ratpanel61 Samba Member
Joined: November 04, 2003 Posts: 345 Location: Va Beach, VA
Posted: Mon May 22, 2006 9:46 am Post subject: I broke it good today. |
So there I was. I took the bus out on the interstate for some high speed runs to make sure that it wouldn't break on the way to Manassas next weekend. About 35 minutes into the drive, the shifter popped out of 4th at about 70 so I got off at the next exit. Now I can push it wih the engine off like it's in neutral, but when I fire the motor up, all of the gears are gone and it bogs the motor down and kills it like it's still in gear. When I try to get it into anything, it's grinding and then it dies. I just replaced all of the shifter linkage from the nosecone forward and all was good until today. I guess I'll be yanking the motor and tranny to try to get it fixed before next weekend. I really don't want to have to drive the wifes car up there....Damn, I'm pissed right now!!! _________________ - '57 Sunroof Beetle (project)
- '73 THING |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon May 22, 2006 10:21 am Post subject: |
Man that sounds exactly what mine did. The man bearing under the nose cone came apart. Did you have any indications something was wrong up to that point? I heard load whirring sound and then it wouldn't go into gear. When I pulled it apart there where pieces of the bearing all over. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon May 22, 2006 11:35 am Post subject: |
You need to recheck both couplers and the front shifting shaft. First, though, drain the oil out of the centersection and see if there is any metal in it.
The rebuilt freeway flyer I bought from Transform over a year ago (one or two months before the old fart retired and closed the transmission part of the business, as it turned out) that I finally put in one of my buses two weeks ago with RGBs that I had rebuilt, lasted all of six miles.  |
Posted: Mon May 22, 2006 12:41 pm Post subject: |
I just got done pulling the tranny. The forward plug fell out (along with all of the oil) so that one's toast. There's not just metal shavings when I still my finger in the hole, there's metal chunks. I guess I need to get hot on finding another tranny before next weekend. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12561 Location: Over 2002 posts deleted!
Posted: Mon May 22, 2006 1:07 pm Post subject: |
ratpanel61 wrote: |
The forward plug fell out ... |
How is it that the plug "fell out"?  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon May 22, 2006 3:00 pm Post subject: |
I'm not sure how it "fell out", but it was fine yesterday, and today when it exploded, the drain plug was gone and all of the oil that was supposed to be inside the tranny was all over underneath the bus and the plug was nowhere to be found. Maybe it wasn't tight (like I thought it was) and rattled itself loose. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
