busdaddy Samba Member
Joined: February 12, 2004 Posts: 52907 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 28, 2013 8:57 am Post subject: |
That crossover looks salvageable to me, the muffler likely won't survive grinding off the welds but it looks like the inlet is done for anyways. One must die to save the other, in a worst case desert island scenario you could patch the muff after you got it cut off. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Tue Apr 30, 2013 6:56 pm Post subject: |
Update:
The parts are starting to come in. I have the GeeBee hoses as well as the vacuum and compression testers. The LM-2 came in today and I really want to play with it.
One thing I'd like to do is find out what my idle RPMs are. I bought the basic kit and I've read various things that say I can check RPMs and others talking about an induction clamp accessory being needed.
Does anyone know how I would check my RPMs with this device in terms of how to physically do it?
Should I make a separate thread for this? If so what forum should I use? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
curtis4085 Samba Member
Posted: Tue Apr 30, 2013 7:00 pm Post subject: |
ivwshane wrote: |
Update:
Should I make a separate thread for this? If so what forum should I use? |
buy there analog attachment if the kit doesnt have it already.. i bought a whole kit and it came with it... then connect it to the device run some extra wire back to the coil and bingo RPM.... oh and you have to read the instructions as you have to dial the meter in to the engine to get correct reading... the wankers that sell the product are zero help, just FYI.. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Tue Apr 30, 2013 7:07 pm Post subject: |
curtis4085 wrote: |
ivwshane wrote: |
Update:
buy there analog attachment if the kit doesnt have it already.. i bought a whole kit and it came with it... then connect it to the device run some extra wire back to the coil and bingo RPM.... oh and you have to read the instructions as you have to dial the meter in to the engine to get correct reading... the wankers that sell the product are zero help, just FYI.. |
Keep in mind I am a noob and jumping head first into this. That being said, it looks like the analog cable has several wires in it, what wire did you use to connect to the coil and where on the coil did you connect it (did you attach a spade connector to it)?
Thanks for your help!
Edit:
Ok in the manual it says black/white + blue- cables are used for RPM, I assume that means I hook them up to their respective sides of the coil? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Tue Apr 30, 2013 8:10 pm Post subject: |
ivwshane wrote: |
curtis4085 wrote: |
ivwshane wrote: |
Update:
Edit:
Ok in the manual it says black/white + blue- cables are used for RPM, I assume that means I hook them up to their respective sides of the coil? |
I would have to check. I beleive the blk/wht wire. Manual says. And then hook it up to the same terminal that you hook your timing light on. _________________ Special Thanks to:
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42786 Location: at the beach
Posted: Tue Apr 30, 2013 8:39 pm Post subject: |
not meaning disrespect. Read the instructions at the innovate site. On mine I use an inductive pickup. Keep in mind that the device is not a tachometer or dwell meter. What you want is one of these or equal:
http://www.amazon.com/Actron-CP7605-Tachometer-Vol...tachometer _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Tue Apr 30, 2013 11:19 pm Post subject: |
I don't understand, what's the difference between it telling me my RPMs and a tach? Can you not view the RPMs in real time? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent  Samba Member
Posted: Wed May 01, 2013 6:05 am Post subject: |
ivwshane wrote: |
I don't understand, what's the difference between it telling me my RPMs and a tach? Can you not view the RPMs in real time? |
My LM-1 is not stable enough on the RPM input to use it a as tachometer to set idle speed. If yours is, awesome. I have to use the smoothing tool in the software to get rid of the constant spikes. I use points and not an electronic ignition so I also need dwell setting. _________________ George Carlin:
Posted: Thu May 02, 2013 5:37 pm Post subject: |
I got my dansk Y pipe in today, it has a bung on it but it's way too small for the LM2 sensor or O2 sensor.
Just an FYI. That and the fact that the bung is on the bottom of the pipe means it wouldn't have been a good idea to use it even if it did fit. Everything that I have read says that condensation build up could damage the sensor and to only use a port located at the top between 10-2. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent  Samba Member
Posted: Thu May 02, 2013 8:04 pm Post subject: |
ivwshane wrote: |
Just an FYI. That and the fact that the bung is on the bottom of the pipe means it wouldn't have been a good idea to use it even if it did fit. Everything that I have read says that condensation build up could damage the sensor and to only use a port located at the top between 10-2. |
the cat will have the correct mount. I showed you the photo already. _________________ George Carlin:
Posted: Thu May 02, 2013 8:08 pm Post subject: |
SGKent wrote: |
ivwshane wrote: |
the cat will have the correct mount. I showed you the photo already. |
I know. My post was to inform others that might have been wondering if that port would work and I was just confirming that it didn't. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent  Samba Member
Posted: Thu May 02, 2013 8:19 pm Post subject: |
ivwshane wrote: |
SGKent wrote: |
ivwshane wrote: |
I know. My post was to inform others that might have been wondering if that port would work and I was just confirming that it didn't. |
Oh. _________________ George Carlin:
Posted: Thu May 02, 2013 8:36 pm Post subject: |
That bung is for gas analyzer not O2 sensor. So If and when you where at the smog shop you could read your CO per-CAT _________________ Special Thanks to:
Chris_914 Samba Member
Joined: September 16, 2011 Posts: 344 Location: Las Vegas
Posted: Fri May 03, 2013 11:04 am Post subject: |
Nope the factory port would have been for a specific dealer setup to use.
The one currently on your bus looks like it might be a modern weld in bung for an O2 sensor. _________________ '75 Westfalia Camper FI 1.8L
'75 914 2.0L |
Posted: Mon May 06, 2013 4:52 pm Post subject: |
Another update:
I got the analog cable for the lm-2 and did an idle RPM check. The bus was cold and the idle kept increasing until it leveled off at about 1540. I checked for vacuum leaks on a few of the lines (I'm still waiting for my replacement kit to come in) and no signs of vacuum leaks. I decided to adjust the idle speed and turned it down until it hovered between 870-880.
I don't know for sure what loose valves sound like but if I had to guess I would say I need to adjust them (I'm waiting for the gaskets from germansupply).
I also got my VHT flameproof paint in today and I plan on painting the new parts (I've already stripped the primer from the new tail pipe and F(Y) pipe).
Would you guys paint the CAT? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Mon May 06, 2013 5:19 pm Post subject: |
ivwshane wrote: |
Another update:
Would you guys paint the CAT? |
I ceramic chromed my system. Some paint some leae alone. It's stainless Steel so should hold up. _________________ Special Thanks to:
Posted: Mon May 06, 2013 5:57 pm Post subject: |
curtis4085 wrote: |
ivwshane wrote: |
Another update:
I ceramic chromed my system. Some paint some leae alone. It's stainless Steel so should hold up. |
Ceramic would be nice but it's out of my budget and time line plus it means someone else would be doing it instead of me. I'm in it now and I'm going to finish it myself. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent  Samba Member
Posted: Mon May 06, 2013 8:42 pm Post subject: |
it is stainless - you can leave it alone. Besides, a new cat sticks out like a sore thumb. You will be Ok cause yours is a CARB-II cat but someone with an older cat who polishes or plates it may end up being accused of installing a new non-CARB-II cat. The CHP are trained to look for stiff like that as well as the CARB-II emblem on it which has to be visible from 5' away. _________________ George Carlin:
Posted: Mon May 06, 2013 8:55 pm Post subject: |
SGKent wrote: |
it is stainless - you can leave it alone. Besides, a new cat sticks out like a sore thumb. You will be Ok cause yours is a CARB-II cat but someone with an older cat who polishes or plates it may end up being accused of installing a new non-CARB-II cat. The CHP are trained to look for stiff like that as well as the CARB-II emblem on it which has to be visible from 5' away. |
Good point. I guess my main concern was keeping it protected but stainless steal does a pretty good job.
I just hope I can get my crossover pipe off cleanly so I can re use it. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Fri May 10, 2013 2:59 pm Post subject: |
Update:
I got my CAT in today:D but I'm still waiting on my order from germansupply (Scott says it should be shipped on Monday:().
A quick question regarding the bung plug. Do I need a washer on it or any other thread sealant or thread lock? I'm using the plug that came with my LM-2 but I like the one Steve uses with the Allen head option. Are those carried by any FLAPS? Are O2 plug holes/threads all the same size?
Edited to add info for me for future reference:
From VHT for flameproof paint:
Quote: |
You won't need to bake the primer and top coats separately. You can apply 3 coats of primer allowing 30 seconds in between each coat, allow it to dry 10 minutes, apply the top coat allowing 30 seconds in between each coat, let it dry for 10 minutes, apply the Clear, allow 30 seconds in between each coat then then bake it once the top coat has dried overnight. |
69 ghia coup 1600dp
70 single cab |
