Käfer2 Samba Member
Joined: December 30, 2019 Posts: 75 Location: Germany
Posted: Sat Aug 09, 2025 10:29 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Your ivory escutcheons, door handles, window cranks look perfect, in combination with the steering wheel color.
You could think about adjusting your smiling rear bumper like the following one
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 1132 Location: Yuba City CA
Posted: Sun Aug 10, 2025 5:08 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Well what do you know
Ol’ Herb earned two awards today at his first VW show
Out of around 150 entries,He earned:
“Top 25 Air-cooled” (voted by the participants)
“Top 10” (voted by the Club holding the event)
Not bad , not bad at all _________________ Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11220 Location: Oregon
Posted: Sun Aug 10, 2025 5:16 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
FN Sweet!
I had a feeling that your car would show well.
Hard work and perseverance pays off in the long run.
Congratulations! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Sun Aug 17, 2025 6:10 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Today’s project was changing the main and idle jets
40MM IDF style carburetors (Chinese Weber copies)
Old
Main Jet - 115
Idle Jet - 50
New
Main jet - 135
Idle jet - 55
Air jets stayed the same at 200
Engine is an 1835cc with Engle 110 cam and big valve heads (I’d have to look in my papers to see exact size) stock rockers and geometry
Runs smoother and has better responsiveness
I need to drive it more and see how things are
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Thu Aug 28, 2025 9:31 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
Käfer2 wrote: |
You are right on the escutcheons, I switched them back to ivory already
and you are also right about the smiling bumper.
I had some clearance issues with the top mounted decklid standoffs I had on there when I mounted the bumpers. I have since removed those standoffs but havent adjusted the bumper yet. _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Sun Aug 31, 2025 5:24 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
This weekend’s project was installing an adjustable beam
First I stripped and cleaned the donor beam
And cut and welded in the adjusters, it off the “horns”,and coated it all in POR-15
Then when it was ready, I pulled out the existing front beam
And swapped all the parts over
It’s an early beam, so no steering damper mount was present . I bought a bolt on billet aluminum one and slapped it on there
I put it all back together at the lowest possible height
That’s way too low for me and the tires weee rubbing
I was just trying to Lower it slightly so it doesn’t look like a monster truck
After a few tries and adjustments , it’s pretty close
It’s really hard to tell in pics, but its at least an inch lower
Easier to tell at a 3/4 angle from the rear
I still have to do the rear , but I’m waiting on short axles etc _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
jitbba Samba Member
Joined: August 20, 2013 Posts: 208 Location: Schulenburg
Posted: Sun Aug 31, 2025 5:56 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Looking good! What size tire are you running? _________________ My other ride is a Zildjian |
Posted: Sun Aug 31, 2025 8:19 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
205/60R15 all the way around
They are a little fat, but I like Them
Maybe 195/60R15 next time _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
jitbba Samba Member
Posted: Sun Aug 31, 2025 8:22 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
That's what I run but I'm wanting bigger  _________________ My other ride is a Zildjian |
richparker Samba Member
Joined: November 24, 2011 Posts: 7550 Location: Durango, CO
Posted: Sun Aug 31, 2025 10:21 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
I went with 15x6 _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Yesterday 2:39 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
ET ?
Not sure what that means _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
