katalla Samba Member
Joined: March 15, 2006 Posts: 442 Location: los angeles
Posted: Thu Dec 31, 2009 5:01 pm Post subject: |
my old bug had a gex engine in it when i bought it, dont know how many miles were on it, i drove it two years before i sold the car, it never blew up. i guess i got lucky, im sure they make one that runs once in a while. |
hoghead5150 Samba Member
Posted: Thu Dec 31, 2009 5:02 pm Post subject: |
years ago gex built a pretty good engine. but that was YEARS ago. i had a gex 1835cc back in the 80's that i put over 60,000 miles on. it probably would have lasted longer, but i was young, and didn't really keep up with scheduled maintenance on it. back then i had several friends that ran gex motors and all of them were good.
now flash forward a couple of years and gex products went down hill BAD. anymore, most gex motors are only good for core! if that.
i'm with glenn. drive it till it gives and then get a good motor. until then save your money. at least in so. cal you will be able to find vw parts easily! _________________ "i got a friend that knows a guy who's best friend has an uncle that used to have a bug just like yours!"
i measured once, cut it three times, and the damn thing is STILL to short! |
Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2354 Location: Sea level (Mid Atlantic)
Posted: Thu Dec 31, 2009 5:43 pm Post subject: |
hoghead5150 wrote: |
i'm with glenn. drive it till it gives and then get a good motor. until then save your money. at least in so. cal you will be able to find vw parts easily! |
You must have missed the OP's last post. It already gave. Put a bullet in its sump and put it out of its misery. The 5 minute run is about right for a GEX engine. On the bright side, there wasn't a lot of suspense.
Someone on here posted something about some junk parts they couldn't use for rebuilds, and the GEX guys came in and bought the lot.
Samba members ought to take out a two-page glossy ad in HVWs about GEX. _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
Posted: Thu Dec 31, 2009 5:47 pm Post subject: |
Pelikan wrote: |
I talked to my father (the super is at my parents place; they let me use a port in their garage to work on it). He had one of his mechanic buddies come over and run the engine, after I told him what they were saying about GEX on the forums. Apparently it was only running on three cylinders because the spark plug wasn't seated right, or something along those lines. Within a few minutes, a part in the oil pump was sheared off, and it lost oil pressure.
So that's where my GEX is at, after about five minutes of run time. I'm putting some strong thought into salvaging what I can off this engine, and building up a 1776 from new parts, or having a cost effective long block mocked up. I'll probably have about $1000 to work with, so hopefully I can do it for that. |
Tear it down--if the oil pump already grenaded, you've got metal floating around in there and will ruin what MIGHT be salvageable if you run the engine again.
Post up pic's. And, I'm sorry--even if you "should have known better" or done your research, that really sucks. I bet you paid a fair bit for that engine. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
GatorJZ Samba Member
Posted: Fri Jan 01, 2010 8:31 am Post subject: |
Pelikan wrote: |
Friendly advice: Do a search for "Empi" before you go buy anything. _________________ 1973 Sports Bug (Super) |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Fri Jan 01, 2010 9:56 am Post subject: |
Pelikan wrote: |
Sorry to hear about you getting "GEX'd" - wow, GEX motor died after 5 minutes of run time? Must be some kind of new record?
Good luck with your rebuild & hope you have a great New Year!
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Fri Jan 01, 2010 9:58 am Post subject: |
katalla wrote: |
...it did run once... for about 5 minutes before unleashing Hell in the engine bay -
Fitz. Samba Member
Joined: October 06, 2009 Posts: 362 Location: Montavilla, Portland, Oregon
Posted: Fri Jan 01, 2010 11:00 am Post subject: |
Best bet now--as everyone is saying--tear it down and start anew.
You're talking about a budget? Time to lose the mechanic and learn about your car. It sounds like you're already pretty well in the know, so save that coin and buy some handcleaner!
Oh, and my advice for a student (I graduated from Portland State '08, at 35 years old) is to run a stocker. Cheaper on parts, less wear and tear (power equals heat), and better on fuel. A stock 1600 DP with a header and decent carb set-up will make more than enough power for day-to-day use. And it'll keep those costly traffic tickets down, too.
Bummed for your loss, but live and learn. As Glenn says: Cheap-fast-reliable... But you can only pick two. Cheap and reliable can be done (I've been doing it for years), but you've got to realize that cheap means doing a job once, so always buy the high-quality part the first time...
Good luck! _________________ Settle down, it's a car. |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Fri Jan 01, 2010 11:48 am Post subject: |
Bart Dunn wrote: |
Samba members ought to take out a two-page glossy ad in HVWs about GEX. |
Yep ... the 5 minute run time could be the headline. I had a GEX 40 horse long block way back when GEX was out here in Ca. (remember their roll-up poster with the bikini girl and the spotless long block?). Well, the crank snapped a few thousand miles into it's life. GEX moved out of California for a reason. Baldwin Park (their home while in Ca.) became just a bit too easy to find. Their unresolved BBB complaints (no better BBB references in Arkansas BTW) and face to face visits with angry customers, drove them out of Ca.
P.S. Nice avatar Fitz _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Detroit73super Samba Member
Joined: October 03, 2009 Posts: 611 Location: Detroit
Posted: Fri Jan 01, 2010 12:04 pm Post subject: |
only 5 minutes eh ??
Too bad it wasn't five minutes of setting a new, never to be broken land speed record instead of in a car port. |
Posted: Fri Jan 01, 2010 12:18 pm Post subject: |
If anyone's in the appropriate line of work (military, mob, etc.) put high explosives here. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
whobba Samba Member
Posted: Fri Jan 01, 2010 12:24 pm Post subject: |
I bought a GEX back in 1999 for the '73 Ghia, and despite the myriad of crappy reviews, that long block ran great for the 8 years I drove it. I hated how they painted the case, because the paint doesn't last long before it starts to peel off. I wouldn't but a GEX again, though - just because of all the bad reviews that I read on TS. It didn't even leak oil, either. Maybe I lucked out. _________________ **SUPPORT THE SAMBA**
http://www.thesamba.com/vw/donate.php
http://www.thesamba.com/vw/products/ |
Fitz. Samba Member
Posted: Fri Jan 01, 2010 2:40 pm Post subject: |
clearsurf2001 wrote: |
P.S. Nice avatar Fitz |
Thanks Man! _________________ Settle down, it's a car. |
Posted: Fri Jan 01, 2010 2:52 pm Post subject: |
whobba wrote: |
I bought a GEX back in 1999 for the '73 Ghia, and despite the myriad of crappy reviews, that long block ran great for the 8 years I drove it. I hated how they painted the case, because the paint doesn't last long before it starts to peel off. I wouldn't but a GEX again, though - just because of all the bad reviews that I read on TS. It didn't even leak oil, either. Maybe I lucked out. |
Maybe the case paint was holding the oil in?
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Fri Jan 01, 2010 3:46 pm Post subject: |
I thought they built enough of their own grenades.  _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Fri Jan 01, 2010 5:29 pm Post subject: |
HeidelbergJohn4.0 wrote: |
I thought they built enough of their own grenades.  |
Too long on the time-delay fuses. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
Fitz. Samba Member
Posted: Fri Jan 01, 2010 10:21 pm Post subject: |
Bart Dunn wrote: |
Too long on the time-delay fuses. |
On the contrary: Five minutes seems ideal for a quick getaway. _________________ Settle down, it's a car. |
Baja Champ SE Samba Member
Posted: Fri Jan 01, 2010 11:04 pm Post subject: |
Did anyone else notice that they are located across the street from a cemetery???
This is indeed a case of irony...so I did learn something in high school english.  _________________ -1972 Baja Champion SE Super Beetle "Frank the Freak"
SOLD
-1969 Deluxe Bus "Warhaul" aka "Project Whitestock"
Air Speed VW Club of So Cal
Member Since July 2007 |
bob67firebird428 Samba Member
Posted: Sat Jan 02, 2010 5:50 am Post subject: |
I must have one of the other lucky Gex motors , was in the car allready and car was cheap , motor has been run for many years allready and its a VERY strong 2180cc .. Im happy so far ..... but i do need to get rid of the stock heater boxes and put on a bigger carb ?
