jimf909 Samba Member
Posted: Tue Dec 26, 2023 8:43 pm Post subject: Re: 14" Tire Options |
mottoguzzi wrote: |
Anybody tried Maxtrek Su-800 A/T 205R14 8 ply 107 load index $90.00, not sure if they would fit stock alloys. |
It'll be interesting to see if anyone has experience with these. They look good, the load rating is very good and the price is pretty good too.
It's odd that they don't spec an aspect ratio, e.g. 205/xx R14. The spec'd 27" diameter suggest an 80 aspect ratio which is tall for a 205 tire and makes this tire 6.4% taller than stock (your engine will run slower at the same mph and the van will be less quick than with the stock tire diameter).
https://www.prioritytire.com/maxtrek-su-800-a-t-lt-205r14-107-105q-d-8-ply-at-all-terrain-tire
Weird (to me) that aspect ratio isn't spec'd with these...
As the manufacturers only provide the tire width and the rim diameter with these tires, various brands and models will have size differences. In order to ensure the correct size is purchased, the overall tire diameter that is needed should be checked. _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Wed Dec 27, 2023 5:06 am Post subject: Re: 14" Tire Options |
jimf909 wrote: |
As the manufacturers only provide the tire width and the rim diameter with these tires, various brands and models will have size differences. In order to ensure the correct size is purchased, the overall tire diameter that is needed should be checked. |
Seems to me that UN SPECIFIED aspect ratio has been discussed VERY many times.
If unspecified it is assumed to be .82 Don't blame the tire manufacturer it is an industry wide convention mostly for light commercial tires.
So a 205/82-14 is 27" in diameter?
Seems like a great way to gain 3/4" ground clearance (if that's what you want) and to gain a couple ticks in higher gearing
Just the thing if you put in a torquier motor and wish to slow the motor down at speed. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Wed Dec 27, 2023 10:56 am Post subject: Re: 14" Tire Options |
Okay. I recall the stock 185/14 tires w/out a stated aspect ratio but assumed that current tires stated one. Regardless, the product page doesn't say assume a .82 ratio, it says the tires will vary. Thanks for the clarification. _________________ - Jim
Butcher wrote: |
Guilty as charged.
Posted: Wed Dec 27, 2023 12:07 pm Post subject: Re: 14" Tire Options |
mottoguzzi wrote: |
Tire Easy-Truck list a 5-7" rim width, so should fit the 6" wide alloys just fine. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10389 Location: Orbiting San Diego
Posted: Wed Dec 27, 2023 12:28 pm Post subject: Re: 14" Tire Options |
That 205R14 tire size is listed on the driver door sticker showing the recommended inflation pressures.
Vanagon Syncros 86-91
205R14C
1988M5 Samba Member
Joined: January 23, 2016 Posts: 844 Location: Tucson, AZ
Posted: Wed Dec 27, 2023 12:38 pm Post subject: Re: 14" Tire Options |
crazyvwvanman wrote: |
205R14C
I wonder if they recommend lower pressure to keep the same gear ratios/ speed? _________________ 1991 tin top GL
Some BMWs. |
Posted: Wed Dec 27, 2023 12:48 pm Post subject: Re: 14" Tire Options |
No, they do it for other reasons.
The pressure has a very minor effect on tire circumference.
Mark
1988M5 wrote: |
I wonder if they recommend lower pressure to keep the same gear ratios/ speed? |
Posted: Wed Dec 27, 2023 6:10 pm Post subject: Re: 14" Tire Options |
1988M5 wrote: |
The recommended pressures should keep the load across the tread rows about the same when under full load conditions. If you never (or seldom if ever) drive your van at the maximum axle load, you can get by with lower pressure.
The chalk test or checking the tread row temperatures with an IR thermometer will tell you whether you have too little or too much air for the load you are carrying. By adjusting the front to rear bias you can also adjust the amount of understeer. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Wed Dec 27, 2023 10:43 pm Post subject: Re: 14" Tire Options |
Looking at the Goodyear Wrangler AT in 195/75/14
Its the stock size in an LT and AT tire, plus I used to run this size on my bus.
Any thoughts? _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4741 Location: Arizona Highways
Posted: Thu Dec 28, 2023 7:16 am Post subject: Re: 14" Tire Options |
otiswesty wrote: |
Any thoughts? |
yeah. they are a good tire comparable to the old BFG A/T, but are usually obscenely expensive.
some years ago, you could find the guy in your town that worked on the mail trucks and he would have a bunch of these tires around in various states of wear--with and without winter studs. the USPS uses this tire on the LLV mail trucks and i used to pick up "take offs" for dirt cheap.
pretty sure the only reason this tire is around is for the USPS. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
brickster Samba Member
Joined: January 05, 2004 Posts: 595 Location: CO, USA
Posted: Thu Dec 28, 2023 7:56 am Post subject: Re: 14" Tire Options |
If you search this thread, you'll find some discussion of them. Load index of 93 (1433lbs) and expensive (minimum of $230 per tire when I checked today). I think I read that Goodyear has a fat, guaranteed USPS contract for these to use on mail trucks, so there is zero incentive to competitively market them?
For that style of tread, it seems like most are using the 27" Grabbers. If you have the stock engine, that extra diameter will noticeably affect performance. I have read that a spring lift is not necessary, but not positive on that. |
airshipper Samba Member
Joined: December 04, 2014 Posts: 10 Location: Akron, Ohio
Posted: Thu Dec 28, 2023 11:04 pm Post subject: Re: 14" Tire Options |
otiswesty wrote: |
Any thoughts? |
I tried going back to 14's last year for a few months (after having 16's) and went with these. Driving around town, they were the best tires I've ever had on the van. However, it was tough going back to a narrower tire when driving on a windy day on the highway. I got too spoiled with my 215/55/16's, but if you are going to stick with 14's, these are a great, but expensive choice.
PM me if you're interested in a discount code for these. I might know a guy.  _________________ '84 Bostig Westy Wolfsburg Auto |
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 679 Location: Senoia,GA
Posted: Fri Dec 29, 2023 4:51 am Post subject: Re: 14" Tire Options |
borninabus wrote: |
otiswesty wrote: |
Any thoughts? |
pretty sure the only reason this tire is around is for the USPS. |
You are correct. Further fleecing of the U.S. taxpayer. _________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
Posted: Wed Jan 10, 2024 8:08 am Post subject: Re: 14" Tire Options |
Is anyone running the AltiMAX RT45 205/70R14 in Load Index 98? 8.2" wide, so would these rub without spacers? _________________ 1984 Campmobile Automatic |
Posted: Wed Jan 10, 2024 9:47 am Post subject: Re: 14" Tire Options |
brickster wrote: |
Is anyone running the AltiMAX RT45 205/70R14 in Load Index 98? 8.2" wide, so would these rub without spacers? |
I have run 215/70R14's and now have 215/75R14's mounted on stock alloy rims and not had rubbing problems. 27x8.5r14 which are just a tiny bit larger than the 215/75r14s gave rubbing problems on my '91 low sitting Multivan but not on my higher sitting 83 1/2 with steel rims (both have the springs they came with)
205/70R14 was a stock size. |
Posted: Wed Jan 10, 2024 10:45 am Post subject: Re: 14" Tire Options |
1988M5 wrote: |
205R14C
A tire has the same circumference and travel per revolution at 10 psi or 40 psi. While the tire diameter appears smaller that doesn't shrink the length of the tread.
Butcher wrote: |
Guilty as charged.
Posted: Wed Jan 10, 2024 4:10 pm Post subject: Re: 14" Tire Options |
I performed the same kind of test about 20 years ago only more accurately.
There was a difference in the rolling circumference but it was very small.
If you look closely that video shows a small difference as well.
Mark |
Posted: Wed Jan 10, 2024 5:58 pm Post subject: Re: 14" Tire Options |
Wildthings wrote: |
brickster wrote: |
Thanks. I was aware, but sometimes dimensions can vary a bit and I wasn't sure if this tire was on the wider side of the spectrum. I have steel wheels. Are you saying there's a difference in offset between stock steels and aluminums?
I am tempted to try these simply because my Vantras are not useful for loose surfaces (snow, dirt, sand and mud). I will say that they're very good for highway and easy dirt roads, quiet and stable. _________________ 1984 Campmobile Automatic |
Posted: Wed Jan 10, 2024 6:24 pm Post subject: Re: 14" Tire Options |
Mark |
I measured the difference in circumference with pressure 20+ years ago. Since the spare tire on an old FJ40 sits on a swing carrier in the back of the rig and is very accessible, I choice it to experiment with. The tire would have been a P235/75r15. IIRC the difference in the circumference going from 0 psi to 40 psi was minor, like 3/16 of an inch. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3635 Location: Dartmouth, Mass.
Posted: Wed Jan 10, 2024 8:42 pm Post subject: Re: 14" Tire Options |
Wildthings wrote: |
I observed the same thing recently when fussing with a 27” in the front clamshell. “Lower the air pressure!”they cried.
The OD had virtually zero difference. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
