drj434343 Samba Member
Joined: January 31, 2016 Posts: 454 Location: Portland, OR
Posted: Fri Aug 02, 2024 8:01 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
No stock AC system that I've encountered runs the fan coupled to the compressor, which is why I questioned Small Car's wiring and added the ability to disable that.
What I found was that the fan triggering with the compressor caused the compressor to cycle much more rapidly than just triggering the fan on the trinary switch. I didn't see any improvements in vent temperatures, so I view that behavior as just increasing wear on everything.
I'm sure there are other considerations I'm not aware of, but if I can get my 40-degree vent temp AND cycle the fan and compressor less frequently, it seems like a win-win. |
Posted: Wed Feb 12, 2025 2:53 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
I have a question for Small Car AC owners. I'm going through my first winter with the Gen V system, and I've found the heat to be insufficient.
It can't keep even the front of the van comfortable at anything below 45 F exterior temperatures. I'm definitely wearing a jacket when driving to compensate. My vent temperatures are about 105F at 50% fan, no defrost, and full dialed heat. I have the analog triple-dial setup.
I've verified the engine is getting up to temperature (190F), and the engine setup itself is unchanged from when I ran the stock heater box which put out tons of heat.
I'm assuming the primary issue here is the size of the heater core they could fit inside the box, but I would be interested in knowing if others can confirm the lack-luster heating.
I'm thinking about mitigation options, including insulating the heater core lines from the engine to reduce the temp drop getting to the front of the car. I'm also considering a higher temperature thermostat.
Any thoughts or advice would be welcome, thanks! |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7209 Location: Honolulu,Hawaii and France
ledogboy Samba Member
Joined: September 19, 2005 Posts: 600 Location: Scappoose, OR / Oakland, CA
Posted: Wed Feb 12, 2025 8:01 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Do you have, or could you install a rear heater? That thing puts out some crazy heat. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
dcasali Samba Member
Joined: November 08, 2016 Posts: 16 Location: Port Townsend, WA
Posted: Tue Feb 18, 2025 4:41 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Over the past decade my summertime Westy travels in the intermountain west have too often been ruined by increasingly frequent triple digit heat events. My 1989 2WD Westy with factory AC is no match for those temps (well maybe if you could drive from the rear seat).
I’m on the cusp of having Small Car Performance install their Gen V unit into my van at considerable expense (~$7K) - they are only an hour or so drive away. I’ve owned a Vanagon or three since 1986 and do most of the work on it, but at age 78 and without lift or garage I’m not game for installing the SC kit.
I’ve spent considerable time reading this entire thread yet I still have some questions about the performance of the unit.
My primary concern is for driver/front passenger comfort. The rear seat is rarely occupied.
Front seats AC performance at 90+ temps is essential. What has been the experience with the Gen 5 unit? How about when using both front and rear evaporators in parallel? Is a curtain between front and rear compartments necessary?
How badly is heating performance compromised? Mountain morning temperatures can be at or below freezing even in the summer. <drj, I saw your recent comments and questions. Any answers?>
Can you defrost an icy windshield? I saw that one user installed a pump in the van coolant line to boost heater performance. Is that worth doing?
My rear seat heater is still intact, though I’ve never actually used it (note to self: verify function). Does it make any noticeable difference to the front occupants? How does one control it?
Fresh air vents right and left no longer function, correct? I saw mention of a work around but couldn’t find it described.
How noisy is the unit? What creates the noise? (radiator fan or in-dash fan?) Is it quieter than open front windows?
How maintainable is the install? What repairs or modifications of the install are possible without removing the entire dashboard? I’m thinking especially of the trinary switch and radiator fan relay(s?)
Overall, has the SCP unit met your expectations; would you recommend it?
Many thanks in advance.... |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4250 Location: Redwood City, California
Posted: Tue Feb 18, 2025 5:35 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Install alongside OE unit is a big yes. Have you tried removing the plastic plenum and getting one of SAH replacement vents. It actually blows cold sir against the front glass.
A division curtain is a must, it does heat OK, but when raining or moist you need the AC pump running to remove the moisture.
I don’t find the noise bad, I hate fan noise and un needed beeps and buzzes. The new unit has many upgrades including vent doors that don’t stick.
I eliminated the end vents and found the unit lacks air movement at the center of the dash. We’ve had it in hot climates and it makes a huge dufference.
I’ve also put a metalized 3M film in the front glass.
Hope that helps
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Tue Feb 18, 2025 7:59 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Quote: |
Have you tried removing the plastic plenum and getting one of SAH replacement vents. It actually blows cold sir against the front glass. |
I wasn't aware of SAH vents and a quick Google search didn't turn up anything. Could you please send me a link to a source for them. Thanks! |
16CVs Samba Member
Posted: Tue Feb 18, 2025 9:54 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
You would have to call him and leave a message. I don't think they answer their phones anymore.
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10237 Location: Mt Lemmon, AZ
Posted: Wed Feb 19, 2025 7:32 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
In case you didn't catch this, I think SAH = https://www.stephansautohaus.com/ |
vik Samba Member
Joined: January 13, 2005 Posts: 240 Location: back in Czech
Posted: Tue May 27, 2025 10:24 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
joetiger wrote: |
With major thanks to felixbobcat, I think I might have it figured out.
--Blue from control panel/thermostat switch to black/green #1 on trinary
--compressor + to black/green #2
--battery to Blue #1 on trinary
--#87 on relay to Blue #2 on trinary
Bosch relay:
--battery to #30
--ground to #85
--additional added wire from control panel to #86 trigger
--Blue #2 from trinary to #87
--jumper from smaller blue/red on rad thermo switch also to #87
I haven't powered anything up yet, but just want to make sure this looks correct.
Thanks |
Hallo Joe,
You wired the Blue to Battery + not to the ground per the VintageAir instruction?
Bosh relay is the vanagon fan relay on mounted on the pillar on later models?
Additiona wire from control panel to #86 switch on first level fan and 87 is second level, right?
Thank you _________________ T3 Syncro camper in progress |
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5257 Location: denver
Posted: Fri May 30, 2025 8:57 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
vik wrote: |
joetiger wrote: |
Bosch relay:
--battery to #30
--ground to #85
Thanks |
Hallo Joe,
Thank you |
Hi Vik,
I'll have to go back and find my notes to see if I can add any more comments. Unfortunately I'm a bit of a relay dullard and was really stuck. Through multiple messages with felixbobcat, he gave me the above instructions. I'll see what I can find.
I should add that whatever I did, the system has worked well, no issues (knock on wood.) _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
shagginwagon83 Samba Member
Posted: Fri May 30, 2025 10:30 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Has anyone had any luck with the Front A/C along with a rear A/C? Or at least a setup that has two evaporators? _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin
Instagram: @joannthevan |
vik Samba Member
Posted: Sun Jun 01, 2025 11:24 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Had a chat felixbobcat and he helped me to figure out the missing electrical stuff. Great guy!
Need to buy one fuse and wire in one relay and I shall be good to go.
Still many steps before I can say - done. _________________ T3 Syncro camper in progress |
GreggK Samba Member
Joined: May 17, 2008 Posts: 1019 Location: Colorado/Philidelphia
Posted: Sun Jun 01, 2025 2:35 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Has anyone used the "updated" wire diagram, for the Gen IV In-dash unit, on the Smallcar site? Page 41 in the Gen IV install instructions, in their Technical Support Library. After having mine installed for 5 years now, I'm just looking at the diagram, preparing to wire up and plumb the A/C. _________________ '86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady |
vik Samba Member
Posted: Thu Jul 24, 2025 2:27 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Question
How did you attached the heater cover under dash? It is originally attached to the vanagon heater. _________________ T3 Syncro camper in progress |
Posted: Thu Jul 24, 2025 8:30 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
vik wrote: |
Question
How did you attached the heater cover under dash? It is originally attached to the vanagon heater. |
I added two L brackets to the top corners so it hangs off the metal dash. I wrapped them in tape so they don't rattle.
I added a little metal bracket that holds the center bottom against the body.
This is an old photo in which I was using black duct tape on the bottom center, before I added the bracket.
I'll try to snap an accurate photo this afternoon. _________________ Joe T.
Posted: Thu Jul 24, 2025 8:56 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Actually here's a pic that shows my heater cover setup better. You can see the black allen bolts in the upper corners holding the L brackets, as well as the bottom bracket.
vik Samba Member
Posted: Thu Jul 24, 2025 11:24 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
i see, that is obvious solution.
Thx  _________________ T3 Syncro camper in progress |
Kdj Samba Member
Joined: January 28, 2017 Posts: 278 Location: Naptown
Posted: Fri Aug 15, 2025 9:03 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Does anyone have a clear picture of the gen5 evaporator housing mocked up in mounting position without any of the hoses or wiring in place? Similar to this but maybe with out hoses.
Having not seen one installed I'm just curious about placement and ducting compared to other available options of evaporator housings that look like they might fit better.
Couple of the other ones that I thought might fit better
https://restomodair.com/shopproducts/haymaker-s-custom-air-conditioning-kit/
https://www.classicautoair.com/shop/complete-ac-sy...ng-system/
One has as a higher CFM rated fan the the vintage air unit but haven't been able to find info on BTU's yet. I'm just trying to decide which way to go. Obviously the small car option is a proven install. |
