"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... 30, 31, 32 ... 174, 175, 176  Next
Crankey
Crankey is offline
PostPosted: Mon Jun 09, 2008 6:15 pm    Post subject: Reply with quote
I don't want to encourage you but I have seen 20's on a single cab.
pombenz
Banned
pombenz is offline
PostPosted: Sun Jun 15, 2008 9:23 pm    Post subject: hubcentric question Reply with quote
I am in the process of fitting a set of s class mercedes wheels to a 80 vangon, and when thinking of getting spacers I'm wondering if knowing the center bore on the benz wheels is 66.5, and the vanagons centerbore is 60.1, would I then get hubcentric spacers with a 66.5 centerbore or 60.1 centerbore? And is the rear centerbore on a 2WD vanagon the same as the front
Christopher Schimke
PostPosted: Mon Jun 23, 2008 4:28 pm    Post subject: Reply with quote
Mercedes CLK320 16x7 ET37 wheels with Toyo Open Country A/T 225/70/16 tires. 7mm spacers front, 12mm spacers rear. THe front spacers were required due to THIS! Rear spacers installed simply for looks. Front caps do not fit, rear caps would fit but I don't like them just on the rear, so their not installed.
goffoz
goffoz is offline
PostPosted: Mon Jun 23, 2008 10:40 pm    Post subject: Reply with quote
I have the exact same wheels on my 86 Syncro, no spacers at all.
just loogy nuts....and it all fits fine Very Happy
....except the spare...rear tire carrier in progress
My tires,Cooper discoveries are a little taller, I think, at 29"
With the stock wbx this is a very slow drive...4th is a "coasting down hill gear only" Rolling Eyes
I stay in first alot longer,,,and use 2nd alot more,
My 89 2wd with stock alloys and tires is positvely "Zippee" when compared.
Thats why the Syncro is getting 150 more pony's..and some new ratios Very Happy
toomanyveedubs
toomanyveedubs is offline
PostPosted: Wed Jun 25, 2008 7:41 am    Post subject: Reply with quote
et 37 17 x 7.5 hub 66.5
do i need the same spacers as above for the front or different for the 7.5" width?
Christopher Schimke
PostPosted: Fri Jun 27, 2008 7:41 am    Post subject: Reply with quote
Yes! I would run 7mm spacers front and rear with those wheels.
pombenz
Banned
pombenz is offline
PostPosted: Fri Jun 27, 2008 8:28 am    Post subject: rear wheel studs Reply with quote
I just went to order rear studs and they only had 54mm in stock, are they too long, and do I need nots or anything with them??
funagon
funagon is offline
PostPosted: Sun Jun 29, 2008 12:17 am    Post subject: Reply with quote
In the SF Bay Area, I'm not buying these but someone might want to haggle with this guy for a lower price. From what I have read these should be 5x112 bolt pattern, 14mm lugs. And he's throwing in the bolts:
http://sfbay.craigslist.org/sby/for/735218411.html
1990 GL 7-passenger
2.2 liter WBX
nelinor
nelinor is offline
PostPosted: Sun Jun 29, 2008 11:35 pm    Post subject: 15 x 7.5 et35 Reply with quote
Got these on the vanagon over the weekend. I found them off of craigslist. I think they came off of an Audi 200.
15 x 7.5 et35
Bored out the centers to 66.56
Longer rear studs
10 mm spacers in the front
Special thanks to Loogy for all the help.
1983.5 VW Vanagon Westfalia - manual - EJ22
2002 Subaru Impreza Wrx
1990 Nissan 300zx tt
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
240Gordy
240Gordy is offline
PostPosted: Thu Jul 03, 2008 10:50 pm    Post subject: wheels that don't really fit Reply with quote
mercedes-benz 18x9.5 rear with kumho 265-35W18 tires.
just kisses the trailing arm, nuts only go about half=way onto the studs, don't even think about opening the slider more than a foot.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
Franklinstower
Franklinstower is offline
PostPosted: Sun Jul 06, 2008 9:37 am    Post subject: Reply with quote
Chris,
What did those tires/wheels do to your speedometer?
I am rolling on 215/60/16 on a 16 x 7 passat wheels and my speedo is dead on according to the "your speed" radar displays we have in kirkland.
Did the size of the tire slow down your speedo to read under the actual speed? And if so, do you know how much?
Thanks,
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
Christopher Schimke
PostPosted: Sun Jul 06, 2008 2:19 pm    Post subject: Reply with quote
Franklinstower wrote:
Chris,
Well, this particular van's speedo read way too fast before the larger diameter tires. With the 28.4" tall tires, the speedometer now reads 4-4.5 mph fast and the odometer reads 10% slow.
H2O-Box
H2O-Box is offline
PostPosted: Mon Jul 07, 2008 11:02 am    Post subject: Reply with quote
Hello All,
I have been looking at this thread and have a question about a rather well priced set of rims that I have a chance to pick up.
They are reproduction MB E320 wheels 15"x6.5" ET48 and have 195/65/15 tires on them.
Now I know that the lug holes will have to be enlarged not a big deal.
But what size spacers would I have to run and would the amount of spacer needed remove the need to enlarge the center bore???
Thanks,
Brett-
Christopher Schimke
PostPosted: Mon Jul 07, 2008 2:07 pm    Post subject: Reply with quote
Hello Brett,
For those wheels, you do not have to bore the centers at all since the Mercedes centerbore is 66.56mm and the 2wd Vanagon centerbore is 60.5mm.
I would run a 15mm spacer.
I'm not sure what lugs that particular mercedes wheel uses, but if it takes the stock type ball seat lug, you will need to use 22mm small ball seat lugs with them. The stock Vanagon ball seat lug nuts are too large and won't seat properly.
H2O-Box
H2O-Box is offline
PostPosted: Mon Jul 07, 2008 7:35 pm    Post subject: Reply with quote
Thanks for the reply, now to look into 15mm spacers and pricing....
240Gordy
240Gordy is offline
PostPosted: Tue Jul 08, 2008 8:52 pm    Post subject: Reply with quote
testing the big wheels again today with some cheap spacers, 1/4" on the rear and 1/2" on the front.
18X9.5 ET 38 rear and 18X8.5 ET 35 front
looks like this,
Tencentlife said,
shenan-agon
shenan-agon is offline
PostPosted: Tue Jul 15, 2008 10:46 am    Post subject: Reply with quote
Okay, so it looks like I have a good line on some wheels off a 1990 Mercedes 300E, but wanted to run it by the forum. They are 16x8, ET36 - apparently they're a +1 upgrade.
First of all, will 8" wide wheels fit okay? I assume I'll want some spacers to push them out a bit, but not sure if I'll then run into issues with the slider door.
Anything else I need to worry about? I've read through a bunch of the threads, but bear with me, as I'm still sort of clueless on this wheel fitment stuff...
floggingmolly
floggingmolly is offline
PostPosted: Tue Jul 15, 2008 10:58 am    Post subject: Reply with quote
I can't say with regard to the front suspension geometry, but I'm sure Loogy can. I have 16x7.5 on the rear, ET of 29, tires are 215/65/16. I was looking at the slider this weekend since I just got new tires and was camping. It is close, but there's probably on the order of about 0.5 to 0.75 inches bewteen the tire and the door. Since my tires bulges out a bit more than the wheel, the tire is the critical piece here. The 8 inchers should be OK, as you'll only be 0.125 (half the 0.5 inches) further out than me with the wheel, but again, the tire will be the critical factor.
That's assuming you adjust the ET to around 30. An ET of 36 will put your wheel and tire a bit further in toward the center of the van, but then you have to look at the rear swing arm (I think that's what it's called) to check for clearance. Again, I have about 0.5 or 0.75 inches inboard as well, so I think you're OK as long as your tires are not giantic.
'85 Wolfsburg Weekender
Christopher Schimke
PostPosted: Tue Jul 15, 2008 11:53 am    Post subject: Reply with quote
The good:
16x8 on the rear is no problem even with the 36mm offset. You could add up to about a 15mm spacer and still have enough clearance depending on what tires you ran.
The bad:
A 16x8 on the front is not good at all. In order to gain enough clearance to the suspension, you would need an effective offset of around 17mm. This means that you would need to run a 19mm spacer or adapter. Nothing is preventing you from running a 16x8 on the front, but you will need to position the wheels way outside the recommended offset range and it's nothing I would condone. My suggsetion is to keep looking for wheels in the 7" wide range as they are the easiest to fit, at least for the front.
floggingmolly
PostPosted: Tue Jul 15, 2008 12:16 pm    Post subject: Reply with quote
And so there you have it. Very Happy
Page 31 of 176
