DeVertible Samba Member
Joined: May 23, 2013 Posts: 85 Location: Sequim, Washington
Posted: Fri May 22, 2015 8:42 am Post subject: |
Sorry about the multi pixs. My hand must have stuttered does have correct lid. 1987 restoration of an original Lake Tahoe based vehicle. I have adjusted valves at .006. The charging system does seem suspect as I drive last night's with lights on and I get a faint gen light. Got trickle on the battery while away. Will re visit issue Monday |
Johnous Samba Member
Joined: August 14, 2014 Posts: 89 Location: Austin, TX
Posted: Fri May 22, 2015 9:06 pm Post subject: |
Very interesting. . . Wow. Thanks, another possibility. |
Posted: Fri May 22, 2015 9:08 pm Post subject: |
Posted: Mon May 25, 2015 5:24 pm Post subject: |
Update; It is not the condenser, nor the fuel pump rod binding. I replaced the condenser and checked the actuator rod for freedom. Replaced coil with a used one and replaced the regulator with a new one which did solve the dim idiot light issue so that's good. I do not think it is vapor lock either, as it will not start with starting fluid or added gas to carburetor. I am coming to the conclusion it is simply a flooding problem. It will start using the standard 'open full throttle' to let things dry out and vaporize after sitting for thirty minutes or so. wish they made a 6 volt idle shut off. Has anyone tried to operate a 12 volt unit successfully on six volts? It just may be as good as it gets. Ever here the song; 12 Volt Man by Jimmy Buffet? I think that's me |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26071 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 25, 2015 5:46 pm Post subject: |
Idle shut off only helps to keep engine from running on after shutting down a hot engine. Will not stop flooding due to carb/fuel pump getting heated up. _________________ In Stereo, Where Available! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Mon May 25, 2015 8:29 pm Post subject: |
If you're really serious about operating a 12v shutoff solenoid in your 6v car, there are 6 to 12 volt power inverters available for purchase that'll do the job, just be warned that they aren't terribly cheap. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed May 27, 2015 6:09 pm Post subject: |
FYI. . . Installed 12 volt idle cutoff after testing on 6 volt battery successfully. It operated most of the time but would stop holding occasionally and the engine would quit. Pretty simple unit . A guy could make a living rewiring the coils |
Posted: Sat Jul 18, 2015 7:26 am Post subject: follow up to hard starting issue |
Installed correct 1967 pict -1 carb, 6 volt idle cut off and correct 1966 67 vacuum advance dist. Starts first crank. Happy Guy |
Posted: Sat Jul 18, 2015 7:27 am Post subject: follow up to hard starting issue |
Posted: Sat Jul 18, 2015 12:42 pm Post subject: |
Most excellent!! Thanks for updating us all. _________________ In Stereo, Where Available! |
