milfredo Samba Member
Posted: Fri Nov 21, 2025 5:48 pm Post subject: Re: Ordered a Sync Link today |
| sled wrote: |
that adapter will work perfectly.
do you have the aluminum ferrule that installs onto the chassis tube in front of the transaxle? |
Yes I believe I do. Do you have any pictures from the instructions just to be sure I’m doing it correct? |
Posted: Sat Nov 22, 2025 1:34 am Post subject: Re: Ordered a Sync Link today |
| sled wrote: |
In my last photo above, is the ferrule the part I have in my rear tinware?
MTT3107 Samba Member
Posted: Sat Nov 22, 2025 6:13 am Post subject: Re: Ordered a Sync Link today |
| Quote: |
| the CSP bellcrank works even less well than the CB crossbar. |
Not my experience, but then again, to each his own.. |
sled Samba Member
Posted: Sat Nov 22, 2025 9:49 am Post subject: Re: Ordered a Sync Link today |
| milfredo wrote: |
| sled wrote: |
no, the cable sheath (black outer) needs to run all the way up to the torsion housing, where the cable enters the chassis conduit.
it looks like someone cut your sheath short for some reason.
_________________ drive your split. |
sled Samba Member
Posted: Sat Nov 22, 2025 9:54 am Post subject: Re: Ordered a Sync Link today |
| MTT3107 wrote: |
| Quote: |
I have used the CSP bell crank myself. It is well built and has a great pedal feel, but it's a matter of geometry, not personal preference. That linkage will not be perfectly synched throughout the throttle range. The synclink is for people wanting perfect sync, and an extremely smooth throttle system with no points of wear. Not to mention incredibly easy adjustment, so much more so than any of the rod style linkages. _________________ drive your split. |
Posted: Sat Nov 22, 2025 10:54 am Post subject: Re: Ordered a Sync Link today |
| sled wrote: |
| milfredo wrote: |
| sled wrote: |
The sheath goes all the way back to the cable tube behind the engine. I’ve pulled it through to make fitting engine a little simpler. I had to drill the ferrule out to 10mm to fit on the tube but it’s lovely now.
It’s all coming together nicely! |
Posted: Tue Dec 09, 2025 12:12 am Post subject: Re: Ordered a Sync Link today |
Tidy, simple to adjust and super smooth. The Butty's bits peddle kit makes a log of difference as it has a bearing on the main shaft.
sled Samba Member
Posted: Tue Dec 09, 2025 12:17 am Post subject: Re: Ordered a Sync Link today |
best linkage money can buy! _________________ drive your split. |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 527 Location: Nowhere, USA
Posted: Tue Dec 09, 2025 8:57 am Post subject: Re: Ordered a Sync Link today |
| sled wrote: |
| The synclink is for people wanting perfect sync, and an extremely smooth throttle system with no points of wear. Not to mention incredibly easy adjustment, so much more so than any of the rod style linkages. |
There are a lot of people who have a mental block with SyncLink, which I suspect is because of the cost (or perhaps because of "the look"?).
Nobody can make a functional argument against it. It just works, and keeps working consistently well. _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 390 Location: Noblesville, IN
Posted: Tue Dec 09, 2025 11:31 am Post subject: Re: Ordered a Sync Link today |
Great linkage. I have been running a SyncLink for 10+ years and never had to adjust unless I pulled the carbs.
I've not seen a SyncLink with the vertical cable placement. Appears they attach to the air filter base plate. Does Pete now make those for shrouds with heater box tubes or did you modify it? _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
sled Samba Member
Posted: Tue Dec 09, 2025 12:17 pm Post subject: Re: Ordered a Sync Link today |
| Kafer_Mike wrote: |
| Does Pete now make those for shrouds with heater box tubes? |
Yes he does. _________________ drive your split. |
