EverettB  Administrator
Joined: April 11, 2000 Posts: 71759 Location: Phoenix 602
vdubfan68 Samba Member
Joined: August 09, 2007 Posts: 179 Location: PINON HILLS
Posted: Sun Jul 14, 2013 5:19 pm Post subject: LOCK LUBRICANTS |
Hello Everett in regards to lock lubricants . There is two ways to go . Tri Flow is petroleum based and has Teflon in it . Works great in areas of the country were it freezes . Or you can use Super Lube which is synthetic . Both come in aerosol and in paste form . The paste form is great when a lock has been torn down or being reassembled . Or if you just want to clean up your original locks . WD 40 works great as a solvent to wash away the old grease and grime . It should never be used as a lubricant . Or a can of parts cleaner . Once the lock plug is clean then apply the above Lubricants I suggested . And your good to go for a few years . I wanted to post some photos of these products to this thread . But Its way to confusing for me . Sorry .  _________________ 1962 Beetle Convertible 1968 Beetle Sunroof |
DHMaher Samba Member
Joined: November 16, 2009 Posts: 787 Location: Portland, Oregon
Posted: Tue Feb 09, 2016 6:53 pm Post subject: Re: How to "rekey" VW door handles. A picture tuto |
Just wanted to say thanks for the great post! I could never get my passenger side to work with my drivers door/ignition key. Using the tutorial I was able to swap the pins/wafers around for a perfect fit!
Thanks again! _________________ Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green
See my ads |
cn63bug Samba Member
Joined: August 19, 2011 Posts: 114 Location: Mt. Juliet, TN
Posted: Wed Feb 10, 2016 4:26 pm Post subject: Re: How to "rekey" VW door handles. A picture tuto |
Great tutorial. I've looked into re-keying everything together and this showed me what I need to do.  |
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Thu Feb 11, 2016 12:27 am Post subject: Re: How to "rekey" VW door handles. A picture tuto |
You guys are welcome, glad to help! _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Bob Hollingsworth Samba Member
Joined: March 10, 2014 Posts: 77 Location: United States
Posted: Thu Mar 31, 2016 12:03 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
I'm a late comer to this thread, which by the way is exactly what I was looking for. I hope someone with an answer is still watching.
I took my drivers side outside door handle off and then removed the lock to see what was holding the push button partially in. There is a rectangular rubber piece that goes around the lock, in a groove, that was brittle and broken. Is this piece necessary and is it available? I am assuming it is there to keep out dirt and water.
I searched several of the parts distributors and didn't find anything. |
Keith Samba Member
Posted: Thu Mar 31, 2016 12:43 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
Sounds like you're describing the door handle seal.
https://chircoestore.com/door-handle-seals-4pc-vw-...hgodIR0Obg _________________ Formerly known in the forums as "OVALTEEN"
Spezialist Banned
Posted: Thu Mar 31, 2016 1:51 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
I've done this a couple of times (back in the day) knowing it was hack, but did it anyway.
I wish a locksmith would show the easy way to mix and match wafers.
I tried that and that's very time consuming.
A note of caution, if you're going to get a key made from scratch and there is no code to work from DO NOT LUBE LOCK.
Locksmiths need a clean and dry lock to start with. _________________
Posted: Thu Mar 31, 2016 2:18 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
| Keith, the rubber seal (?) in question is inside the handle, in a groove, around the lock body. |
Posted: Thu Mar 31, 2016 5:14 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
I'm wondering what the difference is between a filed-off wafer and a wafer of the correct height. Aren't they both now the same height to fit the profile of a particular key? The key doesn't know whether the wafer was filed or not. As for other keys working in the lock, that would happen regardless. I must be missing something . |
EVfun  Samba Member
Posted: Thu Mar 31, 2016 7:06 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
The idea is that all the wafers are the same size and the difference is where in its height the slot for the key is located. The top and the bottom of the wafer are leveled with the lock cylinder when the correct key cut is under the wafer. If one end of a wafer sticks up the other end is recessed in the lock cylinder. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Fri Apr 01, 2016 11:32 am Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
| Bob Hollingsworth wrote: |
Correct, it fits in a groove around the push button, don't really know if it keeps water out, but I'm sure it helps, I think it's more to keep the Button from vibration rattling. I've seen a few for sale recently, but hard to find for the most part.I made a pair out of some bike tube. works fine _________________ 1960 Convertible |
Posted: Fri Apr 01, 2016 2:23 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
| Do you remember where you saw them for sale? |
soupcups  Samba Member
Joined: May 08, 2014 Posts: 230 Location: Huntington Beach
Posted: Tue Sep 13, 2016 8:37 am Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
| Great tutorial on how locks work Keith and everyone else. Just did this to a '63 Notch that came with no keys and/or ignition. Pics showed me what I was looking for and verbiage was very informative. I ended up buying an OG lock with two keys on here and using the key to swap out the wafers in the OG lock with the locks on the car. Now I have three OG door locks that open with the same key. Thanks very much for taking the time to post this and all the detailed pics. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1049 Location: South Florida
Posted: Mon Aug 06, 2018 10:28 am Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
Huge thanks to @Keith Ovalteen for this great tutorial with excellent pictures and some helpful comments from others too. You all help'd me get my buggy's engine lid lock working with the same key as for ignition.
Had to use the key barrel from a big old Beatle engine latch, because the nice smaller and more fitting (for my light weight fiberglass engine lid) latch was from a VW bus, which uses a totally different key (VB type) from my ignition (K type).
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7547 Location: Houston, Texas
Posted: Sat May 04, 2019 3:22 pm Post subject: |
| EverettB wrote: |
Thanks, I have been using spray carb. cleaner or another solvent to clean things up when they are apart, then Tri-Flow spray.
I will check out Super Lube too. |
Tri Flow is used around these parts. It was recommended to me over graphite. _________________ www.vwnos.com [email protected]
FmjBug51 Samba Member
Joined: February 15, 2024 Posts: 3 Location: Michigan
Posted: Thu Aug 01, 2024 12:37 pm Post subject: Re: How to "rekey" VW door handles. A picture tutorial |
| When I got my 1964 beetle only had one key (ignition) and driver’s door lock no key…watched step by step tutorial and filed the standing above the cylinder surface the tumblers of the door tumbler after disassembly with the key in…no problem and now works perfectly with the ignition key…thanks for the information and what a time saver and no expense at all. |
