chadwick Samba Member
Posted: Sat Mar 25, 2006 12:04 am Post subject: Can the genny handle this? |
Hey guys if im running 2 6x9s in the back a 4x6 in the dash spot and a 12 inch sub powered by a 260 watt amp am i risking any electrical problems. I did a search and some said that just a speaker and a tape deck is risky others said they were running 6 speaker system with beastly amps. Whats the true answer. |
vdubman27 Samba Member
Joined: July 08, 2004 Posts: 99 Location: riverside ca 92509
Posted: Sat Mar 25, 2006 12:38 am Post subject: |
what is the amp draw on you 230 watt amp? your gen is rated at 30 amps |
rloaircool Samba Member
Joined: January 21, 2004 Posts: 304 Location: Idaho Falls, Idaho
Posted: Sat Mar 25, 2006 8:53 am Post subject: Re: Can the genny handle this? |
chadwick wrote: |
Depending on how much power the amp is drawing, your headlights might dim. You might want to add a capacitor. |
Posted: Sat Mar 25, 2006 6:18 pm Post subject: |
on the amp it just has a big wide red X it doesnt say anything else imma go on the website and see. what does it have to be below. can it be up to 30 amps or should it be like 25 or 20? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Mar 25, 2006 8:36 pm Post subject: |
If you pull 30 amps off the system, you will eventually drain the battery. 30 amps is the max the generator can do, not the average.
You would not be able to use the head lights, wipers, t/s, ETC. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
Posted: Sat Mar 25, 2006 11:19 pm Post subject: |
230watts for a 12v system is 19.17amps. That means at full peak your amp would be drawing almost 2/3 of the total amperage from your generator. Not sure how the meager charging system would like that abuse.  _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Sun Mar 26, 2006 10:44 am Post subject: |
vdubman27 wrote: |
Ohms law: Volt x amp = watt
So, 230watts divided by 12Volt = 19.166666amps
The number that air cooled nut came up with.
Just to show how it is figured. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun Mar 26, 2006 2:37 pm Post subject: |
Thanks Russ I have the formulas in my PDA. I enter in any two of the values, tap the SOLVE button, and it gives me the third value. _________________ Toby http://www.aircoolednut.com/
Posted: Sun Mar 26, 2006 3:39 pm Post subject: |
If this was the rants, I would say "f__k PDA's". Too many people depend on them and calculators. Learn to do it in your head. That "calculator" usually doesn't fail until we die.
Just ranting a little.
One of my grandkids can't tell time on a clock hands on it. He's gotta have digital. Schools don't even teach them how to tell time anymore. OR the parents. I ranted on my daughter when I found that out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
