The Stupid Question Thread
Page: Previous  1, 2, 3 ... 136, 137, 138, 139, 140  Next
robhead
robhead is offline
PostPosted: Thu Jan 16, 2025 2:15 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Feel free to skip to the bottom if you don't want the history lesson.
So back in 1984 when I was 12, my VW obsession began when I met my 69 and immediately fell in love with it, the only problem was it belonged to my cousins in a city 4 hours away. Fast forward 16 years, 4 beetles, and 2 buses later, my aunt finally agrees to sell me the 69 when it sprung a leak and stunk-up her garage (fuel line under tank rotted). They weren't driving it at the time, but they would occasionally start it and let it warm up, which she then said that the engine (1500 SP) had a warped cylinder after my uncle got drunk and over-rev'd it.
When I got it home and fixed the fuel leak, it didn't take much tinkering and I was able to get it started and I drove it around the yard, for a few minutes until the engine seemed to seize. Once it cooled down, I was able to start it again with the same results. I pulled that engine out and put in a 1600 DP I took from one of my busses.
So anyway, here I am 25 years later, still have the 69, and that 1500 is still sitting on the floor in my shop covered in dust, with a few parts borrowed but the long block is intact. One of my sons has taken an interest in my hobby and I was thinking it may finally be time to rebuild that engine. While I've rebuilt many small engines (lawn equipment) in my youth working in a small engine repair shop, I have never tackled an AC 1600. I was hoping to do just a top end and not crack the case.
What sort of evidence should I look for that would indicate a full rebuild is necessary? Is it more likely that the head is warped rather than a cylinder? Is there a clear tell if either is warped? I believe this motor may have been rebuilt before, so I'm not sure what the current bore situation is. All advice, or even snark, is welcome
BCE56
BCE56 is offline
PostPosted: Fri Jan 24, 2025 3:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
What would cause front disc brakes (Empi conversion) failure to retract/remain in contact with rotor?
During a short drive yesterday, I noticed reduced pedal free play, brakes were dragging. Discs were very hot.
No previous issues since professional installation 6K miles ago.
Rear drum brakes apparently not affected. Parking brake functions normally.
=BCE56=
'86 Syncro Tintop
EJ22, OBD II SmallCar adapter plate conversion
Side project: '69 Frankenbug now driven daily.
mikeonthebike
mikeonthebike is offline
PostPosted: Fri Jan 24, 2025 7:51 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I would check the soft brake lines going to the calipers. If they are bad, they will allow fluid to the calipers but not back. You can't always tell by looking at them. So maybe replace if they are old.
vamram Premium Member
vamram is offline
PostPosted: Sat Jan 25, 2025 9:01 am    Post subject: Re: The Stupid Question Thread Reply with quote
Piggy-backing on this, what is the expected lifetime of the steel-braided brake lines to the caliper? I have this set up on my '73 Super, brakes are excellent, but the lines are 5 years old w/40k miles on them so I'm curious.
Click to view image
Save the Supers!!
BCE56
BCE56 is offline
PostPosted: Sun Jan 26, 2025 2:29 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Brake hoses (rubber) appear sound, they are not soft. All hoses were replaced w/ complete brake job when disc conversion was done 2 years ago. No leaks seen but reservoir is a bit low.
EDIT- I forgot to mention new master cylinder was installed during conversion.
So, new brake system front to rear. Complete satisfaction until now.
=BCE56=
'86 Syncro Tintop
Cusser
Cusser is offline
PostPosted: Sun Jan 26, 2025 6:31 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Keep a good watch on that. Remember that a master cylinder can leak at its rear, into the driver area.
BCE56
BCE56 is offline
PostPosted: Sun Jan 26, 2025 7:21 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks for the reminder!
I checked the pedal this AM. Free play seemed normal, but I did not drive- it is raining here today.
=BCE56=
'86 Syncro Tintop
RobinaWhatev
RobinaWhatev is offline
PostPosted: Mon Jan 27, 2025 10:45 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hi, first time poster and new owner of a '72 Super, runs but needs some love. Can anyone tell me what these disconnected tubes are for under the steering wheel (circled in yellow)? Car came to me with these both disconnected. Not wires, clearly tubes. I'm guessing wiper fluid pressure tube? (I know the wiper fluid is powered by air pressure in the spare). Turn signals and wipers themselves work fine, horn does not.
Thanks,
R
mikeonthebike
PostPosted: Tue Jan 28, 2025 8:43 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks,
R
You would be correct. That is for wiper fluid. Mine are hanging and non functional, also.
BCE56
BCE56 is offline
PostPosted: Thu Feb 06, 2025 12:41 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Follow up:
*Enlisted professional assistance*
Inspected hoses, checked for leaks- all OK.
Adjusted pushrod for more pre travel.
Reset pedal stop.
Lubed pedal assy.
Significant improvement in pedal feel. So far, so good.
On to the next fiasco!
=BCE56=
'86 Syncro Tintop
jinx758
jinx758 is offline
PostPosted: Thu Feb 06, 2025 5:49 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I'm B-A-C-K ... !
Yesterday my '71 died pulling into parking space at store. Struggled to start but got me home - about 7miles.
Re-gapped points, static timed, & would only crank.
Put back-up distributor in with new condenser. Reset point gap (ones that came in "new" distributor) got ready to static time the distributor. Purchased in about 2017, never installed, stored indoors in a Ziploc freezer bag.
Test light stays lit all the time.
W-T-H
I can see point gap separate but light stays on open or closed.
Did my coil short out ?
Open to suggestions.
Thanks ... stay safe... jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
mukluk
mukluk is offline
PostPosted: Fri Feb 07, 2025 4:46 pm    Post subject: Re: The Stupid Question Thread Reply with quote
jinx758 wrote:
I'm B-A-C-K ... !
W-T-H
No, your coil didn't short out.
If you have your static timing light connected correctly (one wire to the same coil terminal as the points wire, the other to a good ground), then the static light staying on despite the points opening and closing indicates the points are either dirty or defective, there's a break in the wire connection from points to condenser to coil, or the points plate isn't grounded to the distributor body.
You can check all of these possible causes with an ohmmeter.
All that aside, how did you come to conclusion that the distributor was the cause of the engine dying earlier? Did you actually test for spark, or are you guessing?
jinx758
jinx758 is offline
PostPosted: Fri Feb 07, 2025 5:49 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks for responding ...
Healthy double stream squirt when throttle is cycled & instant (EGAS38mm carburetor).
Solid bright light on POS coil terminal backed up by 12.7VDC from multimeter with key on.
NEG of test light on bent tab the decklid catches on body - bare metal showing through 3 layers of paint with no rust.
POS on same distributor tab green condenser wire is attached to (NEG). Test light stays on no matter if points are open or closed.
Will pull spark plug to test for actual spark & use ohmmeter on points plate, tomorrow.
Condenser wire is new out of the box & ohmed out from female tab to rubber stopper & open from rubber stopper wire to condenser case. Yes, wire inside distributor is shiny, tight, & connected.
Thanks for the path ... stay safe
jinx
1971 Standard Bug
1776cc dual port
034 distributor
mukluk
mukluk is offline
PostPosted: Fri Feb 07, 2025 6:51 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Healthy accelerator pump action doesn't mean the idle circuit isn't plugged. Wink
mukluk
mukluk is offline
PostPosted: Tue Feb 11, 2025 4:05 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Any luck?
jinx758
jinx758 is offline
PostPosted: Tue Feb 11, 2025 7:19 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Er, um ... not yet.
Put a belt & tensioner on wife's daily & 3days later she pulls up with her car screeching like a cat with its tail under a rocking chair. All pulleys had checked out & noise coming between the engine & radiator.
I'm elbows deep in replacing the turbo on her chevy 1.4ltr.
$600 part at FLAPS ... ouch
Worst Engine Ever !
It has 1364cc & my bug has 1776cc ... (eye roll emoji)
It has trouble on slight uphills. When she "floors it" we hear it scream "Ouch, don't, stop, you're hurting me"
ROFLMAO
Back to bug this weekend... stay safe
jinx
1971 Standard Bug
1776cc dual port
034 distributor
RMD3819
RMD3819 is offline
PostPosted: Mon Mar 03, 2025 7:58 pm    Post subject: Ran out of fuel now won’t start after adding fuel Reply with quote
About a block from the house wife ran out of fuel in the 69.
She put a small amount in from a neighbor which was enough to get home.
Car has been sitting a few weeks and now won’t start after adding more fuel.
Tried a jump which did nothing. The fuel filter is empty and when cranking can see fuel bubbling into it but not filling past the very bottom. This makes me think the carb isn’t getting fuel.
My non VW neighbors have suggested using the following in the carb:
-Carb cleaner (which I have)
-Starting fluid (which I don’t have)
-Fuel directly in the carb.
Thoughts, ideas?
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Mon Mar 03, 2025 8:20 pm    Post subject: Re: Ran out of fuel now won’t start after adding fuel Reply with quote
Thoughts, ideas?
First thought is that sediment in the gas tank has clogged up the in-tank strainer at the tank outlet. It's not unusual for this to happen if you run the tank empty. Particulates floating around in the tank get sucked onto the strainer and embedded in the mesh, so even when you add more fuel they don't get dislodged. If you haven't changed this strainer recently (or ever) it would be best to replace it with a new one. It sounds like you have the fuel filter in the engine compartment after the pump. IMO it is better to locate this filter under the tank or next to the transmission. The fewer fuel connections in the engine bay, the better.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
mukluk
mukluk is offline
PostPosted: Tue Mar 04, 2025 1:39 pm    Post subject: Re: Ran out of fuel now won’t start after adding fuel Reply with quote
Thoughts, ideas?
I would take their advice and use one of those flammable substances down the carb throat to see if the engine will briefly fire up. If it does, pull the fuel hose off at the pump to see if you're getting gas back to that point from the tank or not -- if no gas is getting to the pump, OldSchool's theory is the likely problem. If you are getting fuel to the pump, put the inlet hose back on and remove the outlet hose then have a helper briefly crank the engine while you check to see if the fuel pump is forcing fuel out (fire hazard, be sure you don't have any ignition sources nearby!). If the pump's working, check for obstructions in the hose and filter you have between the pump and carb, and check for a plugged or stuck float needle valve.
If the engine won't briefly fire up when you put some flammable liquid down the carb throat, check to see if you're getting spark to the plugs.
Cusser
Cusser is offline
PostPosted: Tue Mar 04, 2025 4:39 pm    Post subject: Re: Ran out of fuel now won’t start after adding fuel Reply with quote
Important: was wife departing from the house or "trying to make it home" !
Of course Mrs. Cusser would NEVER have such happen to her - right !!!!
Anyway, most likely this is super-related to running out of gas. With air in the line from tank to fuel pump, typically one needs to prime through the carburetor with hydrocarbon such as starting fluid (as others have noted), until the engine rpm pull gasoline through. Fuel pumps are made to pump liquids such as gasoline, not air.
Page 137 of 140
