outward. Notice the 2 circle pressings and strength notches across the top ridge.
68 and later
Flat with no circle pressings |
Actually, it seems that 68s have the seat base that is labeled 64-67.
I have 2 68 DCs with original interior and they have the 64-67 style pedestals . _________________ -Bryan
Motorwagen LLC
Concord NC |
NOS PARTS Samba Member
Joined: June 24, 2001 Posts: 377 Location: behind the wheel, safari's open
Posted: Fri Feb 13, 2009 1:00 pm Post subject: |
I have a few 62's and a few 64-67
I can only see the top rear having 2 rods
I dont recall seen those rods on the front seat top
http://www.kodakgallery.com/ViewSlideshow.action?&...4551654706
in the process of moving from my shop,
so I will be parting out 6 dcabs, sheet metal or any other misc parts
let me know what you need-cut |
blackdog1999  Samba Member
Joined: October 17, 2004 Posts: 1209 Location: Rancho Cordova, CA 95670
Posted: Fri Feb 13, 2009 4:00 pm Post subject: |
The first seat bottom is a hump back seat for late 61-63. It may or may not work on a crewcab rear seat pedastol. I do not believe it will.
The second seat bottom is a 58 through most of 61. This seat will also fit a 1959-63 crewcab.
Everett's pic here shows how a 63 & older rear seat pedastol looks. The bottom drops down because VW used front seat bottoms & in the front you have wheel wells to account for.
[/quote]
Here is a bay seat pedastol. Note that the top is flat. This is how 64 & newer are. A front seat from an early Bus will not work. Conversly the correct 64-67 crewcab seat base will not work in the front of an early Bus because there will be no support in the middle & the seat will sag & eventually brake.
I believe that the backrest was the same for all crewcab rear seats from 59-67. _________________ Home of the one true split Bus Motorhome |
DownRiver Samba Member
Joined: January 05, 2003 Posts: 797 Location: threeonethree
Posted: Fri Feb 13, 2009 5:22 pm Post subject: |
PM'd
NOS PARTS wrote: |
_________________ Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab |
Braukuche Samba Member
Posted: Mon Feb 16, 2009 10:21 pm Post subject: |
Just to note. I have a '59 SO-23 Westy seat while my '59 has a recovered in cheap ass TMI upholstery front seat. I went ahead and traded seats a couple days ago and it was no problem. On the DC rear seat I had to remove this square metal, hollow bar held on with two clamps of sorts, but other than that it fit like a glove in the Westy.
--Dan |
ldsvwguy Samba Member
Joined: September 16, 2003 Posts: 1025 Location: Saratoga Springs, UT
Posted: Sat Mar 28, 2009 10:36 am Post subject: |
So what years are compatible with what years? Will a 59 Single cab front fit in a 1960 Double Cab rear and so forth? The rear seat is real pain-in-the-keister to get sorted out and find. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20867 Location: Sandpoint, ID
Posted: Sat Mar 28, 2009 11:07 am Post subject: |
I know that bay double cab seat bottoms work for front seat bottoms in a barndoor. Both are flat all the way across. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Sat Mar 28, 2009 11:24 am Post subject: |
The 1960 has a dip in the pedestal so straight ones won't work. I'm interested in knowing what models have the dipped seat and which are interchangeable. |
Posted: Sat Mar 28, 2009 11:32 am Post subject: |
ldsvwguy wrote: |
I was not responding to your question, just stating a fact I know of. In the post with lots of pictures at the top of the page it appears to show that buses through 63 used the curved bottom on the front of the front seat bottom. 64 and later used the flat style. Hope that helps.  _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Lou V. Samba Member
Joined: October 29, 2003 Posts: 1018 Location: Placerville,CA
Posted: Sat Mar 28, 2009 11:43 am Post subject: |
55-61 front seat will work for a crew rear seat. _________________
eejermon wrote: |
"The Shasta Snow Trip. It's not for pussies." |
sled Samba Member
Posted: Sat Mar 28, 2009 11:47 am Post subject: |
lou verrilli wrote: |
55-61 front seat will work for a crew rear seat. |
true, but 61 front seat bottoms have a forward edge that is angled forward. the top of the seat overhangs the bottom slightly. Like you said it will fit, but look odd. _________________ drive your split. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71641 Location: Phoenix 602
Posted: Sat Mar 28, 2009 3:12 pm Post subject: |
sled wrote: |
true, but 61 front seat bottoms have a forward edge that is angled forward. the top of the seat overhangs the bottom slightly. Like you said it will fit, but look odd. |
To be more exact, up to very early 1961. All non-hump seats.
The 1958-61 (non-hump again) front seat back rest is the same as the rear back rest. _________________ How to Post Photos
Posted: Mon Apr 13, 2009 12:19 pm Post subject: |
So any 55-61 Non hump bench from any model bus will fit? |
Posted: Mon Apr 13, 2009 8:42 pm Post subject: |
Any chance of getting some dimensions of that bar? Maybe I can get one made if I can't locate one. |
Posted: Mon May 11, 2009 7:52 pm Post subject: |
Can someone please post some pictures and dimensions of the rear mounting bar? |
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3513 Location: Puyallup WA
Posted: Mon May 11, 2009 8:22 pm Post subject: |
ldsvwguy wrote: |
there was a really rusty one for sale in the ads the other day _________________
localboymark wrote: |
One man's "patina" is another man's cancer. |
bugnut68 wrote: |
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
C.C.C. Samba Member
Posted: Mon May 11, 2009 8:27 pm Post subject: |
Mikee wrote: |
ldsvwguy wrote: |
there was a really rusty one for sale in the ads the other day |
link?
I'm lazy...  |
Posted: Mon May 11, 2009 8:34 pm Post subject: |
C.C.C. wrote: |
Mikee wrote: |
ldsvwguy wrote: |
link?
I'm lazy...  |
me too _________________
bugnut68 wrote: |
