3BT Baja
Page: Previous  1, 2, 3  Next
tanner_122
tanner_122 is offline
PostPosted: Sun Jul 11, 2010 9:15 pm    Post subject: Reply with quote
ur rear storage area looks sweet man
91 jeep Cherokee "TANK"
sloboatnova
sloboatnova is offline
PostPosted: Mon Jul 12, 2010 5:35 am    Post subject: Reply with quote
GhiaBateman wrote:
yeah...
that sure looks like a bent spindle to me... I'd think if you bent the wheel itself like that, the welds would have popped...
your baja has come out real nice, I like the orange, which orange is that??
I know for sure the wheel was bent and i'm hoping the wheel was all that was bent. We had to bend it back to get the baja home. The orange is a GM color called sunburst orange. It was made by PPG.
Thanks yall for the compliments.
Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja
sloboatnova
PostPosted: Sun Aug 15, 2010 3:51 pm    Post subject: Reply with quote
A few poser pics from Disney, Ok 8-14-10.
Here's Travis's Baja. This is the second time we have had it out since gettin it ready. It did pretty good.
The event was "Wheelin for the wounded". It was to raise money for wounded Veterans that depend on non-profit organizations for help. We painted the car red white and blue and had all the vet's that showed up sign the trunk lid.
3BT Baja build page
sloboatnova
PostPosted: Mon Aug 16, 2010 6:53 pm    Post subject: Reply with quote
I forgot to mention that I broke a ball joint while hittin some trails in the woods. Don't know why though? I have limit straps keeping it 1/2" from full drop. It pulled the joint right out of the socket. Fortunately, I had spare control arms on hand. Took Travis and I 17 minutes to swap it out.
Any idea's on why it broke out?
3BT Baja build page
Lanceonthelake
Lanceonthelake is offline
PostPosted: Tue Aug 17, 2010 12:56 pm    Post subject: Reply with quote
what wheels are those?
Lotrat
Lotrat is offline
PostPosted: Tue Aug 17, 2010 1:41 pm    Post subject: Reply with quote
How old was it? Was the boot split at all?
sloboatnova
PostPosted: Tue Aug 17, 2010 8:03 pm    Post subject: Reply with quote
I've been told they are old Jackman wheels, but I haven't confirmed that. Next time I have them off, I am going to look closely for some markings. They were on the car when I bought it.
3BT Baja build page
sloboatnova
PostPosted: Tue Aug 17, 2010 8:05 pm    Post subject: Reply with quote
I put all new ball joints in last fall. I've only been wheelin about 6 or 7 times. The boot was split.
3BT Baja build page
Volksmeister
Volksmeister is offline
PostPosted: Thu Aug 19, 2010 9:39 pm    Post subject: Reply with quote
HAHA Thats funny, I cracked off a piece of my front fender from the front tires hitting in EXACTLY the same shape.... I trimmed them up, no probs. Looks like a fun time.
-Levi
Lotrat
Lotrat is offline
PostPosted: Thu Aug 19, 2010 9:59 pm    Post subject: Reply with quote
It's not often you find someone who knows how old their broken ball joint it. Once the boot splits, it fills with dirt and sand and wears in no time. Add a little off-roading fun and they go pop.
Once I get a little in and out movement out of mine then I replace them. Not worth the headache.
Jackman wheels will have a "J" on one of the spokes.
sloboatnova
PostPosted: Wed Oct 20, 2010 5:59 am    Post subject: Reply with quote
After busting a ball joint last time I went out and not having a jack, I got me a 48" farm jack. I mounted it to the rear bumper. Gotta be prepared.
3BT Baja build page
pafree
pafree is offline
PostPosted: Thu Feb 03, 2011 11:48 am    Post subject: Reply with quote
sloboatnova wrote:
I would like to make is to find a way to secure it tightly that won't require a wrench to remove it. I might try to find some large wingnuts if I feel they will not loosen up..
maybe make a small version of a spare tire wing nut that you could put a pipe on the wing to turn it off and tighten. add a spring or sponging piece of rubber under the jack so when you tighten it then the spring would apply pressure and just add a clip encase the nut backs off.
sloboatnova
PostPosted: Thu Feb 03, 2011 12:41 pm    Post subject: Reply with quote
Thats a good idea. I could weld some steel to the nuts to make it like the large wingnut in your pic, but not so big. Then drill holes in the steel that I could tie together with a cable so they can't back off. I have some extra rubber pads that go between the front beam and the body that would be perfect.
3BT Baja build page
sloboatnova
PostPosted: Sat Feb 12, 2011 10:02 pm    Post subject: Reply with quote
So, today I bought a used Weber progressive 26/27 with intake. I put in on and drove a few miles to check it out. It definitely has more juice than the 34 pict solex. Hopefully it will hold up better on the trails too.
Now I need to figure out what I want to do for the air cleaner. I like the one I have, but it doesn't fit the progressive as it has an odd shape. I am considering using the adapter in the link. I could either use it to attach my old filter, or I might plumb my air inlet into the cab. I'm wondering if this adapter restricts air flow? Any input?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12-1529
Does anyone have they're air inlet plumbed into the cab? If so, some pics would be nice. I'm curious how loud it might be.
3BT Baja build page
sloboatnova
PostPosted: Sun Mar 06, 2011 8:07 am    Post subject: Reply with quote
Makin some progress. Travis and I modified my trailer to hold 2 baja's.
Should be safe after I tied em down all around.
We also fabricated mounts for my new winch. We welded the mounting plate to a reciever so that it doesn't stay mounted when not in use.
storage mount
We also put a different steering box on as I couldn't get the play to go away. I also put an Weber progressive to 2 stage air cleaner adapter on so I could keep my good filter. I'll post pics later.
3BT Baja build page
sloboatnova
PostPosted: Tue May 31, 2011 9:58 am    Post subject: Reply with quote
Went wheelin this weekend and broke another lower ball joint. It was the other side this time. This is getting old quick. I have limit straps on the front, but the joint pulled right out of the pocket. Before I started wheelin, I replaced all of the ball joints. Could it be that maybe I didn't clock them in the right direction? Maybe my limit straps need tightened due to stretch or poor attachments? Does anyone make a ball joint that is supposed to be stronger than stock?
3BT Baja build page
X-jeeper
X-jeeper is offline
PostPosted: Tue Apr 17, 2012 2:58 pm    Post subject: Reply with quote
i just found the baja im gona model mine after...when i get one! Love the look of it!
thext94
thext94 is offline
PostPosted: Tue Apr 17, 2012 6:56 pm    Post subject: Reply with quote
Interesting that your breaking balljoints so frequently, I am yet to have any problems with mine, and I like to think I beat it pretty hard. I realize this post is old so you may have solved the problem by now, but maybe tightening the straps like you said would help
Tyler
cmiller95
cmiller95 is offline
PostPosted: Tue Apr 17, 2012 8:55 pm    Post subject: Reply with quote
you could change to a hook and rod setup
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
sloboatnova
PostPosted: Mon Nov 03, 2014 8:10 pm    Post subject: Reply with quote
Haven't updated this for a while but this baja keeps gettin better. I built a 1915 for it.
Specs
AS41 case case drilled and tapped for full flow
CB Perf CW / cross drilled crank / 8 dowel
Scat 5.5" rods
Mahle 94mm jugs
Engle 110 cam and followers
DRD 049 heads 40/35.5
single Weber IDF44
glenns rebuilt 019
CB perf maxi30 pump and 1.5qt slimline sump
Trimil sidewinder
This thing hauls but now. I doubled my power!!! Its almost scary.
3BT Baja build page
Page 2 of 3
