Narrowed Beam Tutorial (Super long post)
Page: Previous  1, 2
don.ville Premium Member
Samba YardMan
don.ville is online now
PostPosted: Tue Sep 29, 2009 5:15 am    Post subject: Reply with quote
rizzag wrote:
******this only works this way on early beams with bakelite bushings(63 and earlier i believe) later beams(64 to 67) with needle bearings have a ledge behind them and can not be knocked in the beam******
just didnt want someone with a later beam getting into something they cant finish or worse.
jeff
Can I do the above and use the bushings that Wagenswest sells for a 67 beam?
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Glenn A
Glenn A is offline
PostPosted: Tue Sep 29, 2009 3:12 pm    Post subject: Reply with quote
Nates Bushings will fit in the tube after You remove the bearings or bushings. If your beam had bearings You would also have to pull the bearing race off of the trailing arm. There are four of them.
I think the area where the bearing sits is wider. You may have to narrow the beam a bit by cutting off that end piece,
mannys66 wrote:
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it.
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R
technowar
technowar is offline
PostPosted: Fri Dec 11, 2009 9:51 pm    Post subject: Reply with quote
I know this is a lame question.. How did you cut the beam?
Glenn A
Glenn A is offline
PostPosted: Sat Dec 12, 2009 8:09 pm    Post subject: Reply with quote
I gave up on cutting old beams. It's easier to build a new one using the old one for the centerpin mount.
But a grinder with a cutoff wheel and a sawzall will work. Plazma cutter helps too.
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R
technowar
PostPosted: Sun Dec 13, 2009 5:54 am    Post subject: Reply with quote
Mind asking how you can make a new beam from the old beam?
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sun Dec 13, 2009 10:14 am    Post subject: Reply with quote
Buy new tubing and sideplates. Then use your centerpin housing and center blocks from your old beam.
Spanner67
Spanner67 is offline
PostPosted: Sat Feb 04, 2012 10:16 am    Post subject: The idiot book/look.... Reply with quote
There are some of us out there...not me...er...well...some of us that know nothing about machining/narrowing/lowering, etc. But do have some welding skills. Is there current information on how to get kits to do the adjustable beam instead of ordering one? All sorts of other questions. Narrowing two inches seems simple enough....but...Does the idiot book simplify some of these issues? Where can a person get one of those?
Page: Previous  1, 2
Page 2 of 2
