Another Pickle Post - 1973 Squareback
Page: Previous  1, 2, 3 ... 11, 12, 13, 14  Next
Scotty D
Scotty D is offline
PostPosted: Fri Jul 11, 2025 2:46 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I was going through some old photos and found this one, early 80's, of me and my friends building a launch ramp in the driveway. I'm the Tony Hawk haircut-havin' homeboy with his hand on the platform, 3rd from the left.
You can just make out the front end of my first car, a clementine '72 FI automatic Squareback. Ahh, the memories...
Scotty D
Scotty D is offline
PostPosted: Sun Jul 13, 2025 3:25 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Reinstalled the air cleaner with some fresh oil, and reconnected the starter/ignition cable (after removing the remote starter). Turned the key, got the fuel pump going, she started right up and idled nicely. Went through the gears lightly while up on Jack stands in the driveway. All of them work Very Happy
Now down to the FLAPS for some fresh oil. I’m going to replace the solid cover plate that came on the ‘73 and replace it with one that has a drain plug. Just seems cleaner/easier for future oil changes.
Scotty D
Scotty D is offline
PostPosted: Sun Jul 13, 2025 8:05 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Got the stuff for the first oil change. Surprisingly the oil in the engine was extremely clean, and clear. No sign of gas or any sludge. The previous owner must have done some work on it recently.
The original oil cover plate had orange RTV caked between it and the engine case. No bueno
So all of that came off. The strainer was clear of debris. Got all of the supplies set up.
Got it all cleaned up, no leaks after a quick warm up. Then took it for a drive finally!!!
https://youtube.com/shorts/qpUhr_-bocc?si=CpBvk3KNnf2X58zK
Scotty D
Scotty D is offline
PostPosted: Fri Jul 18, 2025 6:35 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I figure it’s never too early to stock up on spare parts. Got a great deal on all of this right here on The Samba.Thanks WheeliePete!
Bobnotch
Bobnotch is offline
PostPosted: Sat Jul 19, 2025 12:34 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Some spares are good to have. You might want to check the AAR valve, as it can be leaned up to be used almost right away. That one is a mechanical version, and they usually work better than the electric one. You can test the injectors too, and maybe build a test harness to use the distributor to fire off the injectors. But you can hose them up and see if they leak, or hold pressure. I had a guy send me a bunch of used injectors, and I sat down one day and tested them using a spare dist to fire them (aimed into peanut butter jars, and using the cars wiring harness to fire them. Turned out only one injector was bad out of the 12-15 in the box. Well worth checking, and then cleaning off the old hose stubs so they were ready for use again. Some of the rest of the bits you'll need a spare engine (long block) to use on. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Scotty D
Scotty D is offline
PostPosted: Tue Jul 22, 2025 12:40 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I had posted earlier that there was a vacuum hose connected to the bottom of the oil breather and running to the IAD, as shown in the diagram (in red). I was mistaken, as there is a nipple beneath the oil breather, but no hose, and seemingly nowhere to connect one at the IAD.
Does anyone have any experience with the '73 system that could shed some light on this? There is a bung on the air intake which has no obvious purpose (marked #2 in the third image), but it doesn't seem like a hose would have run from below the breather up around it and over to the intake.
EDIT* I looked through some older photos and remember now that there was originally a hose running from the bung on the air intake all of the way across the engine towards the "firewall" near cylinder 3, and through the opening to the charcoal cannister located beneath the load floor just above the tranny. Which seems weird, as I thought that that was supposed to lead to the bung in the elbow of the exhaust? So I'll just cap that off, along with the bung on the right edge of the oil bath air cleaner that used to have a hose running to the other end of the charcoal cannister.
Here is my breather configuratin:
I think this is an earlier setup...
FastyOrange
FastyOrange is offline
PostPosted: Tue Jul 22, 2025 4:24 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I have a 72, which should be fairly similar to your 73 (no promises). I'm guessing you have some mismatched parts in your engine bay making things confusing for you. Can you post some photos of your engine to help us all look and see what doesn't make sense? Overall shot, closer shots of items that seem wrong or incorrect? I believe I can help with figuring what is right and what isn't and may even be able to provide you with parts to correct problems depending on your needs.
You might also want to start checking your fuel injection parts to make sure they are the correct part numbers for your system (ECU, pressure sensor, tvs, etc). Tram has a chart posted on here with part numbers for each version of FI.
Jon
72 FI Fastback
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 23, 2025 1:32 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Jon
Yes, your 72 will be closer than his last pic of the 68-70 system he posted above (last pic). If I remember correctly, there should be a plastic PCV valve under the small cap that should have a hose to the intake plenum (vacuum source for the valve). According to Ray, these valves have a tendency to leak, and cause weird idle fluctuations. He usually recommends gutting the valve, and adding a block with a 1-3mm hole drilled in it in the hose to get a consistent stable vacuum. It's been a while (a couple of years now) since this sort of thing has been discussed on here, which is why I can't remember which size hole he recommended you use. According to him, the valve would sometimes open at the wrong time throwing the system off in a funky way. By adding a block with a hole in it, it would keep the vacuum stable and eliminate the erratic opening of the valve on the system.
I really don't have any experience with the late system 2 cap breather box, other than knowing that it can cause some troubles with oil leaks if it isn't hooked up correctly. It's also why most people go to the single cap breather box, when they go to carbs on the late engines, due to not pulling enough vacuum to keep the oil inside the engine. Carbs and the 2 cap breather cause oil to be forced out behind the big fan at the case, because the carbs don't make enough vacuum. I hope this helps.
Tram wrote:
Tram wrote:
FastyOrange
PostPosted: Wed Jul 23, 2025 3:27 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I think the last time Ray posted about it, even he said 1-3mm! Regarding the pcv connection on the bottom of the oil breather...there should be a metal tube that bends around the right side of the IAD down below the intake runners. That is what the fitting on the bottom of the oil breather connects to. My car and parts are all in storage right now (long story), but I can look for a photo of this detail tonight. If I don't find any photos I will be heading to storage this weekend and I can grab some pics.
Jon
72 FI Fastback
FastyOrange
PostPosted: Wed Jul 23, 2025 5:49 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
I found this photo of a spare IAD that I am pretty sure came off of either a 72 or 73 type 3.
The tube bending around from the back cover of the IAD is where you will connect your crankcase vent valve. Pay no attention to the TVS that is installed in that photo, it came from a Volvo and I was seeing if it fit for a custom application. You can also see the threaded hole for the temp sensor in front of the intake runners. I believe that location should be the same for your year. I hope this helps!
Jon
72 FI Fastback
Scotty D
Scotty D is offline
PostPosted: Fri Jul 25, 2025 11:47 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Jon
Thanks for the pic, I’ll look again when I get back from Portland, but I’m pretty sure that tube doesn’t exist on my IAD.
FastyOrange
PostPosted: Sat Jul 26, 2025 5:13 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Portland is a lot of fun. Have a great time! I did do a quick check and there are a few of the late style IADs in the classifieds if you end up needing one. Normally, I would offer my spare...but it appears to have had a very hard life and I wouldn't trust it to be a decent unit. I think it will be a permanent mock-up use item.
Jon
72 FI Fastback
Scotty D
Scotty D is offline
PostPosted: Thu Jul 31, 2025 9:48 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Thanks guys.
Home from Portland, I’ll dig into it tonight and take some pics.
Meanwhile I’ve gotten her one step closer to road-worthy by installing a functioning horn. Meep Meep.
Scotty D
Scotty D is offline
PostPosted: Fri Aug 01, 2025 7:05 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Reached another milestone today, first fill-up. Needs some fine tuning, smells very rich, I’ll try to dig into it this weekend and check the plugs to see what they have to say.
FastyOrange
PostPosted: Sat Aug 02, 2025 8:24 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
That is a good looking square! Keep chipping away at it and before you know the list will be finished...and then the new list will start to take shape! I did a search I minute ago, the fixed orifice size that Ray recommended for the late pcv system is 3mm. Planning to do this to my fastback at some point in the near future and see how it goes.
72 FI Fastback
Scotty D
Scotty D is offline
PostPosted: Sat Aug 02, 2025 11:44 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Thank you.
I do seem to remember the 3mil measurement mentioned as well.
I may have to pull some stuff apart and get some clarity. There is definitely NOT a pipe/tube coming off of the IAD to connect a hose to the oil breather.
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 03, 2025 1:05 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Scotty D wrote:
Thank you.
Yeah, not all IAD plenums got that tube off the front plate. In fact most came blank with some sort of bracket attached to them. You might want to look for another plenum IF you want to run all of the tubing. Keep in mind you're not running the stock muffler, so you're already missing 2 hoses that go to the box under the load floor above the trans. Do you still have the hoses from the heads? Just asking as they're part of the PVC system.
Tram wrote:
Tram wrote:
Scotty D
Scotty D is offline
PostPosted: Mon Aug 11, 2025 10:08 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Bobnotch wrote:
Scotty D wrote:
Thank you.
Yes, the front plate of my IAD does indeed have some sort of bracket attached to it. I believe the muffler is stock though, and the hoses that ran from the cannister beneath the load floor were brittle and junk, so they got tossed. I know that one hose came off of the oil bath/air cleaner and ran to the passenger side of the cannister, and the other would have come off the driver side of the cannister and led back to the nipple on the exhaust elbow.
But I don't know about any hoses from the heads, maybe shed some light on those for me.
Scotty D
Scotty D is offline
PostPosted: Mon Aug 11, 2025 10:09 am    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
Oh, and is it imperative to have the hose connected from beneath the breather up to the tube on the IAD, or is there another workaround for it?
Guess I'll be purchasing a late model IAD with proper front plate/tube connection.
FastyOrange
PostPosted: Mon Aug 11, 2025 1:53 pm    Post subject: Re: Another Pickle Post - 1973 Squareback Reply with quote
If you want to run the late model crankcase breather setup, you need the correct IAD and the correct heads (i.e. late heads with the breather ports). The easiest cylinder head port to find is on the passenger side. Pull your air cleaner off and look down at the cooling tin next to the spark plugs at the back of the motor on that side. You should see a cutout with either a hose running down through the tin or no hose but a breather port on the end of the head if you have the right heads. The other breather port is in the same position on the driver's side head, so it will be up near firewall. Passenger side shown below.
If you don't have the late heads, it may be easier to just swap the breather for the early style. It is my understanding that this will also work. Hopefully bobnotch or someone else can confirm that.
You also need to look at the fuel injection parts chart from the k manual shown below and compare the numbers on the chart to the parts on your car before you buy a bunch of parts.
Start there and see if you are even running the correct parts for your model year. You may have a different generation of FI installed...that is fine if the parts match.
Once you know these details you can start figuring out what you need and hopefully avoid buying a bunch of unnecessary parts...and we can better understand what you're working with and how to help when you have issues.
Jon
72 FI Fastback
Page 12 of 14
