Straight axle conversion inner spacer
Yannvanh
Yannvanh is offline
PostPosted: Sat May 07, 2022 9:02 pm    Post subject: Straight axle conversion inner spacer Reply with quote
Hi guys,
I am doing a Sa conversion on my 65 bus and made the axle tubes myself.
Now im in the proces of putting it all back together but i noticed that the inner spacer falls tot deep (i think) in the tube..
I can pull the axle itself a little bit and then the spacer will sit flush with the tube..
Am i doing something wrong or did i made the tubes to long?
I hope you guys van understand what im' saying here!
Thanks!
Teeroy Premium Member
Teeroy is offline
PostPosted: Sun May 08, 2022 4:54 pm    Post subject: Re: Straight axle conversion inner spacer Reply with quote
Which axles are you using?
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Ragtop
Ragtop is offline
PostPosted: Sun May 08, 2022 7:38 pm    Post subject: Re: Straight axle conversion inner spacer Reply with quote
Did you use short end castings?
John Ghia
John Ghia is offline
PostPosted: Sun May 08, 2022 7:59 pm    Post subject: Re: Straight axle conversion inner spacer Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=...aight+axle
BUS BOYZ
Yannvanh
Yannvanh is offline
PostPosted: Thu May 12, 2022 12:43 am    Post subject: Re: Straight axle conversion inner spacer Reply with quote
Yes i used the short end castings and made the axles the same way with the jig like the SA thread:
I use the long axle/long spline
Vanell
Vanell is offline
PostPosted: Thu May 12, 2022 4:43 am    Post subject: Re: Straight axle conversion inner spacer Reply with quote
I measure the long housing with the bearing in, then I make the short end housing that length with also the bearing in, seems to me the problem you are having as the bearing seats differently in the long and short housing. Ian
Yannvanh
Yannvanh is offline
PostPosted: Mon May 16, 2022 10:53 am    Post subject: Re: Straight axle conversion inner spacer Reply with quote
There's a difference of +- 4 mm so i think i have found the problem!
Gonna make a new inner spacer that's 4 mm wider from an old (wider) outer spacer with a lathe machine!
I also need spacers for early bug drums so need to trim the outer one 4mm down so the axle nut will fit!
Thanks guys!
