Gauche1968 Samba Member
Posted: Thu May 23, 2024 1:35 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Finally, some photos. I tested the relays under the dash today. The one on the right in the photo is resposible for the blower fan operation. I was able to test all three existing relays by swaping in a know good fourth relay and moving each existing relay to this position. Fans operated with each relay. So, at least in that function they are all good. Still, there is no power on the wire to the compressor: engine running or not; with either the fan switch or the temperature switch in the on position. _________________ 1984 Vanagon GL
1984 Vanagon Westy |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
djkeev Samba Moderator
![](/vw/forum/images/avatars/12219921954d8bb2ffebb54.jpg)
Joined: September 30, 2007 Posts: 32761 Location: Reading Pennsylvania
Posted: Thu May 23, 2024 6:28 pm Post subject: Re: Resurrecting Early Overhead A/C? |
djkeev wrote: |
You may find this thread helpful, or the many links within this thread...... |
Thanks,
Was there a link you meant to include? _________________ 1984 Vanagon GL
Posted: Fri May 24, 2024 5:20 am Post subject: Re: Resurrecting Early Overhead A/C? |
Ha, I actually posted in that thread! ![Very Happy](images/smiles/icon_biggrin.gif) _________________ 1984 Vanagon GL
jlrftype7 Samba Member
Posted: Fri May 24, 2024 5:24 am Post subject: Re: Resurrecting Early Overhead A/C? |
Saturday is meant to be dry. I'll take our Vanagon apart and trace the power output wire from the Compressor backwards to the A/C controls/Fusebox and report back in the late afternoon. Tonight is supposed to be very wet, so no go for working out in the Street with our Parked Vanagon...
Although, has Vanis13 already done this while overhauling and updating their A/C system? Just wondering. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri May 24, 2024 5:59 am Post subject: Re: Resurrecting Early Overhead A/C? |
jlrftype7 wrote: |
Although, has Vanis13 already done this while overhauling and updating their A/C system? Just wondering. |
Wow, thanks! The furthest I have been able to trace it so far is from the compressor to the driver's wheel well, where it disappears into a taped bundle of wires that run over the gas tank one direction and up into the passenger cabin to the evaporator housing in the other direction. I haven't tried to separate the tape yet to see which way the compressor wire heads, but I imagine it it to one of the relays under the dash? _________________ 1984 Vanagon GL
vanis13 Samba Member
![](/vw/forum/images/avatars/11683102905c9324b6058a4.jpg)
Joined: August 15, 2010 Posts: 3279 Location: ABQ NM USA.... Except when not
Posted: Fri May 24, 2024 6:43 am Post subject: Re: Resurrecting Early Overhead A/C? |
jlrftype7 wrote: |
To be clear, I am not familiar with the overhead AC system so can't directly comment.
In any system however, there is something that tells the compressor to go on....and then there's at least one thing that tells the compressor to go off and there could be several things to tell the compressor to go off.
On - temp switch/rheostat/potentiometer that selects temperature tels the controller unit that switches the AC (and related items) on and off as needed.
The ON signal then can go through (though the early vans don’t typically have 1 and 2):
1) a low pressure switch that will prevent the current flow to the compressor if the pressure is not high enough. This is to prevent the compressor to run in low pressure situations since it needs enough pressure (refrigerant with the right amount of oi) to lubricate the compressor otherwise it will self-destruct.
2) a high pressure switch which will not let current pass if pressure is too high so the system doesn’t blow gasket
3) (and the early Vanagons DO have this) is a temp sensor at the evaporator to prevent freezing which talks back to the controller to tell the compressor to turn off when the evaporator gets close to freezing.
Your situation sounds electrical and tracing the wires would be the step I’d be doing at this time if it was my system. I don't recall Bentley having an electric diagram for the overhead units but I may have missed it. Ultimately hands-on seeing the wires for yourself and tracing wires and checking voltages is what it may take.
This thread has some pics and based on those, I’d start at the dials and see that the compressor on signal is actually being generated because if not, tracing the compressor wire forward will just have you end up here with the cart torn apart. Start here and if it does generate that signal, maybe run a long jumper to compressor and see if it acts like it should.
Depending on the controller type, you may have to concurrently look at the evaporator temp sensor to make sure it is not stopping things but luckily that’s simple since either disconnecting the two leads or connecting them together (try both) will let the system think that the evap is NOT close to freezing and will let compressor signal flow.
Start at the dials and check voltages to/from there.
Hopefully this is helpful for your case.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7147084
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Fri May 24, 2024 11:30 am Post subject: Re: Resurrecting Early Overhead A/C? |
vanis13 wrote: |
jlrftype7 wrote: |
Right, since I do get power out to the Compressor, even though ours is removed for the time being as I slowly make progress on other items beside rehabbing our A/C system, I suspect we'll find an open circuit on the OP's vehicle- Possibly Rodent Damage...
But at least we might all learn the wire colors of the Dealer Installed system[ if they kept to the same harness/Kit over the brief few years it was a Dealer or Port installed system before VW finally got into the act with Factory Air.
I really need to get back to ours. I have the GoWesty Cond kit, new receiver-drier, A/C hose crimp kit to make my own hoses/crimped ferrules once I buy the newer Barrier type hoses.
Already Oiled the Evap Blower, so that's done- But, need to flush the Evaporator and overhaul or clean out the Compressor as well.
Just need to find the time to do all of this... ![Rolling Eyes](images/smiles/icon_rolleyes.gif) _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
xflyer Samba Member
Posted: Sun May 26, 2024 4:01 pm Post subject: Re: Resurrecting Early Overhead A/C? |
These 'add-on' aftermarket AC systems are usually all electro-mechanical. As someone described it, the temp control knob changes the tension on a spring. The spring is push-pulled by the pressure of a diaphragm. One side of the diaphragm has refrigerant on it that travels through a tube that has its end in the evaporator. As the temp of the evaporator changes, that changes the pressure in the tube and at the diaphragm. When the temp knob is rotated clockwise ("colder") the spring tension is changed and the switch contacts will engage sending power to the compressor clutch.
The electrical part is a 'series' circuit. If the fan switch is "OFF" no power goes anywhere. Switch the evap fans to any "ON" speed and power goes to the fan motors and the temp control. If the system has not been running for a minute or more, no matter where the temp control is set, the evap is likely warm enough to engage the switch in the temp control and the compressor should engage.
What looks like the sense tube for the temp control is in one of the photos near the black plastic piece. It is coiled up and would be long enough to go back through the overhead duct and be inserted into the evap fins.
There could be a low pressure switch somewhere. Usually the switch is on the filter drier. It could be anywhere in the refrigerant lines. Just need a fitting for it to screw into.
Need to trace the wiring with a test light or voltmeter.
BTW many of these aftermarket systems from VPC (Volkswagen Products Corp) or DPD had wiring that was all black insulation. Much harder to trouble shoot/trace.
Which leads me to think that the red wire going to the compressor clutch was a later repair or add on. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C |
Posted: Mon May 27, 2024 6:48 am Post subject: Re: Resurrecting Early Overhead A/C? |
I had a chance to do some wire tracing yesterday, which involved peeling back a lot of 40 year old electrical tape:
There are three wires coming from the evaporator housing area into the driver's wheel well: a small gauge green wire, a similar gauge red with black stripe and a larger gauge black with red stripe. These three then run together with the small gauge solid red wire coming from the compressor in the wheel well.
These four wires meet up with two solid red wires coming directly from the hot post on the battery. One is a heavier gauge than the other. All six wires then run concurrently up to the front of the van then into the dash where they travel various paths to the two spade fuses or the three relays.
The two red wires coming from the battery terminate in the spade fuse holders. I measured voltage here and there is only 9.6 volts at both holders, compared to 12.2. volts on the solid red wires at the battery box.
That is as far as I have gotten. _________________ 1984 Vanagon GL
Posted: Tue May 28, 2024 12:55 pm Post subject: Re: Resurrecting Early Overhead A/C? |
A little more progress today: I verified the solid red wire to the compressor is good, by applying 12V directly from the battery at the end that terminates at the relay connector under the dash and I got 12V back at the compressor, so thankfully no need to run a new wire there. Also, the two red wires directly from the battery to the relays are providing battery voltage to the two relays they connect to through the spade fuses, when using a good ground for the multimeter.
I still have no voltage at the relay connector that contains the compressor wire under any condition. This connector contains the compressor wire, a ground, a red and blue wire to the radiator fan wiring and a red and black wire, which I assume is the one that travels back to evaporator housing. I am able to get 12v to this connector, by jumpeing the red and black wire from the neighboring relay to the red and blue wire at the connector to the radiator fan wiring and turning the evaporator fans on, but this does not trigger the relay to send voltage to the compressor wire.
Which post on the 5 pin relay generally carries voltage into the relay? Is there one that is usually the signal post? _________________ 1984 Vanagon GL
Posted: Tue May 28, 2024 1:56 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Gauche1968 wrote: |
Which post on the 5 pin relay generally carries voltage into the relay? Is there one that is usually the signal post? |
85 or 86, depending on who wired it, will be your Coil power and the ground for the relay. If there's a diode in the relay internally, flow will matter in terms of direction.
30 will be Battery or Load power to Relay. 87 will be Load out of the Relay to whatever you're running. In this case, your Comressor.
If you have an 87a and 87b set-up, are all 5 pins wired to a wire on your harness?
So, black or Brown wire will be your Ground for the Relay[ Brown would be German wiring color for a Ground Circuit, but aftermarket A/C wiring could well be Black for ground if put together in the USA]
NOTE- I have NOT forgotten about pulling our Vanagon apart for wiring check. Our Vanagon acted up on the starter circuit yesterday, so now I need to verify Neutral Safety Circuit and Ignition Switch functions since we are planning to go to Michigan this coming Saturday and don't want to be stranded with an inop starter motor.
Of Course the Battery tested good, so the easiest thing to access and replace is not the issue...
I suspect the Neutral Safety Switch, since moving the shifter back and forth a few times finally got the Starter Solenoid Circuit working again, while in Neutral.
Haven't tested the starter motor again, have to do that tonight after work- which means all be probably work fine without a HINT of hesitation....
At any rate, I have both a Porsche Ignition Switch on hand, and GOWesty Neutral Safety switch parts as well if needed. Starter Motor is like 2 years old TDI withy RMW adapter plate upgrade.. Hope THAT didn't start to act up... ![Mad](images/smiles/icon_mad.gif) _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Tue May 28, 2024 3:13 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Here is how that relay I am having trouble with is wired: Pin 87 is not used, Pin 87a is the compressor wire. Pin 30 is the red and black wire from evap housing (I am assuming this from the fan or temp switch), pin 85 is ground and pin 86 is the red and blue wire to the radiator fan. There is no source of constant 12 volt power. The red and blue wire runs to a two pin connector to the rad fan where it meets the red and black wire from the neighboring relay, which provides power to turn on the rad fan, when the evap fan switch is turned on. I thought maybe power would back feed to the relay from the red and blue wire but, no dice. This relay does not appear to have a power source with how it's curtebtly wired. _________________ 1984 Vanagon GL
Posted: Tue May 28, 2024 7:09 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Okay- that gives me something to follow along and possibly match with our A/C system. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Wed May 29, 2024 5:41 am Post subject: Re: Resurrecting Early Overhead A/C? |
So, there is this wiring diagram in the Bentley. It's not an exact match to my system, but it is close. I don't have any idle stabilizer valves, and some of the wire colors don't match what I have, but the basic lay out is the same.
The trouble seems to be with the "AC Compressor Cutout Relay." I don't see how power gets into this relay. Pin 30 is connected to a red wire with black strip that comes from the evaporator housing. The diagram says this is coming from the thermostat, but where does the thermostat get power? Also, the diagram says the red wire with blue stripe on pin 86 goes to the Radiator fan relay, but that doesn't seem to be the case on mine. It goes towards the radiator fan itself. There is a seperate red with blue wire from the rad fan relay also. Unless those two wires are joined somewhere? At any rate, I am not sure what it's purpose is. _________________ 1984 Vanagon GL
Posted: Wed May 29, 2024 12:58 pm Post subject: Re: Resurrecting Early Overhead A/C? |
30 is from the Temp switch, after IT gets it from the Evaporator Switch. SO, EVAP fan switch on, sends power next door to the Thermostat adjustment assembly. IF, the sensor bulb allows the power to come out of the Thermostat by deeming the EVAPORATOR is getting warm enough to turn on the Compressor.
The Compressor Cut-out relay is used to TURN OFF the Compressor. Now I see the Pin arrangement. AT rest, the relay normally ALWAYS sends power out via the 'resting' contacts inside the relay.
Once the relay is powered up, that moves the contacts away from the rest position, turning off the Compressor power.
So, you should be able to drop the front Duct Section to access your two switches, and see why you HAVE Fan Control, but no power out to the Compressor from the T-stat, if you haven't done this yet.
In my NOTES ON EARLY SYSTEM thread, you can see the mess of wiring for those two controls, shown in one picture since I have the duct all apart. Since there are TWO legs OUT of the A/C thermostat, and you are showing 2 connectors before the wire gets to the A/C cut off relay, you might have an open circuit there, or a mouse damaged wire. I thought you said the Radiator Fan was coming on LOW correctly when selecting A/C on. That SHOULD mean your A/C thermostat works correctly for the leg going DOWN to the Cooling Fan Relay in the diagram. 86 coil power to that relay.
Last NOTE- you MAY, or MAY NOT, have issues with idle load and A/C compressor LOAD being on, AND NOT having the Vacuum 'IDLE UP' or Idle Speed Stabilizer vacuum valve mounted on the rear firewal of the engine, behind the Intake Boot area. If you DO have one of those vacuum valves, you will get an increase in idle speed of the engine, to assist in keep the engine from dying out at idle with the increased load of the A/C compressor engaged.
Picture of the wiring, notice the use of SCOTCH LOCK 3M wire connectors? These are notorious for open circuits or voltage drops as they age, or loosen up in tension on the wires they're crimped through. Your issue could be as simple as one of these failing.
Posted: Wed May 29, 2024 2:35 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Thanks jlrftype7,
Yes, I just got through dropping the control panel and the "wind tunnel section." There is power on the green wires at the connector that runs from the fan switch to the thermostat switch when the fans are on. There is no power "coming out" the other contact on the thermostat switch, to the solid red wire, which becomes a red with black stripe further in its run to the compressor cut out relay," with the thermostat turned on. Mechanically, the switch seems to function fine, but there is no "signal out" to the compressor relay. So, is this a bad switch? _________________ 1984 Vanagon GL
Posted: Wed May 29, 2024 2:44 pm Post subject: Re: Resurrecting Early Overhead A/C? |
"30 is from the Temp switch, after IT gets it from the Evaporator Switch. SO, EVAP fan switch on, sends power next door to the Thermostat adjustment assembly. IF, the sensor bulb allows the power to come out of the Thermostat by deeming the EVAPORATOR is getting warm enough to turn on the Compressor.
Once the relay is powered up, that moves the contacts away from the rest position, turning off the Compressor power. "
Yes, but what sends the signal to this relay to "turn on" and thus turn off the compressor? Is it the removal of power to terminal 30 when the thermostat switch turns power off? Also, I am not sure what the purpose of this relay's connection to the high speed rad fan relay is?
And yes, the low speed rad fan comes on with the evap fan. That relay gets power on the green wire that starts at the fan switch and then "makes a stop" on one leg of the thermostat switch, before traveling down to the radiator fan relay. _________________ 1984 Vanagon GL
Posted: Wed May 29, 2024 4:52 pm Post subject: Re: Resurrecting Early Overhead A/C? |
Gauche1968 wrote: |
And yes, the low speed rad fan comes on with the evap fan. That relay gets power on the green wire that starts at the fan switch and then "makes a stop" on one leg of the thermostat switch, before traveling down to the radiator fan relay. |
High Speed Radiator Fan Circuit turns off the Compressor via the Cut Out Relay. Go all the way to the left side of your diagram. Out of the thermostat Fan switch, you are sending power to the High Speed Fan Relay coil/86 pin. This also then feeds the coil power/86 of the Cut Out Relay, turning off the A/C compressor since the coolant got hot enough to warrant kicking the fan level to high, versus the constant Low speed circuit of normal A/C operation.
In the Radiator fan, for the early Vanagons, they’re just 2 speed.
There is an internal resistor for the low side circuit, your ‘quieter’ cooling mode that drops voltage to power the radiator fan.
High Speed is straight vehicle operating voltage, so you’ll know it if it ever came on for you…. ![Laughing](images/smiles/icon_lol.gif) _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
