joetiger  Samba Member
Joined: January 27, 2005 Posts: 5266 Location: denver
Posted: Sun May 09, 2010 12:15 pm Post subject: |
I just got the part from a guy who was parting out a '90.
It looks identical to the one on my '85, part number 251 201 129, same as the old one. I'm thinking that if it doesn't have the "a" suffix, then it's probably doesn't have the ball float. I can't tell any difference between this one and the one I already have. Which sucks. I might just install and see if there's any difference. _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
jmranger Samba Member
Posted: Sun May 09, 2010 12:25 pm Post subject: |
joetiger wrote: |
I might just install and see if there's any difference. |
Don't waste your time. The float is externally mounted - very visible if present. If you don't see it, it's not there.
I have pics of both models - will edit the post when I get a chance.
Edit: ok, here are the pics:
251 201 129 (from my 87):
251 201 129A (from a 91 I believe):
Reckless Amateur wrote: |
Comparing the one from the 87 I had and the one I got from a 1990, I think, the newer one had a ping pong ball float at the end which I don't thing the 87 did. If that helps.  |
I almost answered "D'oh" to that, but now that I've seen the actual parts, well, that description is dead on
JM |
Posted: Sun May 09, 2010 2:01 pm Post subject: |
Awesome. Anybody need an extra gas-vometing filler tube? _________________ Joe T.
Posted: Tue Nov 13, 2012 6:01 pm Post subject: |
Thread resurrection...
I was out at a pull-it yard this afternoon (the one at US36 and Broadway) picking bits and pieces off of an '88 Wolfsburg. It was pretty picked over, but I was lucky enough to pull a good lower grill and a decent heater cover.
I pulled the filler neck just for kicks to see if I'd get lucky and find a ball float valve at the other end.
Well, the cage is there, but the ball is gone! D'oh!
The little cage has a part number, though, 191 201 207. I've checked a few of the usual sites and haven't had any luck yet. _________________ Joe T.
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10255 Location: Mt Lemmon, AZ
Posted: Tue Nov 13, 2012 6:06 pm Post subject: |
Looks like the ball inside a can of Guinness. Wonder if that one is fuel-proof? |
Posted: Wed Nov 14, 2012 6:47 am Post subject: |
Luckily, I had Guinness in the fridge. Tore up the can and tried it out on your advice--too small. I've got an email in to Van Cafe to see if the part is NLA or not. _________________ Joe T.
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15397 Location: Syracuse, NY
Posted: Wed Nov 14, 2012 7:07 am Post subject: |
looks very near a regular ping pong ball
they sell orange ones in the beer & red solo cup isle at your gas station (nothing like a manufacterer promoting beer drinking games ) _________________
Abscate wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17203 Location: Brookeville, MD
Posted: Wed Nov 14, 2012 10:47 am Post subject: |
I'm no chemist, but I'm thinking that dissolved ping pong ball might be bad for the fuel system.  _________________ Joe T.
Posted: Thu Nov 15, 2012 6:49 am Post subject: |
Ball float valve NLA. On the positive side, I'm building up a nice collection of worthless fuel filler necks. _________________ Joe T.
Posted: Thu Nov 15, 2012 7:55 am Post subject: |
I'm curious if the Orange ones are nitrocelluouse and will have to conduct my own garage experiment..
just have to make sure not to mix up the gas cup for the beer cups..  _________________
Abscate wrote: |
OMcComis Samba Member
Joined: December 22, 2013 Posts: 46 Location: United States
Posted: Fri Mar 14, 2014 3:40 pm Post subject: Nylon ball check valve. |
I just bought a filler tube but as everyone else has noticed, there was no ball with it. Believe it or not, I did a quick search on Amazon and found this: http://www.amazon.com/gp/product/B005GFT4O2/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 These fit but looking at the picture posted previously maybe a little small. Sure you could find them in 1.25" though. |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5275 Location: Taoswest, USA
Posted: Fri Sep 19, 2014 10:29 am Post subject: |
Just tossing these into the mix. As I recently repaired (yesterday) the vapor system on my 89 Vanagon Westy, I found the plastic ball inside the tank. It had been pushed out or fallen out of the cage at the end of the filler tube.
I was able to reinstall it, but while doing so I pulled one out of an 84 parts Vanagon to compare the filler tubes.
Here is what I found fyi.
Without ball in the cage.
Upper is the later model filler with cage.
With ball reinserted into the cage. The cage had no tears and was very solid.
_________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
