croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1169 Location: Western Washington State
Posted: Tue Nov 04, 2025 10:06 pm Post subject: Re: Engine Run-In Stand: WIRING |
Here's a pic of my engine, and my redneck wiring job. I did it this way to crank for oil pressure. For clarification: To get it to fire I need to run a wire from the positive side of the solenoid to a positive terminal on the coil. Is that right? So where the red jumper cable is attached to the + of the coil?
_________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20895 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Nov 05, 2025 7:54 am Post subject: Re: Engine Run-In Stand: WIRING |
Did you miss this pic from a earlier post....
_________________ “Fear The Government That Wants To Take Your Guns"
Posted: Wed Nov 05, 2025 9:26 am Post subject: Re: Engine Run-In Stand: WIRING |
Dale, thank you, yes I did see that, but it’s way more than I need. I don’t need to run the alternator, idiot lights, etc. All I need is juice to the starter (check), juice to the fuel pump (check), and juice to the ignition. And that’s the part I’m trying to confirm. I could probably figure that part out by looking at the diagram you provided. _________________ Please check my '67 sedan project progress!
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11517 Location: Oregon
Posted: Wed Nov 05, 2025 10:11 am Post subject: Re: Engine Run-In Stand: WIRING |
| croSSeduP wrote: |
| Dale, thank you, yes I did see that, but it’s way more than I need. I don’t need to run the alternator, idiot lights, etc. All I need is juice to the starter (check), juice to the fuel pump (check), and juice to the ignition. And that’s the part I’m trying to confirm. I could probably figure that part out by looking at the diagram you provided. |
Dude, you're over/under thinking the power to the coil issue.
Simply, place a jumper on the positive cable on the starter and jump it to the #15 post on the coil and you'll have power to the ignition on the engine.
I bought a set of 10 jumper wires from a computer store a few years ago and run all my fresh engines with them when bench starting them. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Wed Nov 05, 2025 11:42 am Post subject: Re: Engine Run-In Stand: WIRING |
| croSSeduP wrote: |
THen don't run them go minimalist... Connect battery and connect coil to a powered switch or just a jumper wire.... _________________ “Fear The Government That Wants To Take Your Guns"
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80383 Location: Sneaking up behind you
Posted: Wed Nov 05, 2025 11:47 am Post subject: Re: Engine Run-In Stand: WIRING |
| Dale M. wrote: |
| croSSeduP wrote: |
THen don't run them go minimalist... Connect battery and connect coil to a powered switch or just a jumper wire.... |
That's what I do, nothing fancy, just get it done. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
