57 Kab Reconstruction/Restoration
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Fri Apr 04, 2025 3:20 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Hey folks…. Correct me if I’m wrong…. This Ghia has the supports behind the rear valance for the bumper support bar to be bolted to but is absent of the hole through the valance and the weld nut. I feel like that is wrong ?but then again this is a car/ model (earliest Verts) that I’m not familiar with so I’m looking g for some feedback.
In my experience I have only seen cars with no supports on the body if they are euro delivered. I believe this car’s original destination is in the US.
I appreciate any insight here. Thanks in advance.
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
Last edited by WrennMetallWerks on Fri Apr 04, 2025 3:31 pm; edited 1 time in total
WrennMetallWerks
PostPosted: Fri Apr 04, 2025 3:27 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
^^^ I feel like we need to add a weld nut and the hole , but then again im not 100 percent sure to be honest. Did they offer the LL with Euro bumpers and the support on the body ? ^^^
WrennMetallWerks
PostPosted: Fri Apr 04, 2025 3:43 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
So looking at this supports up close I’m seeing they are hand made and located in two different heights as well as bead roll positions and over all dimensions Rolling Eyes
One is all the way at the bottom of the valance and one is mounted at the top. The plot thickens Laughing
Loren Premium Member
Loren is offline
PostPosted: Fri Apr 04, 2025 8:29 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Has the owner ordered the birth certificate from VW? This should tell you where it was delivered. It could be a Euro model that was imported. With all the work that has been done to it it’s hard to tell what’s original.
WrennMetallWerks
PostPosted: Fri Apr 04, 2025 10:38 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
^^^ Hey Hey Mr Loren ^^^
So I did ask when I was first commissioned to reconstruct it but unfortunately he said he does not have the BC yet. I think it’s safe to say it most likely never had the supports but like you say it’s very difficult to say with this one.
VeloMikey
VeloMikey is offline
PostPosted: Sat Apr 05, 2025 8:38 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
There is a lot going on in that engine compartment. I think they were added. If the rear valence doesn't have holes, they don't belong. We need to find a factory car that doesn't have holes but has supports to prove my theory wrong.
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
WrennMetallWerks
PostPosted: Sat Apr 05, 2025 8:49 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
I spoke with the owner this morning , he is going to get the BC on it.
I’m yet to see a Euro spec car that has the braces. I feel
like that was not a thing.
It will be nice to find out what is correct for this build. It’s safe to say the previous shop did not have a handle on it.
TRS63
TRS63 is offline
PostPosted: Sat Apr 05, 2025 12:08 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Wow, a lot was hidden..good to see this car finally getting in the right hands!
Antoine
Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
WrennMetallWerks
PostPosted: Sat Apr 05, 2025 1:11 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
^^^ For Real ^^^ I’m doing my best not to point to many finger’s Rolling Eyes .
WrennMetallWerks
PostPosted: Mon May 12, 2025 4:53 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
We are off to a great start resurrecting the chassis.
The new donor cap has been prepped and is ready to be got to the tunnel.
We installed a new fuel line and reinforced the clutch tube.
We use the lay out table to get the front and rear suspension points perfectly level to each as well as checked to make sure that the are square.
Next up I can begin to fit and weld on the donor cap.
Rome
Rome is offline
PostPosted: Mon May 12, 2025 11:48 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Since the tunnel is so conveniently exposed, do you/owner intend to add the mounts for the safety belts such as per the '62+ model year- the inboard mount for lap belts? Same with the ones on the door post on the body for an upper mount for shoulder belt; and figure out where to add the 3rd mounting point for the outboard belt mount. At this point you can easily add the nut for the SAE universal bolt size on a reinforcement plate and have sturdy supports.
WrennMetallWerks
PostPosted: Tue May 13, 2025 10:15 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Hey Hey^^^
The owner is opting to do seat belts for safety
So I have two chassis to do that are going to get this treatment.
I like these ones Washburn is offering and I think they are a real viable option
https://www.thesamba.com/vw/classifieds/detail.php?id=2564872
Last edited by WrennMetallWerks on Tue May 13, 2025 12:14 pm; edited 1 time in total
DaveB9
DaveB9 is offline
PostPosted: Tue May 13, 2025 11:48 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Work inside the tunnel looks very neat. I hadn't seen those Washburn ones before. I had the tunnel open on my 61 and wanted seatbelts so I used some made by OMP for building race chassis:
https://www.ebay.co.uk/itm/286512590742?var=0&...3c9db618cf
The 7/16 thread seems to match the bolts that come with all belts. I adapted the same plates to make the convertible upper mounts based on a 66 bodyshell I took measurements from.
WrennMetallWerks
PostPosted: Tue May 13, 2025 6:10 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Wed May 14, 2025 5:55 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Wed May 14, 2025 5:57 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Test Fitting
WrennMetallWerks
PostPosted: Wed May 14, 2025 5:59 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Got some replacement panels made …
WrennMetallWerks
PostPosted: Thu May 15, 2025 12:57 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Made more parts
WrennMetallWerks
PostPosted: Thu May 15, 2025 6:13 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Thu May 15, 2025 6:16 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Page 4 of 6
