dead van diagnostic tools, wiring bypass
Page: Previous  1, 2, 3, 4
xflyer
xflyer is offline
PostPosted: Fri Jul 07, 2023 5:59 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
wherbusche, Best to know what year the Vanagons are as there are different relay wiring(s) and relays on some of them.
1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C
Busfixer
Busfixer is offline
PostPosted: Tue Dec 03, 2024 3:38 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Help! I almost have the wiring bypass built but ran into a snag. When testing the diodes pictured below (50V, 10A), I cannot get voltage to flow through either diode regardless of orientation. 12.8V flows through my test leads hooked in series to my volt/ohm meter, but it quickly drops to 0V when I insert either diode in series. Am I doing something wrong or are these diodes bad? I must admit that I am a rank amateur in the electrical category.
Puzzled, Busfixer
DanHoug
DanHoug is offline
PostPosted: Tue Dec 03, 2024 3:43 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Digikey RARELY makes a mistake but those are NOT diodes!!! those are capacitors. here's what that part number should look like:
-dan
www.thefixitworkshop.com
jlrftype7
jlrftype7 is offline
PostPosted: Tue Dec 03, 2024 3:46 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Puzzled, Busfixer
Does your Meter have a Diode testing position on its dial? Not all do, but, so many do that I need to ask.
It will look like an Arrow, with a line drawn across the arrow.
Here's a Fluke Meter as an example, the Diode test is one to the right of the Middle/Top OHM symbol, like 1 o'clock on the dial.
S:Paid:MS:CSM-2295:YF1CA5:20501201:APZ_1&gclid=7c2e0a20f8cb1aa6c3716d6f729eac6" target="_blank">https://www.grainger.com/product/4EB18?gucid=N:NRazz...d6f729eac6
‘84 Tin Top - Hilga....Auto
tjet
tjet is offline
PostPosted: Tue Dec 03, 2024 7:31 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
I made the tool with a Posi-Lock fuse holder, and a diode that fits in like a fuse...
https://www.amazon.com/Littelfuse-02400104P-Diode-...&psc=1
https://www.common-motor.com/posi-lock-blade-fuse-...lkQAvD_BwE
Posi lock brand connector info
https://youtu.be/Yiimgl-Rdmw?si=zVx31hbxa2M2ECPF
Busfixer
Busfixer is offline
PostPosted: Tue Dec 03, 2024 7:48 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Thanks Dan, jlr and TJet - I believe Dan is right and these electrical components are capacitors. Dan, when I put them in series as described previously, they would show 6V, 3V, 1V then 0V, allin about 1-1/2 seconds. 0V steady after that. So your recognition of them being a capacitor combined with the quick voltage falloff to0V sounds like you are correct. I will call DigiKey tomorrow. JLR, attached below is a pic of my fine Harbor Freight multimeter in the Diode test position and it reads “1”. Apparently this means no flow. Confirms capacitor idea. Thanks for teaching me that function. TJet, if I don’t get satisfaction from DigiKey, then I may go your route. Thanks for the links.
Thanks again to all - I love the Samba! Busfixer
DanHoug
DanHoug is offline
PostPosted: Wed Dec 04, 2024 6:46 am    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
DigiKey is 80 miles from my house... a company of over 5,000 employees in a town of 8,800!! 3 million sq ft. i've been ordering from them for 40 years and have never had a wrong order but mistakes happen.
frustratingly, before Amazon and DeJoy ruined the USPS, i could order parts in the afternoon and have them in my mailbox by 10am next day for $2.99 USPS 1st Class shipping. now it takes a week to get here and has pretty much circumnavigated the state of Minnesota before arrival.
-dan
Backtotheeightiesagain
Backtotheeightiesagain is offline
PostPosted: Fri Dec 06, 2024 5:52 am    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
There is an emergency bolt on box that fires random sparks into the distributor.
Not seen another one and there is nothing on the Internet about it. Just connect to 12v and King lead. In cap.
Useful diagnostic tool bypass the distributor.
Unfortunately no one makes it now
Busfixer
Busfixer is offline
PostPosted: Sat Dec 21, 2024 12:57 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Follow-up: I finally received the correct diodes from digi-jet and built the diagnostic wiring harness. I added an optional short lead in case I wanted to power the harness from the alternator stud instead of the positive battery post.
I originally built the harness to diagnose a hard shutdown problem at highway speeds. While I was waiting on DigiJet diodes, I replaced the original ignition switch, changed coil power tap on fuse panel from D15 to D23, and cleaned several relay, coil and distributor connections on 2 yr old parts. The problem disappeared.
But I now feel a lot better having the diagnostic harness in my 88 Bus wherever I go.
Another issue will pop up at some point in the future and the harness is ready!
Thanks, Busfixer
do.dah
do.dah is offline
PostPosted: Sat Dec 21, 2024 1:02 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
If you have it,, you won't need it!!
The inverse; If you don't have it, you're gonna need it, REALLY REALLY BAD!!
DanHoug
DanHoug is offline
PostPosted: Sat Dec 21, 2024 1:37 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
those diodes can break pretty easily so cut a section of chopstick longer than the leads and wrap electrical tape around the whole mess to bind them to the chopstick support.
-dan
Busfixer
Busfixer is offline
PostPosted: Sat Dec 21, 2024 3:48 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Dan I was going to wrap the diodes with electric tape but thought the reason they were bare in previous photos was that they get hot. How about a popsicle stick and electrical tape?
Busfixer
DanHoug
DanHoug is offline
PostPosted: Sat Dec 21, 2024 4:28 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Busfixer
you've got 2 - 10 amps diodes in parallel... 20 amps of service for something drawing less than 10 amps so you'll be fine with them wrapped in tape. popsicle sticks are fine as long as it was grape flavor.
-dan
reevesme
reevesme is offline
PostPosted: Tue May 13, 2025 2:28 pm    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
Your device helped me to fix my vanagon today. Thank you, thank you, thank you!!!!
83.5 with a 2.1L engine (replacement) and digijet ignition system. Was having a hot start issue that could have cancelled our trip to Moab.
Coil wasn't get enough current. DIsconnected the fuel pump jumpers first, then the coil feed. Then it would not start again. Reconnected the coil feed; boom fired like a champ.
tjet
tjet is offline
PostPosted: Thu May 15, 2025 7:36 am    Post subject: Re: dead van diagnostic tools, wiring bypass Reply with quote
I just bought a nice Fluke recently to keep onboard.
https://www.fluke.com/en-in/product/electrical-testing/clamp-meters/fluke-362
Ive been looking for a good clamp meter to help troubleshoot draw issues.
Page 4 of 4
