bought a 98 passat 4cyl turbo -non running
Forum Index -> Water-cooled VW Share: Facebook Twitter
bandit86
bandit86 is offline
PostPosted: Tue Jun 15, 2010 2:49 pm    Post subject: bought a 98 passat 4cyl turbo -non running Reply with quote
the guy said he wanted to put a radio in it and an oil change, never ran again. IS there some sort of built in theft protection system?
5spd, 120,000miles, needs lots of TLC , but for 500 I couldnt leave it
Is there an online shopmanual availible?
73sports
73sports is offline
PostPosted: Tue Jun 15, 2010 3:05 pm    Post subject: Reply with quote
Does the engine turn over? There is nothing connected to the radio that would prevent it from starting. 98s don't have the immobilizer system. Give us some more details on what it will or will not do, and we can help you out.
I will never lie, but sometimes the truth changes.
Central Jersey VW Society
bandit86
bandit86 is offline
PostPosted: Tue Jun 15, 2010 3:10 pm    Post subject: Reply with quote
waiting for the towtruck to bring it over
bandit86
bandit86 is offline
PostPosted: Wed Jun 16, 2010 4:12 pm    Post subject: Reply with quote
put a fresh battery in it and nothing. checked the fuses, a 15Amp was blown, looks to be 43? just checking starter wiring now
bandit86
bandit86 is offline
PostPosted: Wed Jun 16, 2010 5:14 pm    Post subject: Reply with quote
also, with the key turned, if I press the clutch, I can hear a relay click, so I think the pedal switch and key switch work
bandit86
bandit86 is offline
PostPosted: Wed Jun 16, 2010 7:12 pm    Post subject: Reply with quote
just checked, the key remote is gutted, the lock on drivers door just turns right around. will need to take the door apart. I was trying the turn left then right bit to try to override the alarm
73sports
73sports is offline
PostPosted: Thu Jun 17, 2010 3:51 pm    Post subject: Reply with quote
When you open the driver's door, there is a rubber cap that is visible (on the door), if you remove this, there is a torx screw behind it. This is the screw that secures the lock part of the door handle in place. Loosen this, and you can remove the lock part. With that removed, you can then use a slotted screwdriver to lock or unlock (disable the alarm) the door. If you still can't ge the starter to crank the engine, first make sure the engine is not seized! Second, the comfort control module ( window, alarm, starter lockout) is in a plactic box under the carpet on the driver's side floor. If the car had a water leak, this box may have filled with water, and of course a wet ccm is not going to work. If the ccm is bad the car may not turn over.
bandit86
bandit86 is offline
PostPosted: Fri Jun 18, 2010 7:12 pm    Post subject: Reply with quote
was a bad starter, the wire from the solenoid to the motor oxidised through. got a wire connector, seems to work.
Now it runs on 3 cylinders, #2 coil not firing. Swapped them around, always number 2 cylinder, gonna check the wiring.
zuhaelter_82
zuhaelter_82 is offline
PostPosted: Thu Jun 24, 2010 11:28 am    Post subject: Reply with quote
I think each coil has a ground to the valve cover. Check that and then pull the plug and check that. With the plug out crank it for a sec and smell the hole to see if gas is even getting to the cylinder.
64 Type II
MKI Jetta Coupe Diesel
MKI Jetta Sedan w/TD swap
B5 V6 GLS
B7 TDI Passat SE
73sports
73sports is offline
PostPosted: Thu Jun 24, 2010 3:17 pm    Post subject: Reply with quote
Replace the ignition output stage (the thing with the 2 plugs on it bolted on top of the air box). For some reason when they fail, #2 coil doesn't fire. I've replaced a bunch of them over the last 10 years!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
