thebigben Samba Member
Joined: October 22, 2020 Posts: 94 Location: California
Posted: Fri Aug 27, 2021 9:29 pm Post subject: Re: Who's got a wood floor? |
I bought some wood-like foam mats on Amazon. Really stunned by how good they look.
Will report back with how they hold up. Took about 30 seconds to install. _________________ Ben
'85 2WD Westy w/ Peloquin TBD + 2.2 Subi (Kurt Vannegut) |
Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Fri Jul 01, 2022 8:44 pm Post subject: Re: Who's got a wood floor? |
I just scored a couple boxes of bamboo/engineered flooring from a gal giving it away on marketplace. Really stoked because I was going to pay too much for pergo...
anyways, I'm looking at the photos in here of at the different under layers and I'm thinking about throwing some old yoga mats under there. Anyone done this? _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
Posted: Sat Sep 24, 2022 7:06 pm Post subject: Re: Who's got a wood floor? |
I got...vinyl!
Sick at home with COVID but got antsy, so a low-impact van project seemed to fit the bill.
I had a bunch of loose lay vinyl flooring left over from a home project and thought it would be perfect for the van.
The loose lay is nice because it's flexible, light and easy to install. In a room you typically put the borders down with adhesive and the rest just stays in from pressure. If you damage a board you can just lift it out and replace it. The only thing I don't like is that it marks up fairly easy. Very easy to clean though.
Originally I was going to stick this on a plywood sub-floor but after a dry fit I realized it would stay in place just on the stock floor without any adhesive. The boards fit under the cabinet overhangs nicely.
The tracks proved to be problematic. I tried without the covers but the boards aren't rigid enough to prevent a bit of a dip. I put the covers back on without the hardware since they stick up pretty high but the covers were still higher than the rest of the floor, causing the boards to buckle. Solution: I cut little inserts for the tracks from extra flooring.
I'm pretty happy with how it turned out. All I needed was a screwdriver, measuring tape, drill, pencil and razor knife. No sawing, gluing etc. I'll probably finish it with a nicer threshold.
_________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
Jan Steinman Samba Member
Joined: July 03, 2022 Posts: 175 Location: Bellingham, WA, USA
Posted: Sat Sep 24, 2022 11:07 pm Post subject: Re: Who's got a wood floor? |
Don't have a nice one showing the floor off, but there's the installation in process of the Acacia floor we found at the local ReStore, for about $40.
We also did the door panels in birch.
Schuylersister Samba Member
Posted: Sun Sep 25, 2022 10:10 am Post subject: Re: Who's got a wood floor? |
Mckinleyvillian wrote: |
anyways, I'm looking at the photos in here of at the different under layers and I'm thinking about throwing some old yoga mats under there. Anyone done this? |
I installed cork snap together flooring in my van but used rattletrap as the underlayment after removing the factory underlayment.
The cork wears nice. I think the bamboo will too. If you need some underlayment I have a small amount that will work for engineered flooring in my shop and will be happy to donate. I live near Blue Lake, Ca. |
Posted: Sun Sep 25, 2022 10:27 am Post subject: Re: Who's got a wood floor? |
Schuylersister wrote: |
I installed cork snap together flooring in my van but used rattletrap as the underlayment after removing the factory underlayment. |
We did similar… removed down to metal, then put rattle trap in-between the ridges, then put a thin layer of black closed-cell overall, before putting the snap-fit acacia down.
There's a mismatch between the pitch of the flooring and the pitch of the ridges in the metal floor, so the floor is a bit spongy in places. But She Who Must Be Obeyed insisted that the grooves go toward the door, to make sweeping easier. |
Posted: Mon Oct 10, 2022 12:10 am Post subject: Re: Who's got a wood floor? |
hey just now seeing this. thanks for the offer, but i ended up getting some vapor barrier. i'll post pics of the floor soon i guess. i'm right off sutter in mckinleyville,.... _________________ so many roads i know
Walty87 Samba Member
Joined: November 02, 2020 Posts: 172 Location: Central Valley
Posted: Sun Feb 05, 2023 3:11 pm Post subject: Re: Who's got a wood floor? |
Hey guys!
I recently got a full westy interior that I’m going to install in my van, but before doing that I plan to redo my floor.
Do you guys usually do flooring under the westy cabinets or do the cabinets sit directly on the metal and the flooring rests against them?
Thanks |
Klister Samba Member
Joined: March 06, 2018 Posts: 199 Location: Washington
Posted: Sun Feb 05, 2023 4:40 pm Post subject: Re: Who's got a wood floor? |
I'm sure this varies by installer - I put my wood floor abutting the cabinets and the bench seat, cutting out smaller area for the back heater vent and my Webasto heater vent. I certainly did not want to go through hassle of removing my westy cabinets for that. |
Posted: Mon Feb 06, 2023 8:03 am Post subject: Re: Who's got a wood floor? |
Klister wrote: |
Makes sense, but mine are currently out. Hmm. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16512 Location: Brookeville, MD
Posted: Mon Feb 06, 2023 8:15 am Post subject: Re: Who's got a wood floor? |
Walty87 wrote: |
Hey guys!
Thanks |
On all mine cabinets go on plywood as a sub floor. Then the final flooring is butted up against the cabinets, not under them. _________________ Dave O
The Western Syncro build
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 608 Location: Lodi, CA
Posted: Mon Feb 06, 2023 10:01 am Post subject: Re: Who's got a wood floor? |
Walty87 wrote: |
Hey guys!
Thanks |
I pulled everything out and lined the floor with soundproofing. The Rear-seat fits slightly differently with the thickness of the floor. I also made a custom cabinet though. _________________ 83 Air-cooled 2.0 Tin Top |
tjet Samba Member
Posted: Mon Feb 06, 2023 10:54 am Post subject: Re: Who's got a wood floor? |
I started a wood floor project a few years ago. My intent was to build a camper style interior from the floor up (I have a stove, fridge, heater, sink, etc). It ended up being more like a workshop floor where I can stuff motorcycles and tools into My van is more like a truck than a nice camper.
I used high quality 1/2" marine grade plywood. It was lighter than that heavy molded rubber/foam mat. When I do it again, I'm going to go with 5/8 or 3/4". I plan on cutting the roof eventually for an NAHT roof, and a thick sheet of plywood bolted to the floor may increase structural rigidity of the van.
campism Samba Member
Joined: September 07, 2007 Posts: 4496 Location: Richmond VA
tjet Samba Member
Posted: Tue Feb 07, 2023 1:53 pm Post subject: Re: Who's got a wood floor? |
Yeah, every Vanagon owner needs a trail bike on-board (or 2). I've since cut that exhaust tip off as it had a tendency to snag on things. I really need to make a bumper-mounted rack. I plan on carrying 2 bikes.
That TW200 in my van is a '20. My other TW200 (below) is an '87 (same year as my syncro). I'm working on the engine currently.
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
tjet Samba Member
Posted: Tue Feb 07, 2023 3:57 pm Post subject: Re: Who's got a wood floor? |
That's the engine I'm installing in my '87 TW. I want a 6-speed for it, plus the extra 25cc. Here's the XT225 donor bike I picked up a couple of months ago.
https://www.youtube.com/shorts/aylghkOX_dY |
