HowTo: 1995 Eurovan Camper - MAP Sensor Replacement
Page: Previous  1, 2
Forum Index -> Eurovan Share: Facebook Twitter
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Wed Jun 19, 2024 12:48 pm    Post subject: Re: HowTo: 1995 Eurovan Camper - MAP Sensor Replacement Reply with quote
1961tbird wrote:
Replacing the MAP sensor mad a huge difference but now the engine idles fast (2000 RPM) and idle Fluctuates (low/high) whether engine is hot or cold.
Kinda stumped now
I would go and check all the basics:
1.) Do the temperature sensors (coolant and IAT) measure correctly? Verify with VCDS.
2.) Is the timing set right? The correct procedure is a real pain. Make sure you've done it right. There are reports of this symptom with ACU engined vans when the timing isn't set right.
3.) Is the idle air control solenoid clean? Sometimes they get gunky and stick, causing this sort of thing.
4.) Has anyone messed with the basic idle screw on the throttle body? It should never need adjustment, and should be sealed with a paint dot, but you never know.
5.) Are there any intake leaks?
1961tbird
1961tbird is offline
PostPosted: Wed Jun 19, 2024 1:49 pm    Post subject: Re: HowTo: 1995 Eurovan Camper - MAP Sensor Replacement Reply with quote
Many thanks. Will report back
bcolins
bcolins is offline
PostPosted: Tue May 13, 2025 10:12 am    Post subject: Re: HowTo: 1995 Eurovan Camper - MAP Sensor Replacement Reply with quote
Excellent tutorial! Thanks for taking the time to take the photos and write up the procedure.
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: Previous  1, 2
Page 2 of 2
